- Frydex
REGISTRAČNÍ ČÍSLO: ESW-H 665 Datum výroby: 20080612 Značka: Opel Vauxhall VIN: W0L0AHM758G189383 Kód modelu: 0QN75 Kód balení: LF62
Typ motoru: Z19DTH
Sériové číslo motoru: 17359456
W0L:General Motors
A:Astra Platform
H:2004 Platform Generation
M75:Monocab (Zafira)
8:2008
G:Gliwice
189383:SERIAL NUMBER
2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 4AU = VNĚJŠÍ BARVA,VIZ SEZNAM BAREV V ÚVODĚ KATALOGU 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A14 = SKLO,BOČNÍ OKNO,ZADNÍ,ZBARVENÉ A33 = ELEKTRICKY ŘÍZENÉ OKNA,ZADNÍ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO A53 = PŘEDNÍ SEDADLO,SPOLUJEZDEC,6CESTNÝ RUČNÍ A88 = OPĚRKA HLAVY,PŘEDNÍ SEDADLO,AKTIVNÍ AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AHB = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA AJT = PRO PŘÍPRAVU K MONTÁŽI BEZPEČNOSTNÍ SÍTĚ ANY = KOLEJNICE A VÁZACÍ ÚCHYTY PRO NÁKLAD AP9 = SÍŹ NÁKLADOVÉHO PROSTORU AQ2 = SÍŤ KOMFORTNÍ AV4 = DĚLENÉ ZADNÍ SEDADLO AWY = ZÁDRŽNÝ SYSTÉM ZADNÍ SEDADLO,RAMENNÍ,ZATAHOVÁNÍ,ODDĚLITELNÝ KOTVICÍ BOD BEZPEČNOSTNÍHO PÁSU AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BNS = LIŠTA KRYCÍ DVEŘE VNITŘEK,SATÉNOVÁ STONE BPI = LIŠTA PŘÍSTROJOVÉ DESKY,SATÉNOVÁ STONE BRL = IDENTIFIKAČNÍ KRITICKÝ BOD MR 2008 1/2 BW4 = S CHROMOVOU LIŠTOU BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE C32 = PRO SYSTÉM QUICKHEAT C68 = PRO ELEKTRONICKOU KLIMATIZACI C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CE1 = STÍRAČ,PŘEDNÍ,IMPULSOVÝ SYSTÉM CE4 = OSTŘIKOVAČ SVĚTLOMETU CT3 = PRO NĚMECKO CT3 D75 = KLIKA ÚPLNÁ VNĚJŠÍ DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO DD8 = PRO VNITŘNÍ ZRCÁTKO CITLIVÉ NA SVĚTLO DDH = ZRCADLO,ELEKTRICKÉ A VYTÁPĚNÉ,PRAVÉ,LEVÉ DDI = ZRCÁTKO,SESTAVA DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4Q = ENJOY E94 = KRYT ECA = KLÍČ F52 = PODVOZEK SE SPORTOVNÍ ÚPRAVOU FE4 = SYSTÉM PRO SPECIÁLNÍ JÍZDU A JÍZDNÍ VLASTNOSTI (IDS+) FW7 = POMĚR NÁPRAVY 3.83 FX3 = PROGRAM ELEKTRONICKÉ STABILITY FZ3 = PRO ZDOKONALENÝ ELEKTRONICKÝ PROGRAM STABILITY (STABILITA PŘÍVĚSU) G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K13 = POUŽÍVÁ SE S FILTREM PEVNÝM ČÁSTIC VE VÝFUKOVÉM SYSTÉMU K34 = REGULÁTOR RYCHLOSTI KA1 = PRO VYHŘÍVANÁ PŘEDNÍ SEDADLA KB5 = ASISTENT ROZJEZDU DO KOPCE KC7 = ELEKTRICKÁ ZÁSUVKA,ZADNÍ SEDADLO KC8 = ZÁSUVKA,VÝSTUP POMOCNÉHO NAPÁJENÍ KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA KCN = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 3.POLOHA KG9 = ALTERNÁTOR,140A LHD = ŘÍZENÍ LEVÉ LRD = VZNĚTOVÝ MOTOR Z19DTH MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR) N52 = VOLANT,TŘI PAPRSKY NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NR1 = PRO REDUKOVANOU DRÁHU HŘEBENOVÉ TYČE NT4 = EMISE,EEC 05 OHA = MÍSTNÍ GM Z EUROPE OHA PHP = TEXTILNÍ ČALOUNĚNÍ,TABITA/ELBA QGT = PNEUMATIKY,225/45 R 17-91V QQ5 = PRO VELKÉ NÁHRAD.KOLO R2L RCL = KOLO 17X7, HLINÍK, 7 DVOJITÝCH PAPRSKŮ, STYLOVÉ T2Q = REFLEKTORY,AUTOMATICKÉ ZAPÍNÁNÍ/VYPÍNÁNÍ T67 = BATERIE,70AH T96 = SVĚTLO DO MLHY PŘEDNÍ T9M = ČALOUNĚNÍ ELBA TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ TSQ = OSVĚTLENÍ INTERIÉRU DELUXE TT2 = SVĚTLOMETY SMĚROVÉ,VYSOKÁ INTENZITA VÝBOJKA,TLUMENÉ XENONOVÉ,DÁLKOVÉ XENONOVÉ/HALOGENOVÉ TTB = OSVĚTLENÍ VNITŘNÍ,STŘEŠNÍ, ZADNÍ KOMFORTNÍ A DVOJITÉ ČTECÍ,3. ŘADA TTO = RÁDIO CHLADICÍ SYSTÉM TTX = PRO POMOCNÝ KONEKTOR RÁDIA U3A U55 U66 = REPRODUKTOR,7 U68 = INFORMAČNÍ POČÍTAČ U71 = ANTÉNA,ÚPLNÁ,STŘECHA UAJ = GRAFICKÉ INFORMACE - BARVA UCL = RÁDIO AM/FM STEREO,HLEDÁNÍ,DVD,NAVIGACE,ETR,TLUMENÍ UD5 = ČIDLO, PARKOVACÍ SYSTÉM UEC = SNÍMAČ INDIKÁTOR AUTOMATICKÉ RECIRKULACE VZDUCHU UH0 = VÝSTRAHA BEZPEČNOSTNÍHO PÁSU,LH UJ3 UJ9 = INDIKÁTOR PODHUŠTĚNÍ PNEUMATIKY UJC = SPÍNAČ SPORTOVNÍ REŽIM V3E = DRŽÁK ZAVAZADEL VOLNÝ STŘEŠNÍ,STŘÍBRNÝ V4M = VYBAVENÍ 5-STAR,SADA NCAP VG2 = OCHRANNÍ VOSK, VYNECHEJTE VGB = STŘEŠNÍ NOSIČ ZAVAZADEL,ELOXOVANÝ VJU = STŘEDOVÝ PŘÍSTROJ NA PANELU,SATÉNOVÁ STONE VNF = ODPOJOVAČ BATERIE W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y W7Z = ZAŘÍZENÍ,ZIMA WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO WBG = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,GPS XA3 = OPEL XG3 = PRO NĚMECKO Y67 = POŽADUJE PŘI OSAZENÉM SERVISNÍM DISPLEJI Z0F = PRO NĚMECKO Z0F Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ ZQ8 = UŽITO SPOLU SE SPORTOVNÍM PODVOZKEM
Typ motoru: Z19DTH
W0L:General Motors
A:Astra Platform
8:2008
G:Gliwice
Prosím o výpis.....
W0L0AHM757G140593
Děkuju
W0L0AHM757G140593
Děkuju
VIN: W0L0AHM757G140593 Kód modelu: 0Q 75 Kód balení: KD51 REGISTRAČNÍ ČÍSLO: Datum výroby: 21052007
Typ motoru: Z18XER
Sériové číslo motoru: 20KE1246
W0L:General Motors
A:Astra Platform
7:2007
G:Gliwice
140593:SERIAL NUMBER
20S = BARVA STEHŮ,HVĚZDNĚ STŘÍBRNÁ
2AU = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ
2H0 = MOTOR BENZINOVÝ C18SEL[2H0],Z18XER[2H0],A18XER[2H0]
80I = VNITŘEK-ČERNÝ
AQ0 = OPĚRKA HLAVY,ZADNÍ SEDADLO,VINYLOVÝ POTAH,DVA,KRAJNÍ
AY9 = OPĚRKA HLAVY,ZADNÍ,VINYL,STŘED
B70 = KRYT PRAHU DVEŘÍ
BA9 = CHLADNIČKA
BL5 = LIŠTA KRYCÍ DVEŘE VNITŘEK,STŘÍBRNÁ
BLB = KRYCÍ LIŠTY PŘÍSTROJOVÉ DESKY,STŘÍBRNÁ
BRG = IDENTIFIKAČNÍ KRITICKÝ BOD 2007 1/2 MR
CT1 = PRO BELGII
CT1
DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ
DDU = ZRCÁTKO,SESTAVA
DP6 = TĚLESO
E4R = PRODEJNÍ BALÍK SADA-COSMO
E94 = KRYT
ECA = KLÍČ
FX1 = KONEČNÝ POHON NÁPRAVY 3.94
JL9 = ABS
K60 = ALTERNÁTOR,100AMP
LHD = ŘÍZENÍ LEVÉ
M25 = RUČNÍ PŘEVODOVKA,5 RYCHLOSTNÍ,F17 TYP
N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM
NT4 = EMISE,EEC 05
OHB
PXF = LEM,ALFA/VINYL
QGF = PNEUMATIKY,205/55 R 16-91H
QL5 = KOLO,VOZOVKA,HLINÍK,10 PŘÍČEK,61/2JX16
R2F
T6K = PANEL VYBAVENÍ,VNITŘNÍ,VINYL
T9S = SVÍTILNA ÚPLNÁ,VNITŘNÍ,PŘEDNÍ DVEŘE
TN6 = BATERIE,55AH
U07 = HOUKAČKA,TROUBA
U3C
U55
U66 = REPRODUKTOR,7
UCE = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,NAVIGACE,ETR,TLUMENÍ
UJ3
VFE = NÁRAZNÍK PŘEDNÍ A ZADNÍ,OCHRANNÝ VÝLISEK,BAREVNÝ
VK8 = DRŽÁK,BRÝLE
W4Y
XA3 = OPEL
XK1 = PRO BELGII
Z0D = PRO BELGII
Z0D
Typ motoru: Z18XER
W0L:General Motors
A:Astra Platform
7:2007
G:Gliwice
80I = VNITŘEK-ČERNÝ
BA9 = CHLADNIČKA
CT1 = PRO BELGII
CT1
DP6 = TĚLESO
E94 = KRYT
ECA = KLÍČ
JL9 = ABS
LHD = ŘÍZENÍ LEVÉ
NT4 = EMISE,EEC 05
OHB
R2F
TN6 = BATERIE,55AH
U3C
U55
U66 = REPRODUKTOR,7
UJ3
VK8 = DRŽÁK,BRÝLE
W4Y
XA3 = OPEL
XK1 = PRO BELGII
Z0D = PRO BELGII
Z0D
Soliku díky!
- roman.schmidt
Zdravim Vas, Mohol by som poprosit o rozkodovanie VIN ? W0L0AHL35D2033848
Dakujem vopred
Dakujem vopred
Opel Astra III Caravan, A16XER mit LPG
Podle D ve VIN je to již modelový rok 2013 a těžko bude mít zatím někdo tak nové EPC na rozklad
- Radoš92
A prosil bych ještě W0L0TGF7552022548
Díky.
Díky.
W0L0AHL35D2033848roman.schmidt píše:Zdravim Vas, Mohol by som poprosit o rozkodovanie VIN ? W0L0AHL35D2033848
Dakujem vopred
Motor typ: A16XER číslo motoru: 20SS7435
datum výroby: 16112012
kód čalounění: XXVM
80I = VNITŘEK-ČERNÝ
AH3 = PŘEDNÍ SEDADLO,ŘIDIČ,RUČNÉ NASTAVENÍ
AJ7 = PRO BEZP. VAK ŘIDIČE, SPOJEZDCE A BOČNÍ VAK
AT3 = ZESÍLENÉ UKOTVENÍ ZADRŽOVACÍHO SYSTÉMU ZADNÍ DĚTSKÉ SEDAČKY
B76 = PRO PŘÍSTROJ S ČERNÝM CIFERNÍKEM
BKV = LIŠTA PŘÍSTROJOVÉ DESKY VNITŘNÍ,UHLOVÁ
BYD = LIŠTA KRYCÍ DVEŘE VNITŘEK,VYNECHEJTE
CR7 = PRO MAĎARSKO
CR7
DP6 = TĚLESO
GAR = VNĚJŠÍ LAK, VIZ KATALOG MODELŮ, ÚVOD, TABULKA LAKŮ
JL9 = ABS
LDE = Z16EXR,A16XER[LDE] ZÁŽEHOVÝ MOTOR
LHD = ŘÍZENÍ LEVÉ
N65 = PNEUMATIKA,NÁHRADNÍ,ÚSPORA PROSTORU
NE9 = EMISNÍ SYSTÉM EEC 09
OHG
PA7 = KOLO,DISKOVÉ,OCEL,61/2Jx15
QHL = PNEUMATIKY,195/65 R 15-91H
T9P = DEKORACE TMAVÁ,TĚLESO SVĚTLOMETU
TN6 = BATERIE,55AH
TTX = PŘÍVOD POMOCNÉHO KONEKTORU VÝBAVY RÁDIA
U3F
U55
UAG = GRAFICKÁ INFORMACE - JEDNOBAREVNÁ
UCH = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,ETR,TLUMENÍ,MP3
UJ3
UW6 = REPRODUKTOR,6
V48 = CHLAZENÍ,MAXIMÁLNÍ OCHRANA
VG9 = OCHRANNÍ VOSK
VU2 = STŘEDOVÝ PŘÍSTROJ NA PANELU,CHROMOVANÁ MATT
W4Y
XA3 = OPEL
XB2 = PRO MAĎARSKO
XJ9 = PRO MAĎARSKO
Z1F = RYCHLOMĚR KM/H
Z1O = PRO MAĎARSKO
- roman.schmidt
To romanK = velka vdaka
Plastovej kryt příčníku na hagusy? Díky
