to Frydex: Díky za info. Co se týče srazu, koukal jsem na termín a bohužel nedorazím. Budu budovat kapitalismus v práci...
Astra H, 1,6 Twinport 77 kw, r.v. 2004
- Frydex
pajus99:
REGISTRAČNÍ ČÍSLO: DJ181KE Datum výroby: 20070530 Značka: Opel Vauxhall VIN: W0L0AHM757G146169 Kód modelu: 0QN75 Kód balení: LD67
Typ motoru: Z19DT
Sériové číslo motoru: 5528687
W0L:General Motors
A:Astra Platform
H:2004 Platform Generation
M75:Monocab (Zafira)
7:2007
G:Gliwice
146169:SERIAL NUMBER
2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 3KU = VNĚJŠÍ BARVA,VIZ SEZNAM BAREV V ÚVODĚ KATALOGU 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA AJT = PRO PŘÍPRAVU K MONTÁŽI BEZPEČNOSTNÍ SÍTĚ AV4 = DĚLENÉ ZADNÍ SEDADLO AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BF8 = ÚLOŽNÁ SCHRÁNKA,PŘEDNÍ SEDADLO,PRAVÉ BL5 = LIŠTA KRYCÍ DVEŘE VNITŘEK,STŘÍBRNÁ BLB = KRYCÍ LIŠTY PŘÍSTROJOVÉ DESKY,STŘÍBRNÁ BRG = IDENTIFIKAČNÍ KRITICKÝ BOD 2007 1/2 MR BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE C60 = KLIMATIZACE C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CT6 = PRO ITÁLII CT6 D75 = KLIKA ÚPLNÁ VNĚJŠÍ DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO DDH = ZRCADLO,ELEKTRICKÉ A VYTÁPĚNÉ,PRAVÉ,LEVÉ DDI = ZRCÁTKO,SESTAVA DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4Q = ENJOY E94 = KRYT ECA = KLÍČ FX3 = PROGRAM ELEKTRONICKÉ STABILITY FXB = POMĚR NÁPRAVY 3.65 FZ3 = PRO ZDOKONALENÝ ELEKTRONICKÝ PROGRAM STABILITY (STABILITA PŘÍVĚSU) G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K13 = POUŽÍVÁ SE S FILTREM PEVNÝM ČÁSTIC VE VÝFUKOVÉM SYSTÉMU K60 = ALTERNÁTOR,100AMP KC7 = ELEKTRICKÁ ZÁSUVKA,ZADNÍ SEDADLO KC8 = ZÁSUVKA,VÝSTUP POMOCNÉHO NAPÁJENÍ KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LHD = ŘÍZENÍ LEVÉ LPM = VZNĚTOVÝ MOTOR Z19DT MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR) N52 = VOLANT,TŘI PAPRSKY NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NR1 = PRO REDUKOVANOU DRÁHU HŘEBENOVÉ TYČE NT4 = EMISE,EEC 05 OHA = MÍSTNÍ GM Z EUROPE OHA P92 = KRYT,KOLO 16PALCOVÉ PROVEDENÍ CHAMPAGNE MR07 PHP = TEXTILNÍ ČALOUNĚNÍ,TABITA/ELBA QGF = PNEUMATIKY,205/55 R 16-91H QN1 = KOLO,DISKOVÉ,OCELOVÉ,61/2JX16 QQ5 = PRO VELKÉ NÁHRAD.KOLO R2L T96 = SVĚTLO DO MLHY PŘEDNÍ T9W = OBKLAD,VNITŘNÍ,TABITA TGT TM7 = BATERIE,60AH TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ TTB = OSVĚTLENÍ VNITŘNÍ,STŘEŠNÍ, ZADNÍ KOMFORTNÍ A DVOJITÉ ČTECÍ,3. ŘADA TTO = RÁDIO CHLADICÍ SYSTÉM U07 = HOUKAČKA,TROUBA U3B U55 U66 = REPRODUKTOR,7 U68 = INFORMAČNÍ POČÍTAČ UAJ = GRAFICKÉ INFORMACE - BARVA UCL = RÁDIO AM/FM STEREO,HLEDÁNÍ,DVD,NAVIGACE,ETR,TLUMENÍ UH0 = VÝSTRAHA BEZPEČNOSTNÍHO PÁSU,LH UJ3 UWA = PŘÍPRAVA PRO MOBILNÍ TELEFON,S OVLÁDÁNÍM HLASEM A SYSTÉMEM BLUETOOTH V2T = NOSIČ,ZAVAZADEL,STŘEŠNÍ,S PRÁŠKOVOU ÚPRAVOU V3D = NOSIČ ZAVAZADEL VOLNÝ STŘEŠNÍ,ČERNÝ V4M = VYBAVENÍ 5-STAR,SADA NCAP VFE = NÁRAZNÍK PŘEDNÍ A ZADNÍ,OCHRANNÝ VÝLISEK,BAREVNÝ VG9 = OCHRANNÍ VOSK VNF = ODPOJOVAČ BATERIE W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO WBG = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,GPS XA3 = OPEL XK4 = PRO ITÁLII Z0H = PRO ITÁLII Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ
Typ motoru: Z19DT
W0L:General Motors
A:Astra Platform
7:2007
G:Gliwice
Zdravím...jako další přírůstek do rodiny opláků bych touhle cestou rád proklepl i svoji ZafiruB VIN:W0L0AHM757G155966
Předem mockrát děkuji.
ZAFIRA B COSMO / 1.9CDTI / 2oo7 / DVD90NAVI / +MKJ by PepaS
- Frydex
REGISTRAČNÍ ČÍSLO: 86-XR-ZX Datum výroby: 20070619 Značka: Opel Vauxhall VIN: W0L0AHM757G155966 Kód modelu: 0QP75 Kód balení: LD6G
Typ motoru: Z19DT
Sériové číslo motoru: 5546158
W0L:General Motors
A:Astra Platform
7:2007
G:Gliwice
155966:SERIAL NUMBER
20S = BARVA STEHŮ,HVĚZDNĚ STŘÍBRNÁ 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 4AU = VNĚJŠÍ BARVA,VIZ SEZNAM BAREV V ÚVODĚ KATALOGU 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A14 = SKLO,BOČNÍ OKNO,ZADNÍ,ZBARVENÉ A23 = PŘEDNÍ SKLO,REFLEXIVNÍ TEPLO A33 = ELEKTRICKY ŘÍZENÉ OKNA,ZADNÍ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO A88 = OPĚRKA HLAVY,PŘEDNÍ SEDADLO,AKTIVNÍ AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AJT = PRO PŘÍPRAVU K MONTÁŽI BEZPEČNOSTNÍ SÍTĚ ANY = KOLEJNICE A VÁZACÍ ÚCHYTY PRO NÁKLAD AQ0 = OPĚRKA HLAVY,ZADNÍ SEDADLO,VINYLOVÝ POTAH,DVA,KRAJNÍ AV4 = DĚLENÉ ZADNÍ SEDADLO AWY = ZÁDRŽNÝ SYSTÉM ZADNÍ SEDADLO,RAMENNÍ,ZATAHOVÁNÍ,ODDĚLITELNÝ KOTVICÍ BOD BEZPEČNOSTNÍHO PÁSU AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY9 = OPĚRKA HLAVY,ZADNÍ,VINYL,STŘED B70 = KRYT PRAHU DVEŘÍ B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BA9 = CHLADNIČKA BF8 = ÚLOŽNÁ SCHRÁNKA,PŘEDNÍ SEDADLO,PRAVÉ BL5 = LIŠTA KRYCÍ DVEŘE VNITŘEK,STŘÍBRNÁ BLB = KRYCÍ LIŠTY PŘÍSTROJOVÉ DESKY,STŘÍBRNÁ BRG = IDENTIFIKAČNÍ KRITICKÝ BOD 2007 1/2 MR BW4 = S CHROMOVOU LIŠTOU BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE C68 = PRO ELEKTRONICKOU KLIMATIZACI C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CE1 = STÍRAČ,PŘEDNÍ,IMPULSOVÝ SYSTÉM CT5 = PRO HOLANDSKO CT5 D75 = KLIKA ÚPLNÁ VNĚJŠÍ DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO DD8 = PRO VNITŘNÍ ZRCÁTKO CITLIVÉ NA SVĚTLO DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4R = PRODEJNÍ BALÍK SADA-COSMO E94 = KRYT ECA = KLÍČ FXB = POMĚR NÁPRAVY 3.65 G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K13 = POUŽÍVÁ SE S FILTREM PEVNÝM ČÁSTIC VE VÝFUKOVÉM SYSTÉMU K34 = REGULÁTOR RYCHLOSTI K60 = ALTERNÁTOR,100AMP KC7 = ELEKTRICKÁ ZÁSUVKA,ZADNÍ SEDADLO KC8 = ZÁSUVKA,VÝSTUP POMOCNÉHO NAPÁJENÍ KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LHD = ŘÍZENÍ LEVÉ LPM = VZNĚTOVÝ MOTOR Z19DT MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR) N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NR1 = PRO REDUKOVANOU DRÁHU HŘEBENOVÉ TYČE NT4 = EMISE,EEC 05 OHB PXF = LEM,ALFA/VINYL QGF = PNEUMATIKY,205/55 R 16-91H QL5 = KOLO,VOZOVKA,HLINÍK,10 PŘÍČEK,61/2JX16 QQ5 = PRO VELKÉ NÁHRAD.KOLO R2L T2Q = REFLEKTORY,AUTOMATICKÉ ZAPÍNÁNÍ/VYPÍNÁNÍ T6K = PANEL VYBAVENÍ,VNITŘNÍ,VINYL T96 = SVĚTLO DO MLHY PŘEDNÍ T9S = SVÍTILNA ÚPLNÁ,VNITŘNÍ,PŘEDNÍ DVEŘE TM7 = BATERIE,60AH TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ TSQ = OSVĚTLENÍ INTERIÉRU DELUXE TTB = OSVĚTLENÍ VNITŘNÍ,STŘEŠNÍ, ZADNÍ KOMFORTNÍ A DVOJITÉ ČTECÍ,3. ŘADA TTO = RÁDIO CHLADICÍ SYSTÉM U07 = HOUKAČKA,TROUBA U3C U55 U66 = REPRODUKTOR,7 U68 = INFORMAČNÍ POČÍTAČ U71 = ANTÉNA,ÚPLNÁ,STŘECHA UAJ = GRAFICKÉ INFORMACE - BARVA UCL = RÁDIO AM/FM STEREO,HLEDÁNÍ,DVD,NAVIGACE,ETR,TLUMENÍ UEC = SNÍMAČ INDIKÁTOR AUTOMATICKÉ RECIRKULACE VZDUCHU UH0 = VÝSTRAHA BEZPEČNOSTNÍHO PÁSU,LH UJ3 V3E = DRŽÁK ZAVAZADEL VOLNÝ STŘEŠNÍ,STŘÍBRNÝ V4M = VYBAVENÍ 5-STAR,SADA NCAP VFE = NÁRAZNÍK PŘEDNÍ A ZADNÍ,OCHRANNÝ VÝLISEK,BAREVNÝ VG2 = OCHRANNÍ VOSK, VYNECHEJTE VGB = STŘEŠNÍ NOSIČ ZAVAZADEL,ELOXOVANÝ VK8 = DRŽÁK,BRÝLE VNF = ODPOJOVAČ BATERIE W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO WBG = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,GPS WFJ = ÚPRAVY VZNĚTOVÉHO MOTORU,ZÁVOD KAISERLAUTERN PRATOLA SERRA XA3 = OPEL XQ5 = PRO HOLANDSKO Y67 = POŽADUJE PŘI OSAZENÉM SERVISNÍM DISPLEJI Z0G = PRO HOLANDSKO Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ
Typ motoru: Z19DT
W0L:General Motors
A:Astra Platform
7:2007
G:Gliwice
- Radoš92
Prosím co nejrychlšji. spěchá, moc díky.
vin:W0L0TGF7522065716
VIN: W0L0TGF7522065716
W0L: General Motors
0: VOZIDLO BEZ ZVLÁŠTNÍ ÚPRAVY
T: Astra
G: Astra
F75: Zafira
2: 2002
2: Bochum
065716: SERIAL NUMBER
Kód modelu: 0QX75
Kód balení: KHS1
Datum výroby: 15.10.2001
Typ motoru: Z18XE
Sériové číslo motoru: 20W22194
Čalounění: XXEC
Výbava: 2AU = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ 2F4 = RÁDIO,CAR 500 2H9 = 18 BENZÍNOVÝ MOTOR 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A14 = SKLO,BOČNÍ OKNO,ZADNÍ,ZBARVENÉ A23 = PŘEDNÍ SKLO,REFLEXIVNÍ TEPLO A32 = ELEKTRICKY ŘÍZENÉ OKNA,PŘEDNÍ A33 = ELEKTRICKY ŘÍZENÉ OKNA,ZADNÍ A88 = OPĚRKA HLAVY,PŘEDNÍ SEDADLO,AKTIVNÍ AG4 = PŘEDNÍ SEDADLO,LEVÉ,REGULÁTOR VÝŠKY,RUČNÝ AJ3 = PRO BEZPEČNOSTNÍ VAK U ŘIDIČE AJ4 = PRO BEZPEČNOSTNÍ VAK AN4 = SEDADLO PRO DÍTĚ,OCHRANNÝ SYSTÉM AP0 = PRO BOČNÍ VZDUCHOVÝ POLŠTÁŘ,LEVÝ AP1 = PRO BOČNÍ VZDUCHOVÝ POLŠTÁŘ,PRAVÝ AP9 = SÍŹ NÁKLADOVÉHO PROSTORU AQ6 = PŘEDNÍ SEDADLO,NASTAVITELNÁ OPĚRKA AS1 = PRO SKLÁPECÍ PŘEDNÍ SEDADLO,PRAVÉ AT0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,CELÁ AU0 = ZÁMEK DVEŘÍ,S DÁLKOVÝM OVLÁDÁNÍM AY3 = OPĚRKA HLAVY,PŘEDNÍ,TEXTIL,CELÁ AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED B70 = KRYT PRAHU DVEŘÍ B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B76 = PRO PŘÍSTROJ S ČERNÝM CIFERNÍKEM BA8 = UKLÁDÁNÍ,PŘEDNÍ SEDADLO,PASAŽÉR BB7 = POUŽÍT S CHROMOVÝMI VNITŘNÍMI DVEŘNÍMI KLIKAMI C60 = KLIMATIZACE CL2 = PRO ČESKOU REPUBLIKU CS0 = PRO ČESKOU REPUBLIKU D44 = KRYT,POUZDRO NA ZRCADLO,STANA PASAŽÉRA,BARVENÉ DA5 = LOKETNÍ OPĚRKA,ZADNÍ,STŘED DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO DL8 = ZRCADLO,ELEKTRICKÉ A VYTÁPĚNÉ,PRAVÉ,LEVÉ G62 = 5 ŠROUB UPEVNĚNÍ KOLA GT6 = POMĚR NÁPRAVY 4.19 JL9 = ABS K60 = ALTERNÁTOR,100AMP KC5 = ZÁSUVKA,ELEKTRICKÉ PŘÍSLUŠENSTVÍ(12V) LHD = ŘÍZENÍ LEVÉ MG4 = RUČNÍ PŘEVODOVKA,5 RYCHLOSTNÍ,SPORTOVNÍ MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU N33 = PRO NASTAVITELNÝ SLOUPEK ŘÍZENÍ N40 = POSILOVAČ ŘÍZENÍ, BEZ PROMĚNNÉHO POMĚRU NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NP5 = VOLANT,KŮŽE NT4 = EMISE,EEC 05 OHC P34 = KOLO A PNEUMATIKA,NÁHRADNÍ QD9 = KOLO,VOZOVKA,HLINÍK,6 PAPRSKŮ,6JX15 QHL = PNEUMATIKY,195/65 R 15-91H T6V = PANEL VYBAVENÍ,VNITŘNÍ,S/LUX,VARIANT 2 T96 = SVĚTLO DO MLHY PŘEDNÍ TN6 = BATERIE,55AH U07 = HOUKAČKA,TROUBA U3F U55 UD0 = DĚTSKÁ SEDAČKA,DÁREK UJ3 UV5 = MULTI-FUNKČNÍ DISPLEJ,VAT3 UZ8 = REPRODUKTOR,8 BOSE V22 = MŘÍŽKA,CHLADIČ,CHRÓMOVÁ LIŠTA V55 = NOSNÍK STŘECHY VJ4 = VÝSTRAŽNÝ ŠTÍTEK, DĚTSKÉ SEDADLO W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y W6V = VYBAVENÍ,TEXTIL,S/LUX,VARIANT 2 W8X = DODATEČNÉ ČÁSTI, RÁDIO INSTALACE W9U = DINKS XA3 = OPEL XK5 = ZAŘÍZENÍ,ŠPERK XK7 = PÍSMO,BEAUTY XL8 = PRO FREKVENCI 433 MHZ XR2 = ŠTÍTEK,ELEGANCE Z1F = RYCHLOMĚR KM/H ZQ9 = VNĚJŠÍ VYBAVENÍ,ČERNÉ
W0L: General Motors
T: Astra
G: Astra
F75: Zafira
2: 2002
2: Bochum
Kód modelu: 0QX75
Kód balení: KHS1
Typ motoru: Z18XE
Čalounění: XXEC
- Radoš92
Díky moc. Asi bude taky zítra na dvoře. Sice ne moje, ale bude tu.
Ahoj, potreboval by som info o W0L0AHL48621664529. Dakujem
Ex: Opel Astra H, Z14XEP
Opel Astra H, Z16XEP Elegance
Pěkný den,
Smím se připojit se svou zafirkou? VIN: W0L0AHM758G062571
Děkuji předem za ochotu a strávený čas.
Nyní: Z-B, 1,9 CDTI/74 kW, Z19 DTL, r.v. 12/2007 (a Š-Felicia)
Dříve: Fiat 127, Š 105
OP-COM China 08/2010 v1.39 a 03/2012 fw 1.59 k dispozici.
Ahoj.
Připojil bych se také s žádostí o info.
VIN: W0L0AHM756G045391
Díky
Díky
