W0L0TGF485G033923 prosim o info, diky moc
							Opel Astra 1.7 CDTI 59kw, 5dv. hatchback. r.v.:2005
Motor: Z17DTL
						Motor: Z17DTL
VIN:   W0L0TGF485G033923
W0L: General Motors
0: VOZIDLO BEZ ZVLÁŠTNÍ ÚPRAVY
T: Astra
G: Astra
F48: 5-DV. SEDAN
5: 2005
G: Gliwice
033923: SERIAL NUMBER
Kód modelu: 0T 48
Kód balení: JF5G
Datum výroby: 13.11.2004
Typ motoru: Z17DTL
Sériové číslo motoru: 01161391
Čalounění: XXQF
Výbava: 2F4 = RÁDIO,CAR 500 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 78U = VNĚJŠÍ LAK, VIZ KATALOG MODELŮ, ÚVOD, TABULKA LAKŮ 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A23 = PŘEDNÍ SKLO,REFLEXIVNÍ TEPLO AJ3 = PRO BEZPEČNOSTNÍ VAK U ŘIDIČE AJ4 = PRO BEZPEČNOSTNÍ VAK AQ6 = PŘEDNÍ SEDADLO,NASTAVITELNÁ OPĚRKA AT0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,CELÁ AY3 = OPĚRKA HLAVY,PŘEDNÍ,TEXTIL,CELÁ AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED B76 = PRO PŘÍSTROJ S ČERNÝM CIFERNÍKEM C35 = OHŘÍVAČ,ZADNÍ ODDĚLENÍ C60 = KLIMATIZACE CL2 = PRO ČESKOU REPUBLIKU CS0 = PRO ČESKOU REPUBLIKU FP9 = POMĚR NÁPRAVY 3.55 G61 = 4 ŠROUB UPEVNĚNÍ KOLA GWP = VYROBENO V GLIWICÍCH JL9 = ABS K60 = ALTERNÁTOR,100AMP LHD = ŘÍZENÍ LEVÉ LRB = MOTOR Z17DTL[LRB] M79 = RUČNÍ PŘEVODOVKA,5 RYCHLOSTNÍ MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU N40 = POSILOVAČ ŘÍZENÍ, BEZ PROMĚNNÉHO POMĚRU NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NP5 = VOLANT,KŮŽE NT4 = EMISE,EEC 05 OHI = MÍSTNÍ GM Z EUROPE OHI P34 = KOLO A PNEUMATIKA,NÁHRADNÍ PBG = ČALOUNĚNÍ,ORLEANS/MALTA PG1 = KOLO,VOZOVKA,OCEL,6JX15 QED = PNEUMATIKY,195/60 R 15-88H T67 = BATERIE,70AH T96 = SVĚTLO DO MLHY PŘEDNÍ T9L = OBKLAD,VNITŘNÍ,MALTA U07 = HOUKAČKA,TROUBA U91 = ANTÉNA KRÁTKÁ,STŘEŠNÍ,RÁDIO U96 = REPRODUKTOR,6,VARIANT 2 UJ3 W2N = PÍSMO,LATERAL, VYNECHEJTE W4Y W8X = DODATEČNÉ ČÁSTI, RÁDIO INSTALACE XA3 = OPEL Y9V Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ Z1X = BARVA,JEDEN POVLAK
							W0L: General Motors
T: Astra
G: Astra
F48: 5-DV. SEDAN
5: 2005
G: Gliwice
Kód modelu: 0T 48
Kód balení: JF5G
Typ motoru: Z17DTL
Čalounění: XXQF
PRODÁNO: Opel Zafira B 1.9 CDTi 110kW (2006) Sport, Panorama, AFL Bi-xenon, Open&Start, CID+DVD90 CZ, Quick Heat, DDS, UHP, HSA, IDS+, DPF, MKJ,         Diagnostika OP-COM (Praha 4)
W0L0AHL3585019873 diky moc
							Opel Astra-H Caravan 1.6T (Z16LET) (2007)
				ilikezafiraB
Ahoj, mužu pořádat o info. Zajímá mě také zda mám filtr pevných částic. Podle kouřivosti 0.50 jsem usoudil že jo.
VIN:W0L0AHM757G074032
diky moc.
diky moc.
Opel Zafira B, 1.9 CDTi 88kW - r.v. 2007
				SoundBlaster
Ahoj, můžete se prosím mrknout i na můj?
Mé Astřiky VIN: W0L0AHL3582070509
SoundBlaster
SoundBlaster
2: pet007
VIN: W0L0AHL3585019873
W0L: General Motors
A: Astra Platform
H: 2004 Platform Generation
L35: Estate
8: 2008
5: Antwerp
019873: SERIAL NUMBER
Kód modelu: 0T 35
Kód balení: IA61
1.reg. značka: YY46610
Datum výroby: 21.9.2007
Typ motoru: Z16LET
Sériové číslo motoru: 20KV1139
Čalounění: XXVM
Výbava: 2HU = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 6Y4 = NÁHRADNÍ KOLO A PNEUMATIKA,VYNECHEJTE 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ 8V2 A14 = SKLO,BOČNÍ OKNO,ZADNÍ,ZBARVENÉ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO A88 = OPĚRKA HLAVY,PŘEDNÍ SEDADLO,AKTIVNÍ AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA AJT = PRO PŘÍPRAVU K MONTÁŽI BEZPEČNOSTNÍ SÍTĚ AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BNS = LIŠTA KRYCÍ DVEŘE VNITŘEK,SATÉNOVÁ STONE BPI = LIŠTA PŘÍSTROJOVÉ DESKY,SATÉNOVÁ STONE BS9 = TĚSNĚNÍ PRIMÁRNÍ,DVEŘE,SPODNÍ BW4 = S CHROMOVOU LIŠTOU C61 = SEMI-AUTOMATICKÁ KLIMATIZACE C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CE4 = OSTŘIKOVAČ SVĚTLOMETU CT7 = PRO DÁNSKO D75 = KLIKA ÚPLNÁ VNĚJŠÍ DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4Q = ENJOY E94 = KRYT ECA = KLÍČ FX1 = KONEČNÝ POHON NÁPRAVY 3.94 FX3 = PROGRAM ELEKTRONICKÉ STABILITY G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K09 = ALTERNÁTOR,120AMP K34 = REGULÁTOR RYCHLOSTI KA1 = PRO VYHŘÍVANÁ PŘEDNÍ SEDADLA KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LHD = ŘÍZENÍ LEVÉ LLU = Z16LET[LLU] BENZINOVÝ MOTOR MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU MZ0 = RUČNÍ PŘEVODOVKA,6RYCHLOSTNÍ (M32-6 WR) N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NS2 = PRO VARIABILNÍ POSILOVAČ ŘÍZENÍ NT4 = EMISE,EEC 05 OHA = MÍSTNÍ GM Z EUROPE OHA OMO P92 = KRYT,KOLO 16PALCOVÉ PROVEDENÍ CHAMPAGNE MR07 PHP = TEXTILNÍ ČALOUNĚNÍ,TABITA/ELBA QBE = PNEUMATIKY,205/55 R 16-89V QN1 = KOLO,DISKOVÉ,OCELOVÉ,61/2JX16 T61 = PRO SYSTÉM DENNÍCH SVĚTEL T9W = OBKLAD,VNITŘNÍ,TABITA TN6 = BATERIE,55AH TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ TTO = RÁDIO CHLADICÍ SYSTÉM U3F U66 = REPRODUKTOR,7 UAC = INFORMAČNÍ PANEL LCD - VÍCEFUNKČNÍ UJ3 V3E = DRŽÁK ZAVAZADEL VOLNÝ STŘEŠNÍ,STŘÍBRNÝ VG9 = OCHRANNÍ VOSK VGB = STŘEŠNÍ NOSIČ ZAVAZADEL,ELOXOVANÝ VIM = PŘÍPRAVA NA RÁDIO,BEZ TELEFONU S INTEGROVANÝM GPS/VC1/VC2/DAB VJU = STŘEDOVÝ PŘÍSTROJ NA PANELU,SATÉNOVÁ STONE W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y W7Z = ZAŘÍZENÍ,ZIMA WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO WTR = DOČASNÁ OPRAVA PNEUMATIKY XA3 = OPEL XL1 = PRO DÁNSKO Z0I = PRO DÁNSKO Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ
W0L: General Motors
A: Astra Platform
L35: Estate
8: 2008
5: Antwerp
Kód modelu: 0T 35
Kód balení: IA61
Typ motoru: Z16LET
Čalounění: XXVM
					Naposledy upravil(a) mach00 dne 18 kvě 2012, 20:07, celkem upraveno 1 x.
2: ilikezafiraB
VIN: W0L0AHM757G074032
W0L: General Motors
A: Astra Platform
M75: Monocab (Zafira)
7: 2007
G: Gliwice
074032: SERIAL NUMBER
Kód modelu: 0Q 75
Kód balení: LD61
1.reg. značka: 39157-019
Datum výroby: 8.1.2007
Typ motoru: Z19DT
Sériové číslo motoru: 5340907
Čalounění: XXVM
Výbava: 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 3KU = VNĚJŠÍ LAK, VIZ KATALOG MODELŮ, ÚVOD, TABULKA LAKŮ 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO A88 = OPĚRKA HLAVY,PŘEDNÍ SEDADLO,AKTIVNÍ AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA AJT = PRO PŘÍPRAVU K MONTÁŽI BEZPEČNOSTNÍ SÍTĚ ANY = KOLEJNICE A VÁZACÍ ÚCHYTY PRO NÁKLAD AV4 = DĚLENÉ ZADNÍ SEDADLO AWY = ZÁDRŽNÝ SYSTÉM ZADNÍ SEDADLO,RAMENNÍ,ZATAHOVÁNÍ,ODDĚLITELNÝ KOTVICÍ BOD BEZPEČNOSTNÍHO PÁSU AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BA9 = CHLADNIČKA BF8 = ÚLOŽNÁ SCHRÁNKA,PŘEDNÍ SEDADLO,PRAVÉ BL5 = LIŠTA KRYCÍ DVEŘE VNITŘEK,STŘÍBRNÁ BLB = KRYCÍ LIŠTY PŘÍSTROJOVÉ DESKY,STŘÍBRNÁ BRG = IDENTIFIKAČNÍ KRITICKÝ BOD 2007 1/2 MR BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE C68 = PRO ELEKTRONICKOU KLIMATIZACI C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CT1 = PRO BELGII D75 = KLIKA ÚPLNÁ VNĚJŠÍ D7F = PRO PŘIHRÁDKU SKLOPNOU DOZADU PŘEDNÍHO SEDADLA D7J = PLOCHÉ OPĚRADLO SEDADLA,SKLOPNÉ,RH DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4Q = ENJOY E94 = KRYT ECA = KLÍČ FXB = POMĚR NÁPRAVY 3.65 G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K13 = POUŽÍVÁ SE S FILTREM PEVNÝM ČÁSTIC VE VÝFUKOVÉM SYSTÉMU K34 = REGULÁTOR RYCHLOSTI K60 = ALTERNÁTOR,100AMP KC7 = ELEKTRICKÁ ZÁSUVKA,ZADNÍ SEDADLO KC8 = ZÁSUVKA,VÝSTUP POMOCNÉHO NAPÁJENÍ KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LHD = ŘÍZENÍ LEVÉ LPM = VZNĚTOVÝ MOTOR Z19DT[LPM] MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR) N52 = VOLANT,TŘI PAPRSKY NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NR1 = PRO REDUKOVANOU DRÁHU HŘEBENOVÉ TYČE NT4 = EMISE,EEC 05 OHA = MÍSTNÍ GM Z EUROPE OHA P92 = KRYT,KOLO 16PALCOVÉ PROVEDENÍ CHAMPAGNE MR07 PHP = TEXTILNÍ ČALOUNĚNÍ,TABITA/ELBA QGF = PNEUMATIKY,205/55 R 16-91H QN1 = KOLO,DISKOVÉ,OCELOVÉ,61/2JX16 QQ5 = PRO VELKÉ NÁHRAD.KOLO T9W = OBKLAD,VNITŘNÍ,TABITA TM7 = BATERIE,60AH TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ TTB = OSVĚTLENÍ VNITŘNÍ,STŘEŠNÍ, ZADNÍ KOMFORTNÍ A DVOJITÉ ČTECÍ,3. ŘADA U07 = HOUKAČKA,TROUBA U3C U55 U66 = REPRODUKTOR,7 U68 = INFORMAČNÍ POČÍTAČ U71 = ANTÉNA,ÚPLNÁ,STŘECHA UAH = DISPLEJ INFOTAINMENT,GRAFICKÝ INFORMAČNÍ DISPLEJ (GID),VAR2 UCH = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,ETR,TLUMENÍ,MP3 UEC = SNÍMAČ INDIKÁTOR AUTOMATICKÉ RECIRKULACE VZDUCHU UH0 = VÝSTRAHA BEZPEČNOSTNÍHO PÁSU,LH UJ3 V2T = NOSIČ,ZAVAZADEL,STŘEŠNÍ,S PRÁŠKOVOU ÚPRAVOU V3D = NOSIČ ZAVAZADEL VOLNÝ STŘEŠNÍ,ČERNÝ V4M = VYBAVENÍ 5-STAR,SADA NCAP VFE = NÁRAZNÍK PŘEDNÍ A ZADNÍ,OCHRANNÝ VÝLISEK,BAREVNÝ VG2 = OCHRANNÍ VOSK, VYNECHEJTE VNF = ODPOJOVAČ BATERIE VQ9 = ODMONTOVATELNÁ SPOJKA ZÁVLEKU W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO XA3 = OPEL XK1 = PRO BELGII Y67 = POŽADUJE PŘI OSAZENÉM SERVISNÍM DISPLEJI Z0D = PRO BELGII Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ
Filtr pevných částic (DPF) máš, viz kód výbavy K13
W0L: General Motors
A: Astra Platform
7: 2007
G: Gliwice
Kód modelu: 0Q 75
Kód balení: LD61
Typ motoru: Z19DT
Čalounění: XXVM
2: SoundBlaster
W0L: General Motors
A: Astra Platform
L35: Estate
8: 2008
2: Bochum
070509: SERIAL NUMBER
Kód modelu: 0T 35
Kód balení: JM58
1.reg. značka: DN353FL
Datum výroby: 16.11.2007
Typ motoru: Z17DTH
Sériové číslo motoru: 1720996
Čalounění: XXVM
Výbava: 2AU = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO AH3 = PŘEDNÍ SEDADLO,ŘIDIČ,RUČNÉ NASTAVENÍ AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA AJT = PRO PŘÍPRAVU K MONTÁŽI BEZPEČNOSTNÍ SÍTĚ AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BNS = LIŠTA KRYCÍ DVEŘE VNITŘEK,SATÉNOVÁ STONE BPI = LIŠTA PŘÍSTROJOVÉ DESKY,SATÉNOVÁ STONE C60 = KLIMATIZACE C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CT6 = PRO ITÁLII D75 = KLIKA ÚPLNÁ VNĚJŠÍ DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4Q = ENJOY E94 = KRYT ECA = KLÍČ FR7 = POMĚR NÁPRAVY 3.95 (PŘEDNÍ) FX3 = PROGRAM ELEKTRONICKÉ STABILITY G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K60 = ALTERNÁTOR,100AMP KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LHD = ŘÍZENÍ LEVÉ LPZ = VZNĚTOVÝ MOTOR Z17DTH[LPZ] MG1 = RUČNÍ PŘEVODOVKA,5 RYCHLOSTNÍ,F23 TYP MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU N52 = VOLANT,TŘI PAPRSKY N65 = PNEUMATIKA,NÁHRADNÍ,ÚSPORA PROSTORU NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NS2 = PRO VARIABILNÍ POSILOVAČ ŘÍZENÍ NT4 = EMISE,EEC 05 OHA = MÍSTNÍ GM Z EUROPE OHA P92 = KRYT,KOLO 16PALCOVÉ PROVEDENÍ CHAMPAGNE MR07 PHP = TEXTILNÍ ČALOUNĚNÍ,TABITA/ELBA QGF = PNEUMATIKY,205/55 R 16-91H QN1 = KOLO,DISKOVÉ,OCELOVÉ,61/2JX16 T96 = SVĚTLO DO MLHY PŘEDNÍ T9W = OBKLAD,VNITŘNÍ,TABITA TM7 = BATERIE,60AH TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ U07 = HOUKAČKA,TROUBA U3B UAC = INFORMAČNÍ PANEL LCD - VÍCEFUNKČNÍ UJ3 URA = SPÍNAČ OVLÁDÁNÍ RÁDIA UW5 = REPRODUKTOROVÝ SYSTÉM 6,BASE V2T = NOSIČ,ZAVAZADEL,STŘEŠNÍ,S PRÁŠKOVOU ÚPRAVOU V3D = NOSIČ ZAVAZADEL VOLNÝ STŘEŠNÍ,ČERNÝ VG9 = OCHRANNÍ VOSK VJU = STŘEDOVÝ PŘÍSTROJ NA PANELU,SATÉNOVÁ STONE W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO XA3 = OPEL XK4 = PRO ITÁLII Z0H = PRO ITÁLII Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ
W0L: General Motors
A: Astra Platform
L35: Estate
8: 2008
2: Bochum
Kód modelu: 0T 35
Kód balení: JM58
Typ motoru: Z17DTH
Čalounění: XXVM
						- BikerMarius
Ahoj copak má moje astřička  ?
VIN W0L0AHL3572055260
Dík
Dík
