W0L0AHL3582113300
Pánové, můžu poprosit? Děkuju
W0L0AHL3582113300
W0L0AHL3582113300
Prodáno... Co bude dál? Netuším...
Honz@:
VIN: W0L0AHL3582113300
Kód modelu: 0TN35
Kód balení: JM58
REGISTRAČNÍ ČÍSLO: DP912FW
Datum výroby: 20080131
Typ motoru: Z17DTH
Sériové číslo motoru: 1754165
Kód řízení GM*: XXVM
W0L:General Motors
0:VOZIDLO BEZ ZVLÁSTNÍ ÚPRAVY
A:Astra Platform
H:2004 Platform Generation
L35:Estate
8:2008
2:Bochum
113300:SERIAL NUMBER
10U = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO AH3 = PŘEDNÍ SEDADLO,ŘIDIČ,RUČNÉ NASTAVENÍ AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA AJT = PRO PŘÍPRAVU K MONTÁŽI BEZPEČNOSTNÍ SÍTĚ ALR AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BNS = LIŠTA KRYCÍ DVEŘE VNITŘEK,SATÉNOVÁ STONE BPI = LIŠTA PŘÍSTROJOVÉ DESKY,SATÉNOVÁ STONE BRL = IDENTIFIKAČNÍ KRITICKÝ BOD MR 2008 1/2 C60 = KLIMATIZACE C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CT6 = PRO ITÁLII D75 = KLIKA ÚPLNÁ VNĚJŠÍ DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4Q = ENJOY E94 = KRYT ECA = KLÍČ FR7 = POMĚR NÁPRAVY 3.95 (PŘEDNÍ) FX3 = PROGRAM ELEKTRONICKÉ STABILITY G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K60 = ALTERNÁTOR,100AMP KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LHD = ŘÍZENÍ LEVÉ LPZ = VZNĚTOVÝ MOTOR Z17DTH MG1 = RUČNÍ PŘEVODOVKA,5 RYCHLOSTNÍ,F23 TYP MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU N52 = VOLANT,TŘI PAPRSKY N65 = PNEUMATIKA,NÁHRADNÍ,ÚSPORA PROSTORU NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NS2 = PRO VARIABILNÍ POSILOVAČ ŘÍZENÍ NT4 = EMISE,EEC 05 OHA = MÍSTNÍ GM Z EUROPE OHA P92 = KRYT,KOLO 16PALCOVÉ PROVEDENÍ CHAMPAGNE MR07 PHP = TEXTILNÍ ČALOUNĚNÍ,TABITA/ELBA QGF = PNEUMATIKY,205/55 R 16-91H QN1 = KOLO,DISKOVÉ,OCELOVÉ,61/2JX16 T96 = SVĚTLO DO MLHY PŘEDNÍ T9M = ČALOUNĚNÍ ELBA TM7 = BATERIE,60AH TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ U07 = HOUKAČKA,TROUBA U3B UAC = INFORMAČNÍ PANEL LCD - VÍCEFUNKČNÍ UJ3 URA = SPÍNAČ OVLÁDÁNÍ RÁDIA UW5 = REPRODUKTOROVÝ SYSTÉM 6,BASE V2T = NOSIČ,ZAVAZADEL,STŘEŠNÍ,S PRÁŠKOVOU ÚPRAVOU V3D = NOSIČ ZAVAZADEL VOLNÝ STŘEŠNÍ,ČERNÝ VG9 = OCHRANNÍ VOSK VJU = STŘEDOVÝ PŘÍSTROJ NA PANELU,SATÉNOVÁ STONE W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO XA3 = OPEL XK4 = PRO ITÁLII Z0H = PRO ITÁLII Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ
Kód modelu: 0TN35
Kód balení: JM58
Typ motoru: Z17DTH
W0L:General Motors
A:Astra Platform
L35:Estate
8:2008
2:Bochum
Ahoj, rad bych take pozadal o blizsi info o svem vozidle.
VIN: W0L0AHM759G015786
Diky
Diky
Zafira B 1.8 16V
Kód modelu: 0QN75
Kód balení: KD51
Datum výroby: 20080917
Typ motoru: Z18XER
Sériové číslo motoru: 20MD0486
W0L:General Motors
A:Astra Platform
M75:Monocab (Zafira)
9:2009
G:Gliwice
015786:SERIAL NUMBER
2H0 = MOTOR BENZINOVÝ C18SEL,Z18XER,A18XER 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 4AU = VNĚJŠÍ BARVA,VIZ SEZNAM BAREV V ÚVODĚ KATALOGU 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A14 = SKLO,BOČNÍ OKNO,ZADNÍ,ZBARVENÉ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA ANY = KOLEJNICE A VÁZACÍ ÚCHYTY PRO NÁKLAD AQ2 = SÍŤ KOMFORTNÍ AV4 = DĚLENÉ ZADNÍ SEDADLO AWY = ZÁDRŽNÝ SYSTÉM ZADNÍ SEDADLO,RAMENNÍ,ZATAHOVÁNÍ,ODDĚLITELNÝ KOTVICÍ BOD BEZPEČNOSTNÍHO PÁSU AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BF8 = ÚLOŽNÁ SCHRÁNKA,PŘEDNÍ SEDADLO,PRAVÉ BNS = LIŠTA KRYCÍ DVEŘE VNITŘEK,SATÉNOVÁ STONE BPI = LIŠTA PŘÍSTROJOVÉ DESKY,SATÉNOVÁ STONE BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE C68 = PRO ELEKTRONICKOU KLIMATIZACI C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CE1 = STÍRAČ,PŘEDNÍ,IMPULSOVÝ SYSTÉM CE4 = OSTŘIKOVAČ SVĚTLOMETU CR7 = PRO MAĎARSKO D75 = KLIKA ÚPLNÁ VNĚJŠÍ D7F = PRO PŘIHRÁDKU SKLOPNOU DOZADU PŘEDNÍHO SEDADLA D7J = PLOCHÉ OPĚRADLO SEDADLA,SKLOPNÉ,RH DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO DD8 = PRO VNITŘNÍ ZRCÁTKO CITLIVÉ NA SVĚTLO DDH = ZRCADLO,ELEKTRICKÉ A VYTÁPĚNÉ,PRAVÉ,LEVÉ DDI = ZRCÁTKO,SESTAVA DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4Q = ENJOY E94 = KRYT ECA = KLÍČ FX1 = KONEČNÝ POHON NÁPRAVY 3.94 FX3 = PROGRAM ELEKTRONICKÉ STABILITY FZ3 = PRO ZDOKONALENÝ ELEKTRONICKÝ PROGRAM STABILITY (STABILITA PŘÍVĚSU) G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K60 = ALTERNÁTOR,100AMP KA1 = PRO VYHŘÍVANÁ PŘEDNÍ SEDADLA KC7 = ELEKTRICKÁ ZÁSUVKA,ZADNÍ SEDADLO KC8 = ZÁSUVKA,VÝSTUP POMOCNÉHO NAPÁJENÍ KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA KCN = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 3.POLOHA LHD = ŘÍZENÍ LEVÉ M25 = RUČNÍ PŘEVODOVKA,5 RYCHLOSTNÍ,F17 TYP MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NR1 = PRO REDUKOVANOU DRÁHU HŘEBENOVÉ TYČE NT4 = EMISE,EEC 05 NZX = KRYT,KOLO OHA = MÍSTNÍ GM Z EUROPE OHA PHP = TEXTILNÍ ČALOUNĚNÍ,TABITA/ELBA QGF = PNEUMATIKY,205/55 R 16-91H QN1 = KOLO,DISKOVÉ,OCELOVÉ,61/2JX16 QQ5 = PRO VELKÉ NÁHRAD.KOLO T2Q = REFLEKTORY,AUTOMATICKÉ ZAPÍNÁNÍ/VYPÍNÁNÍ T96 = SVĚTLO DO MLHY PŘEDNÍ T9M = ČALOUNĚNÍ ELBA TN6 = BATERIE,55AH TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ TSQ = OSVĚTLENÍ INTERIÉRU DELUXE TT2 = SVĚTLOMETY SMĚROVÉ,VYSOKÁ INTENZITA VÝBOJKA,TLUMENÉ XENONOVÉ,DÁLKOVÉ XENONOVÉ/HALOGENOVÉ TTB = OSVĚTLENÍ VNITŘNÍ,STŘEŠNÍ, ZADNÍ KOMFORTNÍ A DVOJITÉ ČTECÍ,3. ŘADA TTX = PRO POMOCNÝ KONEKTOR RÁDIA U3F U66 = REPRODUKTOR,7 UAG = GRAFICKÁ INFORMACE - JEDNOBAREVNÁ UCH = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,ETR,TLUMENÍ,MP3 UJ3 V3E = DRŽÁK ZAVAZADEL VOLNÝ STŘEŠNÍ,STŘÍBRNÝ VG9 = OCHRANNÍ VOSK VGB = STŘEŠNÍ NOSIČ ZAVAZADEL,ELOXOVANÝ VJU = STŘEDOVÝ PŘÍSTROJ NA PANELU,SATÉNOVÁ STONE W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y W5T = ODZNAK MOTORU,VYNECHÁN W7Z = ZAŘÍZENÍ,ZIMA WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO XA3 = OPEL XB2 = PRO MAĎARSKO XJ9 = PRO MAĎARSKO Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ Z1O = PRO MAĎARSKO
Kód modelu: 0QN75
Kód balení: KD51
Typ motoru: Z18XER
W0L:General Motors
A:Astra Platform
9:2009
G:Gliwice
- blue_phantas
Ahojte, mohol by som Vas poprosit o info:
Dakujem!
Dakujem!
Naposledy upravil(a) blue_phantas dne 18 kvě 2011, 09:55, celkem upraveno 1 x.
Opel Astra Caravan, 2007, 1.9CDTI, 88kw, 130000km
- Mike.S
W0L:General Motors
A:Astra Platform
L35:Estate
7:2007
2:Bochum
086218:SERIAL NUMBER
vyrobena: 6.12.2006
první RZ: DD064JZ
motor: Z19DT
č.motoru: 5300267
čalounění: XXVX
výbava:
20S = BARVA STEHŮ,HVĚZDNĚ STŘÍBRNÁ 2HU = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A14 = SKLO,BOČNÍ OKNO,ZADNÍ,ZBARVENÉ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AQ0 = OPĚRKA HLAVY,ZADNÍ SEDADLO,VINYLOVÝ POTAH,DVA,KRAJNÍ AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY9 = OPĚRKA HLAVY,ZADNÍ,VINYL,STŘED B70 = KRYT PRAHU DVEŘÍ B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BL5 = LIŠTA KRYCÍ DVEŘE VNITŘEK,STŘÍBRNÁ BLB = KRYCÍ LIŠTY PŘÍSTROJOVÉ DESKY,STŘÍBRNÁ BS7 = TĚSNĚNÍ PRIMÁRNÍ,DVEŘE,DVĚ BARVY BS9 = TĚSNĚNÍ PRIMÁRNÍ,DVEŘE,SPODNÍ BW4 = S CHROMOVOU LIŠTOU C61 = SEMI-AUTOMATICKÁ KLIMATIZACE C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CT6 = PRO ITÁLII D75 = KLIKA ÚPLNÁ VNĚJŠÍ DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4R = PRODEJNÍ BALÍK SADA-COSMO E94 = KRYT ECA = KLÍČ FX3 = PROGRAM ELEKTRONICKÉ STABILITY FXB = POMĚR NÁPRAVY 3.65 G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K60 = ALTERNÁTOR,100AMP KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LHD = ŘÍZENÍ LEVÉ LPM = VZNĚTOVÝ MOTOR Z19DT MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR) N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM N65 = PNEUMATIKA,NÁHRADNÍ,ÚSPORA PROSTORU NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NR1 = PRO REDUKOVANOU DRÁHU HŘEBENOVÉ TYČE NT4 = EMISE,EEC 05 OHB OMO PXF = LEM,ALFA/VINYL QGF = PNEUMATIKY,205/55 R 16-91H QL5 = KOLO,VOZOVKA,HLINÍK,10 PŘÍČEK,61/2JX16 T6K = PANEL VYBAVENÍ,VNITŘNÍ,VINYL T96 = SVĚTLO DO MLHY PŘEDNÍ T9S = SVÍTILNA ÚPLNÁ,VNITŘNÍ,PŘEDNÍ DVEŘE TM7 = BATERIE,60AH TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ TTO = RÁDIO CHLADICÍ SYSTÉM U07 = HOUKAČKA,TROUBA U3B U55 U68 = INFORMAČNÍ POČÍTAČ UAC = INFORMAČNÍ PANEL LCD - VÍCEFUNKČNÍ UJ3 UJC = SPÍNAČ SPORTOVNÍ REŽIM URA = SPÍNAČ OVLÁDÁNÍ RÁDIA UW6 = REPRODUKTOR,6 V2T = NOSIČ,ZAVAZADEL,STŘEŠNÍ,S PRÁŠKOVOU ÚPRAVOU V3E = DRŽÁK ZAVAZADEL VOLNÝ STŘEŠNÍ,STŘÍBRNÝ VDR VG9 = OCHRANNÍ VOSK VK8 = DRŽÁK,BRÝLE VNF = ODPOJOVAČ BATERIE W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO WFB = NOVÁ ŘÍDICÍ JEDNOTKA XA3 = OPEL XJ2 = NIŽŠÍ SPORTOVNÍ PODVOZEK XK4 = PRO ITÁLII Z0H = PRO ITÁLII Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ ZQ8 = UŽITO SPOLU SE SPORTOVNÍM PODVOZKEM
A:Astra Platform
L35:Estate
7:2007
2:Bochum
vyrobena: 6.12.2006
první RZ: DD064JZ
motor: Z19DT
č.motoru: 5300267
čalounění: XXVX
výbava:
Old cars:
Škoda 120L
Škoda Felicia Combi LXi
Actual car:
Škoda 120L
Actual car:
Zdravim, taky prosim rozespat
W0L0AHL0865155774
Diky
W0L0AHL0865155774
Diky
VIN: W0L0AHL0865155774
W0L: General Motors
0: VOZIDLO BEZ ZVLÁSTNÍ ÚPRAVY
A: Astra Platform
H: 2004 Platform Generation
L08: 3-DV. SEDAN
6: 2006
5: Antwerp
155774: SERIAL NUMBER
Kód modelu: 0TO08
Kód balení: MC65
REGISTRAČNÍ ČÍSLO: 139YE71
Datum výroby: 24.3.2006
Typ motoru: Z20LEH
Sériové číslo motoru: 31003957
Kód řízení GM*: XXOP
20S = BARVA STEHŮ,HVĚZDNĚ STŘÍBRNÁ 2HU = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 46X = BARVA ČALOUNĚNÍ SEDADLA BARVA STŘÍBRNÁ/UHLOVÁ 6Y4 = NÁHRADNÍ KOLO A PNEUMATIKA,VYNECHEJTE 80I = VNITŘEK-ČERNÝ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ 8V2 A88 = OPĚRKA HLAVY,PŘEDNÍ SEDADLO,AKTIVNÍ AG6 = PRO SEDADLO SE ČTYŘCESTNÝM RUČNÍM REGULÁTOREM AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ AQ0 = OPĚRKA HLAVY,ZADNÍ SEDADLO,VINYLOVÝ POTAH,DVA,KRAJNÍ AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY9 = OPĚRKA HLAVY,ZADNÍ,VINYL,STŘED B2G = OPC B4W = DEKORACE VNITŘNÍ PROSTOR,ČALOUNĚNÍ STROPU,UHLOVÉ B56 = LIŠTA KYVADLOVÁ KAROSÉRIE BARVA B58 = KRYCÍ PODLAHOVÉ ROHOŽKY,PŘEDNÍ A ZADNÍ KOBERCOVÁ VLOŽKA B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BA9 = CHLADNIČKA BD8 = LIŠTA,CELK.,STŘEŠNÍ,V BARVĚ KAROSERIE BLZ = DVEŘNÍ KRYCÍ LIŠTA VNITŘEK,ČERNÁ MAZE BNX = LIŠTA PŘÍSTROJOVÉ DESKY VNITŘNÍ, ČERNÁ MAZE BRE = IDENTIFIKAČNÍ KRITICKÝ BOD 2006 1/2 MR BS9 = TĚSNĚNÍ PRIMÁRNÍ,DVEŘE,SPODNÍ BW4 = S CHROMOVOU LIŠTOU BX4 = LIŠTA KRYCÍ BOKU C68 = PRO ELEKTRONICKOU KLIMATIZACI C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CE1 = STÍRAČ,PŘEDNÍ,IMPULSOVÝ SYSTÉM CE4 = OSTŘIKOVAČ SVĚTLOMETU CU3 = PRO FRANCII D75 = KLIKA ÚPLNÁ VNĚJŠÍ DD8 = PRO VNITŘNÍ ZRCÁTKO CITLIVÉ NA SVĚTLO DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DGZ = SCHRÁNKA V PŘÍSTROJOVÉ DESCE DĚLÍCÍ PŘEPÁŽKA DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) DVC = VLOŽKA,ČERNÁ,CHROMOVANÉ KROUŽKY,MODRÁ RUČIČKA ECA = KLÍČ FE4 = SYSTÉM PRO SPECIÁLNÍ JÍZDU A JÍZDNÍ VLASTNOSTI (IDS+) FW7 = POMĚR NÁPRAVY 3.83 FX3 = PROGRAM ELEKTRONICKÉ STABILITY G62 = 5 ŠROUB UPEVNĚNÍ KOLA JF5 = POUŽITO SPOLU S PEDÁLEM SPORT ZE SLITINY JL9 = ABS K09 = ALTERNÁTOR,120AMP K34 = REGULÁTOR RYCHLOSTI KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LHD = ŘÍZENÍ LEVÉ LPI = BENZINOVÝ MOTOR Z20LEH MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU MZ0 = RUČNÍ PŘEVODOVKA,6RYCHLOSTNÍ (M32-6 WR) N55 = VOLANT, TROJPŘÍČKOVÝ, KOŽENÝ NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NS1 = PRO REDUKOVANOU DRÁHU HŘEBENOVÉ TYČE NT4 = EMISE,EEC 05 OHE PAB = LEM,DRÁŽKA/KŮŽE QPA = PRO POUŽITÍ S PNEUMATIKAMI 225/40ZR18-92Y QU7 = KOLO 18X8, HLINÍK, SPORTOVNÍ, 6 PLOCHÝCH PAPRSKŮ, TROJÚHELNÍKOVÉ OTVORY T2Q = REFLEKTORY,AUTOMATICKÉ ZAPÍNÁNÍ/VYPÍNÁNÍ T56 = SPOJLER ZADNÍ, STŘEŠNÍ,SPORT T6K = PANEL VYBAVENÍ,VNITŘNÍ,VINYL T96 = SVĚTLO DO MLHY PŘEDNÍ T9S = SVÍTILNA ÚPLNÁ,VNITŘNÍ,PŘEDNÍ DVEŘE TN6 = BATERIE,55AH TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRC = MŘÍŽKA CHLADIČE,ČERNÁ,S BAREVNOU TYČÍ (VOŠTINY) TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSQ = OSVĚTLENÍ INTERIÉRU DELUXE TT2 = SVĚTLOMETY SMĚROVÉ,VYSOKÁ INTENZITA VÝBOJKA,TLUMENÉ XENONOVÉ,DÁLKOVÉ XENONOVÉ/HALOGENOVÉ U07 = HOUKAČKA,TROUBA U3D U55 U68 = INFORMAČNÍ POČÍTAČ UAH = DISPLEJ INFOTAINMENT,GRAFICKÝ INFORMAČNÍ DISPLEJ (GID),VAR2 UEC = SNÍMAČ INDIKÁTOR AUTOMATICKÉ RECIRKULACE VZDUCHU UEQ = ODPOJOVAČ AKUMULÁTORU UJ3 UJC = SPÍNAČ SPORTOVNÍ REŽIM URA = SPÍNAČ OVLÁDÁNÍ RÁDIA UW5 = REPRODUKTOROVÝ SYSTÉM 6,BASE VG9 = OCHRANNÍ VOSK VK8 = DRŽÁK,BRÝLE VQA = NÁRAZNÍK PŘEDNÍ A ZADNÍ,SPORTOVNÍ,STYLOVÝ (VOŠTINY) VU2 = STŘEDOVÝ PŘÍSTROJ NA PANELU,CHROMOVANÁ MATT VYE = HLAVICE ŘADICÍ PÁKY,KOŽENÁ,SPORTOVNÍ W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W2E = PŘEDNÍ SEDADLA,RECARO W4Y W5B = OPC / VXR W5T = ODZNAK MOTORU,VYNECHÁN WBA = "OPC" WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO WTR = DOČASNÁ OPRAVA PNEUMATIKY XA3 = OPEL XJ3 = PODVOZEK OCP/VXR XK2 = PRO FRANCII Z0W = PRO FRANCII Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ ZQ8 = UŽITO SPOLU SE SPORTOVNÍM PODVOZKEM
W0L: General Motors
A: Astra Platform
L08: 3-DV. SEDAN
6: 2006
5: Antwerp
Kód modelu: 0TO08
Kód balení: MC65
Typ motoru: Z20LEH
poprosím o kat. číslo prípadne cenu plniaceho a výpustného ventilu klími na astru H,r.v. 2005, 1,7 dth.
A ak sa mení aj nejaké tesnenie tak aj to.
Diki
Diki
Opel Astra H Caravan 1.7CDTI 74 kw Z17DTH r.v.2005
Opel Astra G Caravan 1.7
