Astra H Caravan OPC, 1.9 CDTI 110KW, Z19DTH (2007)
nlibor
Příspěvek od nlibor » 21 bře 2011, 21:26
tak jsem konečně vyměnil Géčko 3.dv za Háčko Caravan OPC, 1.9 CDTI 110KW, Z19DTH (2007)
W0L:General Motors
A:Astra Platform
H:2004 Platform Generation
L35:Estate
7:2007
5:Antwerp
152242:SERIAL NUMBER
vyrobena: 21.3.2007
první RZ: L-LD 6130
čalounění: XXLO
motor: Z19DTH
č.motoru: 17235127
výbava:
2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ
3KU = VNĚJŠÍ BARVA,VIZ SEZNAM BAREV V ÚVODĚ KATALOGU
6Y4 = NÁHRADNÍ KOLO A PNEUMATIKA,VYNECHEJTE
80I = VNITŘEK-ČERNÝ
80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ
80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ
8V2
A14 = SKLO,BOČNÍ OKNO,ZADNÍ,ZBARVENÉ
A33 = ELEKTRICKY ŘÍZENÉ OKNA,ZADNÍ
A53 = PŘEDNÍ SEDADLO,LEVÉ/PRAVÉ,REGULÁTOR VÝŠKY,RUČNÝ
A88 = OPĚRKA HLAVY,PŘEDNÍ SEDADLO,AKTIVNÍ
AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ
AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE
AHB = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE
AHC = PRO RUČNÍ PRODLOUŽENÍ POLŠTÁŘE
AJT = PRO PŘÍPRAVU K MONTÁŽI BEZPEČNOSTNÍ SÍTĚ
ANY = KOLEJNICE A VÁZACÍ ÚCHYTY PRO NÁKLAD
AP9 = SÍŹ NÁKLADOVÉHO PROSTORU
AQ0 = OPĚRKA HLAVY,ZADNÍ SEDADLO,VINYLOVÝ POTAH,DVA,KRAJNÍ
AQ2 = SÍŤ KOMFORTNÍ
AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ
AY9 = OPĚRKA HLAVY,ZADNÍ,VINYL,STŘED
B56 = LIŠTA KYVADLOVÁ KAROSÉRIE BARVA
B70 = KRYT PRAHU DVEŘÍ
B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ
B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ
BA9 = CHLADNIČKA
BLE = LIŠTA KRYCÍ DVEŘE VNITŘEK,CHROMOVÁ MATT
BLG = LIŠTA PŘÍSTROJOVÉ DESKY VNITŘNÍ,CHROM MATT
BPF = PŘÍPRAVA V NÁRAZNÍKU VPŘEDU,SPODNÍ HRANA SPOJLERU
BPG = PŘÍPRAVA V NÁRAZNÍKU VZADU,SPODNÍ HRANA SPOJLERU
BRG = IDENTIFIKAČNÍ KRITICKÝ BOD 2007 1/2 MR
BS7 = TĚSNĚNÍ PRIMÁRNÍ,DVEŘE,DVĚ BARVY
BS9 = TĚSNĚNÍ PRIMÁRNÍ,DVEŘE,SPODNÍ
BW4 = S CHROMOVOU LIŠTOU
BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE
C32 = PRO SYSTÉM QUICKHEAT
C68 = PRO ELEKTRONICKOU KLIMATIZACI
C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU
CE1 = STÍRAČ,PŘEDNÍ,IMPULSOVÝ SYSTÉM
CE4 = OSTŘIKOVAČ SVĚTLOMETU
CT3 = PRO NĚMECKO
D18 = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,CHROMOVANÉ KRUHY
D75 = KLIKA ÚPLNÁ VNĚJŠÍ
DD8 = PRO VNITŘNÍ ZRCÁTKO CITLIVÉ NA SVĚTLO
DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ
DDU = ZRCÁTKO,SESTAVA
DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ
DP6 = TĚLESO
DT4 = POPELNÍK A ZAPALOVAČ CIGARET
E94 = KRYT
ECA = KLÍČ
FE4 = SYSTÉM PRO SPECIÁLNÍ JÍZDU A JÍZDNÍ VLASTNOSTI (IDS+)
FX3 = PROGRAM ELEKTRONICKÉ STABILITY
FXB = POMĚR NÁPRAVY 3.65
G62 = 5 ŠROUB UPEVNĚNÍ KOLA
JF5 = POUŽITO SPOLU S PEDÁLEM SPORT ZE SLITINY
JL9 = ABS
K13 = POUŽÍVÁ SE S FILTREM PEVNÝM ČÁSTIC VE VÝFUKOVÉM SYSTÉMU
K34 = REGULÁTOR RYCHLOSTI
KA1 = PRO VYHŘÍVANÁ PŘEDNÍ SEDADLA
KB5 = ASISTENT ROZJEZDU DO KOPCE
KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA
KG9 = ALTERNÁTOR,140A
LHD = ŘÍZENÍ LEVÉ
LRD = VZNĚTOVÝ MOTOR Z19DTH
MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU
MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR)
N35 = VOLANT,SPORT,KŮŽE
NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE
NS1 = PRO REDUKOVANOU DRÁHU HŘEBENOVÉ TYČE
NT4 = EMISE,EEC 05
OBM
OHC
OMO
P33 = KOLO,VOZOVKA,HLINÍK,11 PŘÍČEK,71/2JX18
PAO = LEM,KOŽENÝ MONDIAL
QNA = PNEUMATIKY,225/40 R 18-92W
R2L
T2Q = REFLEKTORY,AUTOMATICKÉ ZAPÍNÁNÍ/VYPÍNÁNÍ
T56 = SPOJLER ZADNÍ, STŘEŠNÍ,SPORT
T67 = BATERIE,70AH
T6K = PANEL VYBAVENÍ,VNITŘNÍ,VINYL
T96 = SVĚTLO DO MLHY PŘEDNÍ
T9P = DEKORACE TMAVÁ,TĚLESO SVĚTLOMETU
T9S = SVÍTILNA ÚPLNÁ,VNITŘNÍ,PŘEDNÍ DVEŘE
TGR
TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ
TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ
TRP = RÁMEČEK,RADIOPŘIJÍMAČ
TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ
TSQ
TT2 = SVĚTLOMETY SMĚROVÉ,VYSOKÁ INTENZITA VÝBOJKA,TLUMENÉ XENONOVÉ,DÁLKOVÉ XENONOVÉ/HALOGENOVÉ
TTO = RÁDIO CHLADICÍ SYSTÉM
U07 = HOUKAČKA,TROUBA
U3A
U55
U66 = REPRODUKTOR,7
U68 = INFORMAČNÍ POČÍTAČ
UAJ = GRAFICKÉ INFORMACE - BARVA
UCL = RÁDIO AM/FM STEREO,HLEDÁNÍ,DVD,NAVIGACE,ETR,TLUMENÍ
UD7 = ČIDLO PARKOVACÍHO SYSTÉMU
UEC = SNÍMAČ INDIKÁTOR AUTOMATICKÉ RECIRKULACE VZDUCHU
UJ3
UJ9 = INDIKÁTOR PODHUŠTĚNÍ PNEUMATIKY
UJC = SPÍNAČ SPORTOVNÍ REŽIM
UWA = PŘÍPRAVA PRO MOBILNÍ TELEFON,S OVLÁDÁNÍM HLASEM A SYSTÉMEM BLUETOOTH
V3E = DRŽÁK ZAVAZADEL VOLNÝ STŘEŠNÍ,STŘÍBRNÝ
VDR
VG2 = OCHRANNÍ VOSK, VYNECHEJTE
VGB = STŘEŠNÍ NOSIČ ZAVAZADEL,ELOXOVANÝ
VK8 = DRŽÁK,BRÝLE
VNF = ODPOJOVAČ BATERIE
VQ9 = ODMONTOVATELNÁ SPOJKA ZÁVLEKU
VU2 = STŘEDOVÝ PŘÍSTROJ NA PANELU,CHROMOVANÁ MATT
W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU
W2E = PŘEDNÍ SEDADLA,RECARO
W34 = OPC LINE
W4Y
W7P = ŠTÍTEK,SPORT
WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO
WBG = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,GPS
WBP = PRODEJNÍ KAMPAŇ
WTR = DOČASNÁ OPRAVA PNEUMATIKY
XA3 = OPEL
XG3 = PRO NĚMECKO
XJ2 = NIŽŠÍ SPORTOVNÍ PODVOZEK
Y67 = POŽADUJE PŘI OSAZENÉM SERVISNÍM DISPLEJI
Z0F = PRO NĚMECKO
Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ
ZQ8 = UŽITO SPOLU SE SPORTOVNÍM PODVOZKEM
Naposledy upravil(a) nlibor dne 03 dub 2011, 23:00, celkem upraveno 1 x.
Re: Astra H Caravan OPC, 1.9 CDTI 110KW, Z19DTH (2007)
Příspěvek od Samothe » 21 bře 2011, 21:29
OPC line vždy vypadal luxusně,tak ať hlavně dobře slouží 8-)
nikos83
Příspěvek od nikos83 » 21 bře 2011, 21:33
vitaj a vela stastnych km ;)
Příspěvek od Midzi » 21 bře 2011, 21:35
no hura konecne, ako to prebiehalo?
nlibor
Příspěvek od nlibor » 21 bře 2011, 21:45
Midzi píše:no hura konecne, ako to prebiehalo?
ráno vyzvednout v OV, pak odhlásit v Opavě, přihlášení v Rožnově, odpoledne k servisákovi na TECH 2. Výpis bez závad :D
nlibor
Příspěvek od nlibor » 23 bře 2011, 22:44
můžete mi prosím poradit jaké je přesné označení žárovek do níže uvedených světel?
Příspěvek od swabel » 24 bře 2011, 09:01
Vsetko najdes v tomto Osram katalogu:
http://am_application.osram.info/publish/index_en.html
pepcco
Příspěvek od pepcco » 24 bře 2011, 10:38
Krásavica! 8-) Tie prahy ti závidím, lebo ináč už všetko mám, len tie prahy nie a nie zohnať! Nech ti slúži, veľa šťastných km! :lol:
Fila78
Příspěvek od Fila78 » 24 bře 2011, 11:59
Pekna pekna 8-) .
Mike.S
Příspěvek od Mike.S » 24 bře 2011, 20:16
tak Ti gratuluju ke koupi toho mazlíka a ať Ti slouží 8-)
to máš na zimách? měl jsem pocit, že tam byly jiné liťáky ...
Old cars:
Škoda 120L
Škoda Felicia Combi LXi
Actual car:
