řekni si o info podle svého VIN zde
- DanielMazanec
Zdravím, kdo by byl tak hodný a vyjel podle VINka moji Astru?
VIN: W0L0AHL0885118570. Mám také Sport režim bez IDS+ a vím také, že mám snížené origo pružiny...Tuším -10mm, ale v čem je rozdílná "sportovní zadní náprava", jak zde bylo zmíněno oproti nápravě bez sportovního režimu? Díky za ujasnění
Astra H GTC 2008 1.7CDTi (74kW) Z17DTH
@danko
Info vehicule
Model A04 ASTRA-H
Model Code 0TP08
Made 08.04.2008
Type body L08
Motor Z17DTH
The engine number 1796076
Transmission
VIN Decoding
W0L
General Motors
0
Normal Vehicle
A
Astra Platform
H
2004 Platform Generation
L08
3 Door Hatch
8
2008
5
Antwerp
serial
118570
Options
STITCHING COLOUR,STARSILVER
EXTERIOR PAINT,SEE MODEL CATALOGUE FOREWORD PAINT CHART
COVER,FLOOR INNER,STANDARD
INTERIOR-BLACK
BODY INTERIOR TRIM-BLACK
DOOR PANEL TRIM,BLACK
FRONT BUCKET SEAT
FRONT SEAT,DRIVER,6 WAY MANUAL
WITH ADJUSTABLE LUMBAR SUPPORT
RESTRAINT HEAD, RR SEAT, VINYL COVERED, TWO, OUTSIDE
AIR BAG,ROOF,FRONT
PLATE DOOR SILL COVER
MOULDING BODYSIDE COLOUR
COOL BOX
MOULDING,ASSY.,ROOF,BODY COLOURED
WITH MATT CHROME SEMI GLOSS MOULDING
IDENTIFICATION BREAKING POINT 2008 1/2 M.Y.
SEAL PRIMARY, DOORS, TWO COLOUR
SEAL PRIMARY, DOORS, LOWER
MOULDING DOOR INTERIOR, MATT CHROME SEMI GLOSS
WITH CHROME MOULDING
FOR ELECTRONIC AIR CONDITIONING
LAMP,ASSY,ROOF,WITH DUAL READING LAMP
FOR ITALY
HANDLE,ASSY.,OUTSIDE
MIRROR,ELECTRIC,RH-LH
MIRROR,ASSY
VISOR,SUN,WITH ILLUMINATED MIRROR,RH-LH
HOUSING
ASHTRAY AND CIGARETTE LIGHTER (SMOKERS PACK)
INSTRUMENT CLUSTER,BLACK,BLACK RINGS WITH SILVER TOP
SALES PACKAGE EQUIPMENT-COSMO
KEY
AXLE RATIO 3.95 (FRT)
ELECTRONIC STABILITY PROGRAM
5 BOLT WHEEL FIXING
ABS
ALTERNATOR,100AMP
HEATER DUCT,REAR PASSENGER 2ND POSITION
LEFT HAND DRIVE
Z17DTH[LPZ] DIESEL ENGINE
MANUAL TRANSMISSION,5 SPEED,F23 TYPE
USED WITH MANUAL TRANSMISSION
WHEEL,ASSY.,STEERING,THREE SPOKES,LEATHER
TYRE,SPARE,SPACE SAVER
EQUIPMENT,EUROPEAN UNION
FOR REDUCED RACK TRAVEL
EMISSION,EEC 05
TRIM,ALPHA/VINYL
TYRES,225/45 R 17-91V
WHEEL,ROAD,ALUMINIUM,7JX17
TRIM PANEL,INNER,VINYL
FRONT FOGLAMP
ORNAMENTATION DARK, HEADLAMP HOUSING
LAMP ASSY, INTERIOR, FRONT DOOR
BATTERY,60AH
LAMP INTERIOR,ROOF,REAR,COURTESY AND DUAL READING
FRAME,RADIO
FOR RADIO EQUIPMENT AUXILIARY CONNECTOR
HORN,FANFARE
SPEAKER,7
INFORMATION COMPUTER
GRAPHIC INFO - MONOCHROMATIC
RADIO AM/FM STEREO,SEEK,CD,ETR,FADER,MP3
SENSOR INDICATOR AUTOMATIC AIR RECIRCULATION
SWITCH SPORT MODE
PROTECTION WAX
HOLDER,EYE GLASSES
GRILLE RADIATOR,LATICE TYPE,BLACK,WITH CHROME BAR
PANEL CENTRE INSTRUMENT,CHARCOAL PIANO
FOR STEERING WHEEL RADIO OPERATION
EQUIPMENT RECEIVING UNIT,RADIO
LOWERED SPORTS CHASSIS
SENSOR,RESTRAINT SYSTEM,LH
USED WITH SPORTS CHASSIS
Mas tam to co ja co sa tyka napravy
A mne to nepride centimeter,minimalne 3cm,teda porovnaval som so svojou starou 1,9tkou
Info vehicule
Model A04 ASTRA-H
Model Code 0TP08
Made 08.04.2008
Type body L08
Motor Z17DTH
Transmission
VIN Decoding
W0L
General Motors
0
Normal Vehicle
A
Astra Platform
H
L08
3 Door Hatch
8
2008
5
Antwerp
serial
118570
Options
INTERIOR-BLACK
FRONT BUCKET SEAT
AIR BAG,ROOF,FRONT
COOL BOX
FOR ITALY
MIRROR,ASSY
HOUSING
KEY
5 BOLT WHEEL FIXING
ABS
ALTERNATOR,100AMP
LEFT HAND DRIVE
EMISSION,EEC 05
TRIM,ALPHA/VINYL
FRONT FOGLAMP
BATTERY,60AH
FRAME,RADIO
HORN,FANFARE
SPEAKER,7
SWITCH SPORT MODE
PROTECTION WAX
HOLDER,EYE GLASSES
Náprava pro nižší sportovní podvozek označení kódu výbavy XJ2 (nižší pružiny)DanielMazanec píše:Zdravím, kdo by byl tak hodný a vyjel podle VINka moji Astru?VIN: W0L0AHL0885118570. Mám také Sport režim bez IDS+ a vím také, že mám snížené origo pružiny...Tuším -10mm, ale v čem je rozdílná "sportovní zadní náprava", jak zde bylo zmíněno oproti nápravě bez sportovního režimu? Díky za ujasnění
Položka č.1X GM 93178632 (Opel 4 24 064)
Pero zadní, nepoužívá se se sadou pro ochranu podvozku - motorový prostor. Ident SJ kromě OPC a VXR
Položka č.5 GM 93178641 (Opel 4 36 316)
Tlumič pérování kromě IDS+ nepoužívá se se sadou pro ochranu podvozku - motorový prostor. Ident A2 kromě OPC a VXR
http://ecat24.com/opel/catalog/part/1/9 ... 1188,1185/
Nosník zadní nápravy položka č.1 GM 93182200 (Opel 54 02 221)
Používá se se sportovním podvozkem Ident YU
http://ecat24.com/opel/catalog/part/1/9 ... 1189,1187/
333jaco333
Zdravim, som tu novy a planujem kupu Astry H caravan.Poprosil by som info
VIN: W0L0AHL3582008231
Opel Astra H caravan, 1.9cdti, 74kw, r.v. 8.2007
Decoding VIN code W0L0AHL3582008231333jaco333 píše:Zdravim, som tu novy a planujem kupu Astry H caravan.Poprosil by som info
Informace dopravní - první evidenční číslo SON-KR39
Model A04 ASTRA-H
Modelový kód 0TN35
Udělal 10.08.2007
Velikost písma L35
Motor Z19DT
Číslo motoru 5652029
Přenos
VIN dekódování
W0L
General Motors
0
Normální vozidlo
A
Astrina platforma
H
2004 platformní generace
L35
Majetek
8
2008
2
BOCHUM
sériový
008231
Na přání
VENKOVNÍ BARVA,PODÍVEJ SE NA MODEL KATALOG PŘEDMLUVU BARVU GRAF
KRYT,PODLAHA VNITŘNÍ,STANDARD
INTERIÉR-ČERNÝ
INTERIÉR AUTOMOBILU TRIM - BLACK
PLECH DVEŘÍ UPRAVENÝ,ČERNÝ
PŘEDNÍ SKLÁPĚCÍ SEDADLO
OPĚRKA HLAVY,PŘEDNÍ SEDADLO,AKTIVNÍ
PŘEDNÍ SEDADLO,ŘIDIČ,6 ZPŮSOB, JAK PŘÍRUČKA
S NASTAVITELNOU BEDERNÍ OPĚROU PÁTEŘEMI
OPĚRKA HLAVY,ZÁĎ,LÁTKA,DVA
PRO BEZPEČNOSTNÍ SÍŤ INSTALAČNÍ ZÁSOBY
AIRBAG,STŘECHA,PŘEDNÍ STRANA
OPĚRKA HLAVY,ZÁĎ,LÁTKA,CENTRUM
KRYT,ASSY.,ZAVAZADLO
HNĚTENÍ BODYSIDE BARVY
CHLADNÝ BOX
HNĚTENÍ DVEŘNÍHO INTERIÉRU, VLÁKNITÉHO SÁDROVCE
HNĚTENÍ ŠTÍTU PŘÍSTROJŮ,VLÁKNITÉHO SÁDROVCE
PRO ELEKTRONICKOU KLIMATIZACI
LAMPA,ASSY,STŘECHA,S DVOJITOU LAMPOU NA ČTENÍ
HADR,PŘEDNÍ STRANA,IMPULSNÍ SOUSTAVA
OSTŘIKOVAČ SVĚTLOMETU
PRO NĚMECKÝ
KLIKA,ASSY.,VNĚ
PŘEDNÍ SEDADLOOPĚRADLA NA RUCE,LH
PRO SVĚTLÉ CITLIVÉ VNITŘNÍ ZRCADLO
ZRCADLO,ELEKTRICKÝ,RH - LH
ZRCADLO,ASSY
HLEDÍ,SLUNCE,S OSVĚTLENÝM ZRCADLEM,RH - LH
BYDLENÍ
POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCI BALÍK)
BLOK PŘÍSTROJŮ,ČERNÉ,ČERNÉ PRSTENY SE STŘÍBREM DOVRŠÍ
VYCHUTNÁVAT
KRYT
KLÍČ
ELEKTRONICKÝ PROGRAM STABILITY
STÁLÝ PŘEVOD ROZVODOVKY 3.65
5 BOLT UPEVNĚNÍ KOLA
PROTIBLOKOVACÍ BRZDOVÝ SYSTÉM ABS
UŽÍVAL S ODSÁVACÍM SYSTÉMEM ČISTIČEM ČÁSTIC
REGULACE RYCHLOSTI JÍZDY
ALTERNÁTOR,100AMP
PRO ZAHŘÁTÁ PŘEDNÍ SEDADLA
VEDENÍ OHŘÍVAČE,ZADNÍ PASAŽÉR 2. UMÍSTÍ
LEVOSTRANNÉ ŘÍZENÍ
Z19DTL[LPP] NAFTOVÝ MOTOR
UŽÍVAL S RUČNÍM PŘENOSEM
M32 (WR) RUČNÍ PŘENOS
KOLO,ASSY.,,ŘÍZENÍ,TŘI VÝPLETY KOLA,KŮŽE
VYBAVENÍ,EVROPSKÁ UNIE
PRO PROMĚNNÉ ŘÍZENÍ S POSILOVAČEM ÚSILÍ
VYSLÁNÍ,EEC 05
MÍSTNÍ GM EVROPY OHA
KRYT,KOLO 16INCH CAMPAGNE DESIGN MY07
UPRAVENÁ LÁTKA, TABITA/ELBA
PNEUMATIKY,205/55 R 16 - 91H
KOLO,CESTA,OCEL,61/2JX16
PRO PLNÉ VELIKOSTNÍ NÁHRADNÍ KOLO
HEADLAMPS,AUTOMATICKÝ ON - OFF
PŘEDNÍ MLHOVKA
DÍL OBLOŽENÍ,VNITŘEK,TABITA
BATERIE,60AH
MŘÍŽOVÉ TOPNÉ TĚLESO,ČERNÝ,S CHROMOVÝM BAREM
INTERIÉR LAMPY, STŘECHY,ZÁDI, ZDVOŘILOSTI A DVOJITÉHO ČTENÍ
RÁM,RÁDIO
LAMPA,ASSY,VNITŘNÍ ZVYK
INTERIÉR LAMPY LUXUSNÍ
RÁDIOVÁ ZAŘÍZENÍ CHLADICÍ SOUSTAVA
PRO RÁDIOVOU ZAŘÍZENÍ POMOCNOU SPOJKU
MLUVČÍ,7
INFORMAČNÍ POČÍTAČ
GRAFICKÁ INFORMACE - BARVA
RÁDIO - BÝT/FM'S STEREO,HLEDAT,CD,NAVIGACE,ETR,PROLÍNAČ
SENZOROVÉ INDIKÁTOROVÉ AUTOMATICKÉ LETECKÉ ZPĚTNÉ VEDENÍ
DOPRAVCE,ZAVAZADLO,STŘECHA,PRACH POKRYL
NOSIČ ZAVAZADEL VYČISTÍ STŘECHU,ČERNÝ
OCHRANNÝ VOSK,VYMAZAT
PANELOVÝ CENTRÁLNÍ NÁSTROJ,VLÁKNITÝ SÁDROVEC
ODDĚLUJÍCÍ SPÍNAČ BATERIE
PRO RÁDIO - OPERACE VOLANTU
VYBAVENÍ,ZIMA
PŘÍSTROJOVÁ PŘIJÍMAJÍCÍ JEDNOTKA,RÁDIO
PŘÍSTROJOVÁ PŘIJÍMAJÍCÍ JEDNOTKA,GPS
POŽADOVAL KDY PŘIPOMÍNKA SLUŽBY DISPLEJE SEDĚL
SENZOR, SYSTÉM OMEZENÍ,LH
- DanielMazanec
Moc děkuju za výpis
Trošku mi zadní tlumiče tečou a mám doma úplně nový, ale koukám tedy, že to nejsou ty snížený. Objednávací kód je GM 93178640. Opel 4 36 315. Vypadá to že jsou to klasický pro auta bez Sport režimu. Takže nic pro mě. Pokud se pletu, opravte mě
333jaco333
Velka vdaka, a este jedna otazocka ma to DPF filter?Stan. píše:Decoding VIN code W0L0AHL3582008231333jaco333 píše:Zdravim, som tu novy a planujem kupu Astry H caravan.Poprosil by som info
Model A04 ASTRA-H
Modelový kód 0TN35
Udělal 10.08.2007
Velikost písma L35
Motor Z19DT
Přenos
VIN dekódování
W0L
General Motors
0
Normální vozidlo
A
Astrina platforma
H
L35
Majetek
8
2008
2
BOCHUM
sériový
008231
Na přání
INTERIÉR-ČERNÝ
CHLADNÝ BOX
PRO NĚMECKÝ
KLIKA,ASSY.,VNĚ
ZRCADLO,ASSY
BYDLENÍ
VYCHUTNÁVAT
KRYT
KLÍČ
ALTERNÁTOR,100AMP
LEVOSTRANNÉ ŘÍZENÍ
VYSLÁNÍ,EEC 05
PŘEDNÍ MLHOVKA
BATERIE,60AH
RÁM,RÁDIO
MLUVČÍ,7
INFORMAČNÍ POČÍTAČ
VYBAVENÍ,ZIMA
Podle katalogu pro výfuk ano, trubka střední výfuková s katalyzátorem.
Používá se u čističe sazí výfukového systému. GM 13253541 (Opel 8 55 665)
Uvedené katalogové číslo jak píšeš GM 93178640 (Opel 4 36 315) je dle katalogu pro 5ti dveřový sedan Ident A1.DanielMazanec píše:Moc děkuju za výpisTrošku mi zadní tlumiče tečou a mám doma úplně nový, ale koukám tedy, že to nejsou ty snížený. Objednávací kód je GM 93178640. Opel 4 36 315. Vypadá to že jsou to klasický pro auta bez Sport režimu. Takže nic pro mě. Pokud se pletu, opravte mě
Nepoužívá se pro snížený sportovní podvozek a nepoužívá se pro ochranu podvozku (prostor motoru)
@333jaco333
Ano ma
Ano ma
