mimar
Příspěvek od mimar »
Vedel by mi niekto zistiť katalógové číslo gumových záslepiek technologických otvorov zo spodu na prahoch. Je ich tam cca 10 - 15 na každej strane. Ďakujem
Skús pozrieť tu že ktoré to sú:
http://www.opeloem.com/opel/astra_h_200 ... plugs.html
jumajazu
Příspěvek od jumajazu »
Poprosil by som o info k tomuto VIN
W0L0AHM7582055647
Vopred dakujem
W0L:General Motors
A:Astra Platform
H:2004 Platform Generation
M75:Monocab (Zafira)
8:2008
2:Bochum
055647:SERIAL NUMBER
1RU = VNĚJŠÍ BARVA,VIZ SEZNAM BAREV V ÚVODĚ KATALOGU 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 60X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - BÉŽOVÉ 60Y = LEM OPLECHOVÁNÍ DVEŘÍ,BÉŽOVÝ 80I = VNITŘEK-ČERNÝ A14 = SKLO,BOČNÍ OKNO,ZADNÍ,ZBARVENÉ A33 = ELEKTRICKY ŘÍZENÉ OKNA,ZADNÍ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO A53 = PŘEDNÍ SEDADLO,SPOLUJEZDEC,6CESTNÝ RUČNÍ A88 = OPĚRKA HLAVY,PŘEDNÍ SEDADLO,AKTIVNÍ AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AHB = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AJT = PRO PŘÍPRAVU K MONTÁŽI BEZPEČNOSTNÍ SÍTĚ ANY = KOLEJNICE A VÁZACÍ ÚCHYTY PRO NÁKLAD AQ0 = OPĚRKA HLAVY,ZADNÍ SEDADLO,VINYLOVÝ POTAH,DVA,KRAJNÍ AV4 = DĚLENÉ ZADNÍ SEDADLO AWY = ZÁDRŽNÝ SYSTÉM ZADNÍ SEDADLO,RAMENNÍ,ZATAHOVÁNÍ,ODDĚLITELNÝ KOTVICÍ BOD BEZPEČNOSTNÍHO PÁSU AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY9 = OPĚRKA HLAVY,ZADNÍ,VINYL,STŘED B70 = KRYT PRAHU DVEŘÍ B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BA9 = CHLADNIČKA BNR = LIŠTA KRYCÍ DVEŘE VNITŘEK,SVĚTLÁ BURL BNU = LIŠTA PŘÍSTROJOVÉ DESKY VNITŘNÍ,SVĚTLÁ BURL BW4 = S CHROMOVOU LIŠTOU BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE C32 = PRO SYSTÉM QUICKHEAT C68 = PRO ELEKTRONICKOU KLIMATIZACI C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CE1 = STÍRAČ,PŘEDNÍ,IMPULSOVÝ SYSTÉM CT1 = PRO BELGII CT1 D75 = KLIKA ÚPLNÁ VNĚJŠÍ DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO DD8 = PRO VNITŘNÍ ZRCÁTKO CITLIVÉ NA SVĚTLO DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4R = PRODEJNÍ BALÍK SADA-COSMO E4X = ČERNÁ/BÉŽOVÁ E94 = KRYT ECA = KLÍČ FXB = POMĚR NÁPRAVY 3.65 G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K13 = POUŽÍVÁ SE S FILTREM PEVNÝM ČÁSTIC VE VÝFUKOVÉM SYSTÉMU K34 = REGULÁTOR RYCHLOSTI KC7 = ELEKTRICKÁ ZÁSUVKA,ZADNÍ SEDADLO KC8 = ZÁSUVKA,VÝSTUP POMOCNÉHO NAPÁJENÍ KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA KG9 = ALTERNÁTOR,140A LHD = ŘÍZENÍ LEVÉ LPM = VZNĚTOVÝ MOTOR Z19DT MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR) N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NR1 = PRO REDUKOVANOU DRÁHU HŘEBENOVÉ TYČE NT4 = EMISE,EEC 05 OHB PXF = LEM,ALFA/VINYL QGF = PNEUMATIKY,205/55 R 16-91H QL5 = KOLO,VOZOVKA,HLINÍK,10 PŘÍČEK,61/2JX16 QQ5 = PRO VELKÉ NÁHRAD.KOLO R2L T2Q = REFLEKTORY,AUTOMATICKÉ ZAPÍNÁNÍ/VYPÍNÁNÍ T67 = BATERIE,70AH T96 = SVĚTLO DO MLHY PŘEDNÍ T9M = ČALOUNĚNÍ ELBA TGV TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ TSQ = OSVĚTLENÍ INTERIÉRU DELUXE TTB = OSVĚTLENÍ VNITŘNÍ,STŘEŠNÍ, ZADNÍ KOMFORTNÍ A DVOJITÉ ČTECÍ,3. ŘADA TTO = RÁDIO CHLADICÍ SYSTÉM TTX = PRO POMOCNÝ KONEKTOR RÁDIA U07 = HOUKAČKA,TROUBA U3C U55 U66 = REPRODUKTOR,7 U68 = INFORMAČNÍ POČÍTAČ U71 = ANTÉNA,ÚPLNÁ,STŘECHA UAJ = GRAFICKÉ INFORMACE - BARVA UCL = RÁDIO AM/FM STEREO,HLEDÁNÍ,DVD,NAVIGACE,ETR,TLUMENÍ UD5 = ČIDLO, PARKOVACÍ SYSTÉM UEC = SNÍMAČ INDIKÁTOR AUTOMATICKÉ RECIRKULACE VZDUCHU UH0 = VÝSTRAHA BEZPEČNOSTNÍHO PÁSU,LH UJ3 UWA = PŘÍPRAVA PRO MOBILNÍ TELEFON,S OVLÁDÁNÍM HLASEM A SYSTÉMEM BLUETOOTH V3E = DRŽÁK ZAVAZADEL VOLNÝ STŘEŠNÍ,STŘÍBRNÝ V4M = VYBAVENÍ 5-STAR,SADA NCAP VFE = NÁRAZNÍK PŘEDNÍ A ZADNÍ,OCHRANNÝ VÝLISEK,BAREVNÝ VG2 = OCHRANNÍ VOSK, VYNECHEJTE VGB = STŘEŠNÍ NOSIČ ZAVAZADEL,ELOXOVANÝ VK8 = DRŽÁK,BRÝLE VNF = ODPOJOVAČ BATERIE VQ9 = ODMONTOVATELNÁ SPOJKA ZÁVLEKU VU3 = STŘEDOVÝ PŘÍSTROJ NA PANELU,UHLOVÁ METALÍZA W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO WBG = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,GPS XA3 = OPEL XK1 = PRO BELGII Y67 = POŽADUJE PŘI OSAZENÉM SERVISNÍM DISPLEJI Z0D = PRO BELGII Z0D Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ
mimar
Kesi, ďakujem, už sa vtom prehrabávam.
mana
Příspěvek od mana »
Prosím o rychlé info o W0L0AHL4865136921 . Zítra se na něho jedu podívat tak ať vím Dík
mach00
Příspěvek od mach00 »
VIN: W0L0AHL4865136921
W0L: General Motors
A: Astra Platform
H: 2004 Platform Generation
L48: 5-DV. SEDAN
6: 2006
5: Antwerp
136921: SERIAL NUMBER
Kód modelu: 0T 48
Kód balení: IZS1
Datum výroby: 28.2.2006
Typ motoru: Z16XEP
Sériové číslo motoru: 20GV6228
Čalounění: XXVM
Výbava: 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 4CU = VNĚJŠÍ LAK, VIZ KATALOG MODELŮ, ÚVOD, TABULKA LAKŮ 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA AJ7 = PRO BEZP. VAK ŘIDIČE, SPOJEZDCE A BOČNÍ VAK AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BA9 = CHLADNIČKA BL5 = LIŠTA KRYCÍ DVEŘE VNITŘEK,STŘÍBRNÁ BLB = KRYCÍ LIŠTY PŘÍSTROJOVÉ DESKY,STŘÍBRNÁ BRE = IDENTIFIKAČNÍ KRITICKÝ BOD 2006 1/2 MR C68 = PRO ELEKTRONICKOU KLIMATIZACI C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CR7 = PRO MAĎARSKO D75 = KLIKA ÚPLNÁ VNĚJŠÍ DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO DDH = ZRCADLO,ELEKTRICKÉ A VYTÁPĚNÉ,PRAVÉ,LEVÉ DDI = ZRCÁTKO,SESTAVA DGZ = SCHRÁNKA V PŘÍSTROJOVÉ DESCE DĚLÍCÍ PŘEPÁŽKA DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4Q = ENJOY ECA = KLÍČ FX1 = KONEČNÝ POHON NÁPRAVY 3.94 G61 = 4 ŠROUB UPEVNĚNÍ KOLA JM4 = BRZDOVÝ SYSTÉM,KOTOUČ-PŘEDNÍ/BUBEN-ZADNÍ K60 = ALTERNÁTOR,100AMP KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LHD = ŘÍZENÍ LEVÉ LJ7 = MOTOR Z16XEP[LJ7] M25 = RUČNÍ PŘEVODOVKA,5 RYCHLOSTNÍ,F17 TYP MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NT4 = EMISE,EEC 05 OHA = MÍSTNÍ GM Z EUROPE OHA PHP = TEXTILNÍ ČALOUNĚNÍ,TABITA/ELBA PY3 = KOLO,DISKOVÉ,OCELOVÉ,61/2JX16 QGF = PNEUMATIKY,205/55 R 16-91H QQ5 = PRO VELKÉ NÁHRAD.KOLO T96 = SVĚTLO DO MLHY PŘEDNÍ T9W = OBKLAD,VNITŘNÍ,TABITA TN6 = BATERIE,55AH TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ U3F U55 U66 = REPRODUKTOR,7 U68 = INFORMAČNÍ POČÍTAČ U71 = ANTÉNA,ÚPLNÁ,STŘECHA UAH = DISPLEJ INFOTAINMENT,GRAFICKÝ INFORMAČNÍ DISPLEJ (GID),VAR2 UCH = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,ETR,TLUMENÍ,MP3 UEQ = ODPOJOVAČ AKUMULÁTORU UJ3 VDR VG9 = OCHRANNÍ VOSK W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO XA3 = OPEL XB2 = PRO MAĎARSKO XJ9 = PRO MAĎARSKO Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ Z1O = PRO MAĎARSKO
Sajfi
Příspěvek od Sajfi »
Mám prosbičku, odinstaloval jsem si z PC EPC a zajímalo by mě, v čem předtím jezdil múj nový GID. Můžete se mi na to kouknout? Vyčetl jsem z něho tohle VIN: W0L0AHL3575190371
dík Sajfi :-)
W0L:General Motors
A:Astra Platform
L35:Estate
7:2007
5:Antwerp
190371:SERIAL NUMBER
2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 4AU = VNĚJŠÍ BARVA,VIZ SEZNAM BAREV V ÚVODĚ KATALOGU 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A53 = PŘEDNÍ SEDADLO,SPOLUJEZDEC,6CESTNÝ RUČNÍ A88 = OPĚRKA HLAVY,PŘEDNÍ SEDADLO,AKTIVNÍ AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AHB = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AHC = PRO RUČNÍ PRODLOUŽENÍ POLŠTÁŘE AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA AJT = PRO PŘÍPRAVU K MONTÁŽI BEZPEČNOSTNÍ SÍTĚ AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED B70 = KRYT PRAHU DVEŘÍ B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BA9 = CHLADNIČKA BLE = LIŠTA KRYCÍ DVEŘE VNITŘEK,CHROMOVÁ MATT BLG = LIŠTA PŘÍSTROJOVÉ DESKY VNITŘNÍ,CHROM MATT BRG = IDENTIFIKAČNÍ KRITICKÝ BOD 2007 1/2 MR BS7 = TĚSNĚNÍ PRIMÁRNÍ,DVEŘE,DVĚ BARVY BS9 = TĚSNĚNÍ PRIMÁRNÍ,DVEŘE,SPODNÍ BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE C68 = PRO ELEKTRONICKOU KLIMATIZACI C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CE1 = STÍRAČ,PŘEDNÍ,IMPULSOVÝ SYSTÉM CT3 = PRO NĚMECKO CT3 D18 = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,CHROMOVANÉ KRUHY D75 = KLIKA ÚPLNÁ VNĚJŠÍ DD8 = PRO VNITŘNÍ ZRCÁTKO CITLIVÉ NA SVĚTLO DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) E94 = KRYT ECA = KLÍČ FX3 = PROGRAM ELEKTRONICKÉ STABILITY FXB = POMĚR NÁPRAVY 3.65 G62 = 5 ŠROUB UPEVNĚNÍ KOLA JF5 = POUŽITO SPOLU S PEDÁLEM SPORT ZE SLITINY JL9 = ABS K13 = POUŽÍVÁ SE S FILTREM PEVNÝM ČÁSTIC VE VÝFUKOVÉM SYSTÉMU K34 = REGULÁTOR RYCHLOSTI K60 = ALTERNÁTOR,100AMP KA1 = PRO VYHŘÍVANÁ PŘEDNÍ SEDADLA KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LHD = ŘÍZENÍ LEVÉ LRD = VZNĚTOVÝ MOTOR Z19DTH MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR) N35 = VOLANT,SPORT,KŮŽE NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NR1 = PRO REDUKOVANOU DRÁHU HŘEBENOVÉ TYČE NT4 = EMISE,EEC 05 OHC PHQ = TEXTILNÍ ČALOUNĚNÍ,ALPHA STŘÍBRNÁ/ELBA QGT = PNEUMATIKY,225/45 R 17-91V QL4 = KOLO,DISKOVÉ,ALUMINIUM,7JX17 QQ5 = PRO VELKÉ NÁHRAD.KOLO R2D T2Q = REFLEKTORY,AUTOMATICKÉ ZAPÍNÁNÍ/VYPÍNÁNÍ T9M = ČALOUNĚNÍ ELBA T9P = DEKORACE TMAVÁ,TĚLESO SVĚTLOMETU TM7 = BATERIE,60AH TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ TSQ = OSVĚTLENÍ INTERIÉRU DELUXE TTO = RÁDIO CHLADICÍ SYSTÉM U07 = HOUKAČKA,TROUBA U3A U55 U66 = REPRODUKTOR,7 U68 = INFORMAČNÍ POČÍTAČ UAG = GRAFICKÁ INFORMACE - JEDNOBAREVNÁ UCE = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,NAVIGACE,ETR,TLUMENÍ UEC = SNÍMAČ INDIKÁTOR AUTOMATICKÉ RECIRKULACE VZDUCHU UJ3 UJC = SPÍNAČ SPORTOVNÍ REŽIM V2T = NOSIČ,ZAVAZADEL,STŘEŠNÍ,S PRÁŠKOVOU ÚPRAVOU V3D = NOSIČ ZAVAZADEL VOLNÝ STŘEŠNÍ,ČERNÝ VDR VG2 = OCHRANNÍ VOSK, VYNECHEJTE VK8 = DRŽÁK,BRÝLE VNF = ODPOJOVAČ BATERIE VU2 = STŘEDOVÝ PŘÍSTROJ NA PANELU,CHROMOVANÁ MATT W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W2E = PŘEDNÍ SEDADLA,RECARO W4Y W7P = ŠTÍTEK,SPORT WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO WBG = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,GPS XA3 = OPEL XG3 = PRO NĚMECKO XJ2 = NIŽŠÍ SPORTOVNÍ PODVOZEK Y67 = POŽADUJE PŘI OSAZENÉM SERVISNÍM DISPLEJI Z0F = PRO NĚMECKO Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ ZQ8 = UŽITO SPOLU SE SPORTOVNÍM PODVOZKEM
paulinek
Příspěvek od paulinek »
Prosím o info o vozu VIN: W0L0AHL3592125303
Mockrát děkuji! :) 8-)
Naposledy upravil(a) paulinek dne 24 bře 2012, 20:58, celkem upraveno 1 x.
Zafira B 2009 1.7 CDTi, 92 kW
