Zdravím prosil bych také informace o vin:WOLOAHM7582142731
dík.
						dík.
VIN:   W0L0AHM7582142731
Kód modelu: 0Q 75
Kód balení: JH61
REGISTRAČNÍ ČÍSLO: BI-KE 1154
Datum výroby: 07032008
W0L:General Motors
A:Astra Platform
H:2004 Platform Generation
M75:Monocab (Zafira)
8:2008
2:Bochum
142731:SERIAL NUMBER
20S = BARVA STEHŮ,HVĚZDNĚ STŘÍBRNÁ
4XU = VNĚJŠÍ LAK, VIZ KATALOG MODELŮ, ÚVOD, TABULKA LAKŮ
6Y4 = NÁHRADNÍ KOLO A PNEUMATIKA,VYNECHEJTE
80I = VNITŘEK-ČERNÝ
80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ
80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ
A14 = SKLO,BOČNÍ OKNO,ZADNÍ,ZBARVENÉ
A23 = PŘEDNÍ SKLO,REFLEXIVNÍ TEPLO
A33 = ELEKTRICKY ŘÍZENÉ OKNA,ZADNÍ
A53 = PŘEDNÍ SEDADLO,SPOLUJEZDEC,6CESTNÝ RUČNÍ
A88 = OPĚRKA HLAVY,PŘEDNÍ SEDADLO,AKTIVNÍ
AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ
AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE
AHB = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE
AHC = PRO RUČNÍ PRODLOUŽENÍ POLŠTÁŘE
AJT = PRO PŘÍPRAVU K MONTÁŽI BEZPEČNOSTNÍ SÍTĚ
AP9 = SÍŹ NÁKLADOVÉHO PROSTORU
AQ0 = OPĚRKA HLAVY,ZADNÍ SEDADLO,VINYLOVÝ POTAH,DVA,KRAJNÍ
AV4 = DĚLENÉ ZADNÍ SEDADLO
AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ
AY9 = OPĚRKA HLAVY,ZADNÍ,VINYL,STŘED
B70 = KRYT PRAHU DVEŘÍ
B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ
B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ
BLE = LIŠTA KRYCÍ DVEŘE VNITŘEK,CHROMOVÁ MATT
BLG = LIŠTA PŘÍSTROJOVÉ DESKY VNITŘNÍ,CHROM MATT
BRL = IDENTIFIKAČNÍ KRITICKÝ BOD MR 2008 1/2
BW4 = S CHROMOVOU LIŠTOU
BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE
C2K = SKLO OKNA,KONZOLA PO CELÉ DÉLCE
C68 = PRO ELEKTRONICKOU KLIMATIZACI
C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU
CE1 = STÍRAČ,PŘEDNÍ,IMPULSOVÝ SYSTÉM
CT3 = PRO NĚMECKO
D75 = KLIKA ÚPLNÁ VNĚJŠÍ
DD8 = PRO VNITŘNÍ ZRCÁTKO CITLIVÉ NA SVĚTLO
DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ
DDU = ZRCÁTKO,SESTAVA
DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ
DP6 = TĚLESO
DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA)
DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ
E4R = PRODEJNÍ BALÍK SADA-COSMO
E94 = KRYT
ECA = KLÍČ
FX3 = PROGRAM ELEKTRONICKÉ STABILITY
FXB = POMĚR NÁPRAVY 3.65
FZ3 = ZDOKONALENÝ ELEKTRONICKÝ PROGRAM STABILITY
G62 = 5 ŠROUB UPEVNĚNÍ KOLA
JL9 = ABS
K07 = PRO NEZÁVISLÉ TOPENÍ
K13 = POUŽÍVÁ SE S FILTREM PEVNÝM ČÁSTIC VE VÝFUKOVÉM SYSTÉMU
K34 = REGULÁTOR RYCHLOSTI
KA1 = PRO VYHŘÍVANÁ PŘEDNÍ SEDADLA
KB4 = POUŽITO SPOLU S DÁLKOVÝM OVLÁDÁNÍM OHŘÍVAČE
KC7 = ELEKTRICKÁ ZÁSUVKA,ZADNÍ SEDADLO
KC8 = ZÁSUVKA,VÝSTUP POMOCNÉHO NAPÁJENÍ
KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA
KG9 = ALTERNÁTOR,140A
LHD = ŘÍZENÍ LEVÉ
LPV = VZNĚTOVÝ MOTOR Z17DTJ[LPV],A17DTJ[LPV]
MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU
MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR)
N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM
NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE
NE9 = EMISNÍ SYSTÉM EEC 09
NR1 = PRO REDUKOVANOU DRÁHU HŘEBENOVÉ TYČE
OGA = SE SPECIÁLNÍM VOZIDLEM OPEL
OHB
PBF = LEM,ALPHA/MONDIAL
QQ0 = KOLO 16X6.5,HLINÍK,7 DVOJITÝCH PAPRSKŮ
R2D
T2Q = REFLEKTORY,AUTOMATICKÉ ZAPÍNÁNÍ/VYPÍNÁNÍ
T67 = BATERIE,70AH
T6K = PANEL VYBAVENÍ,VNITŘNÍ,VINYL
T96 = SVĚTLO DO MLHY PŘEDNÍ
TGR
TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ
TRP = RÁMEČEK,RADIOPŘIJÍMAČ
TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ
TSQ = OSVĚTLENÍ INTERIÉRU DELUXE
TTB = OSVĚTLENÍ VNITŘNÍ,STŘEŠNÍ, ZADNÍ KOMFORTNÍ A DVOJITÉ ČTECÍ,3. ŘADA
TTO = RÁDIO CHLADICÍ SYSTÉM
TTX
U07 = HOUKAČKA,TROUBA
U3A
U55
U66 = REPRODUKTOR,7
U68 = INFORMAČNÍ POČÍTAČ
U71 = ANTÉNA,ÚPLNÁ,STŘECHA
UAG = GRAFICKÁ INFORMACE - JEDNOBAREVNÁ
UCE = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,NAVIGACE,ETR,TLUMENÍ
UEC = SNÍMAČ INDIKÁTOR AUTOMATICKÉ RECIRKULACE VZDUCHU
UJ3
UWA = PŘÍPRAVA PRO MOBILNÍ TELEFON,S OVLÁDÁNÍM HLASEM A SYSTÉMEM BLUETOOTH
V3E = DRŽÁK ZAVAZADEL VOLNÝ STŘEŠNÍ,STŘÍBRNÝ
V4M = VYBAVENÍ 5-STAR,SADA NCAP
VG2 = OCHRANNÍ VOSK, VYNECHEJTE
VGB = STŘEŠNÍ NOSIČ ZAVAZADEL,ELOXOVANÝ
VVH = STŘEDOVÝ PŘÍSTROJ NA PANELU,UHLOVÁ PIANO
W2E = PŘEDNÍ SEDADLA,RECARO
W4Y
WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO
WBG = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,GPS
WTS = SADA,PNEUMATIKA,OPRAVA PNEUMATIK,INTEGROVANÉ VYBAVENÍ
XA3 = OPEL
XG3 = PRO NĚMECKO
Y67 = POŽADUJE PŘI OSAZENÉM SERVISNÍM DISPLEJI
Z0F = PRO NĚMECKO
Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ
						Kód modelu: 0Q 75
Kód balení: JH61
W0L:General Motors
A:Astra Platform
8:2008
2:Bochum
80I = VNITŘEK-ČERNÝ
CT3 = PRO NĚMECKO
DP6 = TĚLESO
E94 = KRYT
ECA = KLÍČ
JL9 = ABS
LHD = ŘÍZENÍ LEVÉ
OHB
R2D
T67 = BATERIE,70AH
TGR
TTX
U3A
U55
U66 = REPRODUKTOR,7
UJ3
W4Y
XA3 = OPEL
XG3 = PRO NĚMECKO
Z0F = PRO NĚMECKO
Jestli mohu poprosit
W0L0AHL4845194446
předem díky
							W0L0AHL4845194446
předem díky
ASTRA H 1.8 COSMO
VIN:   W0L0AHL4845194446
W0L: General Motors
A: Astra Platform
H: 2004 Platform Generation
L48: 5-DV. SEDAN
4: 2004
5: Antwerp
194446: SERIAL NUMBER
Kód modelu: 0T 48
Kód balení: KS51
1. reg. značka: CUX-BW 77
Datum výroby: 25.5.2004
Typ motoru: Z18XE
Sériové číslo motoru: 20CT4915
Čalounění: XXRY
Výbava: 20S = BARVA STEHŮ,HVĚZDNĚ STŘÍBRNÁ 2H9 = 18 BENZÍNOVÝ MOTOR 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 4CU = VNĚJŠÍ LAK, VIZ KATALOG MODELŮ, ÚVOD, TABULKA LAKŮ 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A33 = ELEKTRICKY ŘÍZENÉ OKNA,ZADNÍ A88 = OPĚRKA HLAVY,PŘEDNÍ SEDADLO,AKTIVNÍ AE4 = PRO SPORTOVNÍ SEDADLA AH3 = PŘEDNÍ SEDADLO,ŘIDIČ,RUČNÉ NASTAVENÍ AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AHB = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AQ0 = OPĚRKA HLAVY,ZADNÍ SEDADLO,VINYLOVÝ POTAH,DVA,KRAJNÍ AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY9 = OPĚRKA HLAVY,ZADNÍ,VINYL,STŘED B58 = KRYCÍ PODLAHOVÉ ROHOŽKY,PŘEDNÍ A ZADNÍ KOBERCOVÁ VLOŽKA B70 = KRYT PRAHU DVEŘÍ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BA9 = CHLADNIČKA BD8 = LIŠTA,CELK.,STŘEŠNÍ,V BARVĚ KAROSERIE BLK = KRYCÍ LIŠTY PŘÍSTROJOVÉ DESKY,ŘADA KOVOVÁ STŘÍBRNÁ BLM = LIŠTA KRYCÍ DVEŘE VNITŘEK,ŘADA KOVOVÁ STŘÍBRNÁ BS9 = TĚSNĚNÍ PRIMÁRNÍ,DVEŘE,SPODNÍ BW4 = S CHROMOVOU LIŠTOU BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE C32 = PRO SYSTÉM QUICKHEAT C68 = PRO ELEKTRONICKOU KLIMATIZACI C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CE1 = STÍRAČ,PŘEDNÍ,IMPULSOVÝ SYSTÉM CE4 = OSTŘIKOVAČ SVĚTLOMETU COB = VYROBENÉ V ANTWERPÁCH 2 CT3 = PRO NĚMECKO D75 = KLIKA ÚPLNÁ VNĚJŠÍ DD8 = PRO VNITŘNÍ ZRCÁTKO CITLIVÉ NA SVĚTLO DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DGZ = SCHRÁNKA V PŘÍSTROJOVÉ DESCE DĚLÍCÍ PŘEPÁŽKA DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4R = PRODEJNÍ BALÍK SADA-COSMO ECA = KLÍČ ECB FE4 = SYSTÉM PRO SPECIÁLNÍ JÍZDU A JÍZDNÍ VLASTNOSTI (IDS+) FX1 = KONEČNÝ POHON NÁPRAVY 3.94 FX3 = PROGRAM ELEKTRONICKÉ STABILITY G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K09 = ALTERNÁTOR,120AMP K34 = REGULÁTOR RYCHLOSTI KB5 = ASISTENT ROZJEZDU DO KOPCE KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LHD = ŘÍZENÍ LEVÉ M25 = RUČNÍ PŘEVODOVKA,5 RYCHLOSTNÍ,F17 TYP MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NR1 = PRO REDUKOVANOU DRÁHU HŘEBENOVÉ TYČE NT4 = EMISE,EEC 05 OHB OIF PBF = LEM,ALPHA/MONDIAL QL4 = KOLO,DISKOVÉ,ALUMINIUM,7JX17 QOM = PNEUMATIKY,215/45 R 17-91V QQ5 = PRO VELKÉ NÁHRAD.KOLO T2Q = REFLEKTORY,AUTOMATICKÉ ZAPÍNÁNÍ/VYPÍNÁNÍ T6K = PANEL VYBAVENÍ,VNITŘNÍ,VINYL T96 = SVĚTLO DO MLHY PŘEDNÍ T9S = SVÍTILNA ÚPLNÁ,VNITŘNÍ,PŘEDNÍ DVEŘE TN7 = BATERIE,66AH TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ TSQ = OSVĚTLENÍ INTERIÉRU DELUXE TT2 = SVĚTLOMETY SMĚROVÉ,VYSOKÁ INTENZITA VÝBOJKA,TLUMENÉ XENONOVÉ,DÁLKOVÉ XENONOVÉ/HALOGENOVÉ U07 = HOUKAČKA,TROUBA U3A U55 U65 = REPRODUKTOR,5 U68 = INFORMAČNÍ POČÍTAČ UAG = GRAFICKÁ INFORMACE - JEDNOBAREVNÁ UCK = RÁDIO AM/FM STEREO,HLEDÁNÍ,MCD,ETR,TLUMENÍ UD7 = ČIDLO PARKOVACÍHO SYSTÉMU UEC = SNÍMAČ INDIKÁTOR AUTOMATICKÉ RECIRKULACE VZDUCHU UEQ = ODPOJOVAČ AKUMULÁTORU UH1 = VÝSTRAHA BEZPEČNOSTNÍHO PÁSU,RH UJ3 UJ9 = INDIKÁTOR PODHUŠTĚNÍ PNEUMATIKY UJC = SPÍNAČ SPORTOVNÍ REŽIM VFE = NÁRAZNÍK PŘEDNÍ A ZADNÍ,OCHRANNÝ VÝLISEK,BAREVNÝ VK8 = DRŽÁK,BRÝLE VQ9 = ODMONTOVATELNÁ SPOJKA ZÁVLEKU W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO XA3 = OPEL XG3 = PRO NĚMECKO XJ2 = NIŽŠÍ SPORTOVNÍ PODVOZEK Y67 = POŽADUJE PŘI OSAZENÉM SERVISNÍM DISPLEJI Z0F = PRO NĚMECKO Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ Z1Y = BARVA,DVA POVLAKY ZQ8 = UŽITO SPOLU SE SPORTOVNÍM PODVOZKEM
							W0L: General Motors
A: Astra Platform
L48: 5-DV. SEDAN
4: 2004
5: Antwerp
Kód modelu: 0T 48
Kód balení: KS51
Typ motoru: Z18XE
Čalounění: XXRY
PRODÁNO: Opel Zafira B 1.9 CDTi 110kW (2006) Sport, Panorama, AFL Bi-xenon, Open&Start, CID+DVD90 CZ, Quick Heat, DDS, UHP, HSA, IDS+, DPF, MKJ,         Diagnostika OP-COM (Praha 4)
Mohu poprosit o informaci vin W0L0AHL0885025008. Mockrát děkuji
Poprosim : W0L0AHM75C2014104
je to 2012 - vidim ze uz aj tie dekodujete
Dakujem
Dakujem
Prosím o info pre tento VIN:
W0L0AHL35B2100697
Vopred ďakujem
							W0L0AHL35B2100697
Vopred ďakujem
Astra Caravan Classic III 1,6 85kW
luky:
VIN: W0L0AHL0885025008
W0L: General Motors
A: Astra Platform
L08: 3-DV. SEDAN
8: 2008
5: Antwerp
025008: SERIAL NUMBER
Kód modelu: 0T 08
Kód balení: KD5F
1.reg. značka: 30-XX-KP
Datum výroby: 2.10.2007
Typ motoru: Z18XER
Sériové číslo motoru: 20KV0169
Čalounění: XXVX
Výbava: 20S = BARVA STEHŮ,HVĚZDNĚ STŘÍBRNÁ 2H0 = MOTOR BENZINOVÝ C18SEL[2H0],Z18XER[2H0],A18XER[2H0] 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 4DU = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO A88 = OPĚRKA HLAVY,PŘEDNÍ SEDADLO,AKTIVNÍ AF8 = KONTROLA ZAMYKÁNÍ POSTRANNÍCH DVEŘÍ,OCHRANA PROTI KRÁDEŽI AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AP7 = VSTUP BEZ KLÍČE A SYSTÉM STARTU AQ0 = OPĚRKA HLAVY,ZADNÍ SEDADLO,VINYLOVÝ POTAH,DVA,KRAJNÍ AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ B4W = DEKORACE VNITŘNÍ PROSTOR,ČALOUNĚNÍ STROPU,UHLOVÉ B70 = KRYT PRAHU DVEŘÍ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BA9 = CHLADNIČKA BKX = S POLOLESKLOU KRYCÍ LIŠTOU Z MATNÉHO CHROMU BS9 = TĚSNĚNÍ PRIMÁRNÍ,DVEŘE,SPODNÍ BSS = LIŠTA KRYCÍ DVEŘE VNITŘEK,CHROMOVANÁ MATT ČÁSTEČNĚ LESKLÁ BW4 = S CHROMOVOU LIŠTOU BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE C68 = PRO ELEKTRONICKOU KLIMATIZACI CT5 = PRO HOLANDSKO D75 = KLIKA ÚPLNÁ VNĚJŠÍ DDH = ZRCADLO,ELEKTRICKÉ A VYTÁPĚNÉ,PRAVÉ,LEVÉ DDI = ZRCÁTKO,SESTAVA DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4R = PRODEJNÍ BALÍK SADA-COSMO FX1 = KONEČNÝ POHON NÁPRAVY 3.94 G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K34 = REGULÁTOR RYCHLOSTI K60 = ALTERNÁTOR,100AMP KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LHD = ŘÍZENÍ LEVÉ M25 = RUČNÍ PŘEVODOVKA,5 RYCHLOSTNÍ,F17 TYP MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM N65 = PNEUMATIKA,NÁHRADNÍ,ÚSPORA PROSTORU NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NS2 = PRO VARIABILNÍ POSILOVAČ ŘÍZENÍ NT4 = EMISE,EEC 05 OHB PXF = LEM,ALFA/VINYL QGF = PNEUMATIKY,205/55 R 16-91H QQ0 = KOLO 16X6.5,HLINÍK,7 DVOJITÝCH PAPRSKŮ R2L T6K = PANEL VYBAVENÍ,VNITŘNÍ,VINYL T96 = SVĚTLO DO MLHY PŘEDNÍ T9P = DEKORACE TMAVÁ,TĚLESO SVĚTLOMETU T9S = SVÍTILNA ÚPLNÁ,VNITŘNÍ,PŘEDNÍ DVEŘE TN6 = BATERIE,55AH TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TTO = RÁDIO CHLADICÍ SYSTÉM TTX U07 = HOUKAČKA,TROUBA U3C U55 U66 = REPRODUKTOR,7 U68 = INFORMAČNÍ POČÍTAČ U71 = ANTÉNA,ÚPLNÁ,STŘECHA UAJ = GRAFICKÉ INFORMACE - BARVA UCL = RÁDIO AM/FM STEREO,HLEDÁNÍ,DVD,NAVIGACE,ETR,TLUMENÍ UJ3 VG2 = OCHRANNÍ VOSK, VYNECHEJTE VOD = MŘÍŽKA CHLADIČE,MŘÍŽOVANÁ,ČERNÁ,S CHROMOVANOU TYČÍ VVH = STŘEDOVÝ PŘÍSTROJ NA PANELU,UHLOVÁ PIANO W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO WBG = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,GPS WP1 = PANORAMATICKÉ ČELNÍ SKLO,S TEPELNĚ REFLEXNÍ VRSTVOU XA3 = OPEL XJ2 = NIŽŠÍ SPORTOVNÍ PODVOZEK XQ5 = PRO HOLANDSKO Y67 = POŽADUJE PŘI OSAZENÉM SERVISNÍM DISPLEJI Z0G = PRO HOLANDSKO Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ
W0L: General Motors
A: Astra Platform
L08: 3-DV. SEDAN
8: 2008
5: Antwerp
Kód modelu: 0T 08
Kód balení: KD5F
Typ motoru: Z18XER
Čalounění: XXVX
pm24:
Zatím moc údajů v posledním EPC (12/2011) není...
VIN: W0L0AHM75C2014104
W0L: General Motors
0: Normal Vehicle
A: Astra Platform
M75: Monocab (Zafira)
C: 2012
2: Bochum
014104: SERIAL NUMBER
W0L: General Motors
0: Normal Vehicle
A: Astra Platform
C: 2012
2: Bochum
solo1976:
VIN: W0L0AHL35B2100697
W0L: General Motors
A: Astra Platform
L35: Estate
B: 2011
2: Bochum
100697: SERIAL NUMBER
Kód modelu: 0T 35
Kód balení: I9G1
Datum výroby: 11.4.2011
Typ motoru: A16XER
Sériové číslo motoru: 20RF7012
Čalounění: XXVM
Výbava: 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO A88 = OPĚRKA HLAVY,PŘEDNÍ SEDADLO,AKTIVNÍ AH3 = PŘEDNÍ SEDADLO,ŘIDIČ,RUČNÉ NASTAVENÍ AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA AJ7 = PRO BEZP. VAK ŘIDIČE, SPOJEZDCE A BOČNÍ VAK AT3 = ZESÍLENÉ UKOTVENÍ ZADRŽOVACÍHO SYSTÉMU ZADNÍ DĚTSKÉ SEDAČKY AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B76 = PRO PŘÍSTROJ S ČERNÝM CIFERNÍKEM BKV = LIŠTA PŘÍSTROJOVÉ DESKY VNITŘNÍ,UHLOVÁ BX6 = IDENTIFIKAČNÍ KRITICKÝ BOD 2011 1/2 MR. BYD = LIŠTA KRYCÍ DVEŘE VNITŘEK,VYNECHEJTE C68 = PRO ELEKTRONICKOU KLIMATIZACI CR7 = PRO MAĎARSKO D75 = KLIKA ÚPLNÁ VNĚJŠÍ DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DP6 = TĚLESO E9D = POTAH,ZAROVNANÝ,KOLO,VARIANT 1 ECA = KLÍČ FX1 = KONEČNÝ POHON NÁPRAVY 3.94 FX3 = PROGRAM ELEKTRONICKÉ STABILITY G62 = 5 ŠROUB UPEVNĚNÍ KOLA GAZ = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ JL9 = ABS K34 = REGULÁTOR RYCHLOSTI K60 = ALTERNÁTOR,100AMP KC8 = ZÁSUVKA,VÝSTUP POMOCNÉHO NAPÁJENÍ KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LDE = Z16EXR,A16XER[LDE] ZÁŽEHOVÝ MOTOR LHD = ŘÍZENÍ LEVÉ M25 = RUČNÍ PŘEVODOVKA,5 RYCHLOSTNÍ,F17 TYP MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NE9 = EMISNÍ SYSTÉM EEC 09 OHG PHP = TEXTILNÍ ČALOUNĚNÍ,TABITA/ELBA QGF = PNEUMATIKY,205/55 R 16-91H QN1 = KOLO,DISKOVÉ,OCELOVÉ,61/2JX16 QQ5 = PRO VELKÉ NÁHRAD.KOLO T96 = SVĚTLO DO MLHY PŘEDNÍ T9M = ČALOUNĚNÍ ELBA T9P = DEKORACE TMAVÁ,TĚLESO SVĚTLOMETU TN6 = BATERIE,55AH TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TTX U3F U55 U66 = REPRODUKTOR,7 U68 = INFORMAČNÍ POČÍTAČ UAG = GRAFICKÁ INFORMACE - JEDNOBAREVNÁ UCH = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,ETR,TLUMENÍ,MP3 UJ3 VG9 = OCHRANNÍ VOSK VU2 = STŘEDOVÝ PŘÍSTROJ NA PANELU,CHROMOVANÁ MATT W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO XA3 = OPEL XB2 = PRO MAĎARSKO XJ9 = PRO MAĎARSKO Y67 = POŽADUJE PŘI OSAZENÉM SERVISNÍM DISPLEJI Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ Z1O = PRO MAĎARSKO
W0L: General Motors
A: Astra Platform
L35: Estate
B: 2011
2: Bochum
Kód modelu: 0T 35
Kód balení: I9G1
Typ motoru: A16XER
Čalounění: XXVM
