Hele ten VIN kod máš nějakej dlouhej má být jen 17 znaků zkontroluj!
VIN:   W0L0AHL4855147917
Kód modelu: 0T 48
Kód balení: JL51
REGISTRAČNÍ ČÍSLO:
Datum výroby: 01032005
W0L:General Motors
A:Astra Platform
H:2004 Platform Generation
L48:5-DV. SEDAN
5:2005
5:Antwerp
147917:SERIAL NUMBER
4AU = VNĚJŠÍ LAK, VIZ KATALOG MODELŮ, ÚVOD, TABULKA LAKŮ
80I = VNITŘEK-ČERNÝ
80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ
80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ
AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA
AJ7 = PRO BEZP. VAK ŘIDIČE, SPOJEZDCE A BOČNÍ VAK
AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED
B76 = PRO PŘÍSTROJ S ČERNÝM CIFERNÍKEM
BGZ = IDENT.EFEKTIVNÍ BOD CON.
C60 = KLIMATIZACE
CL2 = PRO ČESKOU REPUBLIKU
COB = VYROBENÉ V ANTWERPÁCH 2
CS0 = PRO ČESKOU REPUBLIKU
DDV = ZRCÁTKO,SESTAVA
DHA = ZRCÁTKO,SESTAVA, ZPĚTNÉ,VNITŘNÍ
DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA)
FY2 = KONEČNÝ POHON NÁPRAVY 3.74
G62 = 5 ŠROUB UPEVNĚNÍ KOLA
JL9 = ABS
K60 = ALTERNÁTOR,100AMP
KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA
LHD = ŘÍZENÍ LEVÉ
LRB = MOTOR Z17DTL[LRB]
M26 = RUČNÍ PŘEVODOVKA,5 RYCHLOSTNÍ,F17 TYP
MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU
N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM
NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE
NT4 = EMISE,EEC 05
OHI = MÍSTNÍ GM Z EUROPE OHI
PAQ = LEM,ALPHA/MALTA
QG8 = KOLO,VOZOVKA,OCEL,61/2JX15
QQ5 = PRO VELKÉ NÁHRAD.KOLO
QXL = PNEUMATIKY,195/65 R 15-91T(AW)
T96 = SVĚTLO DO MLHY PŘEDNÍ
T9L = OBKLAD,VNITŘNÍ,MALTA
TM7 = BATERIE,60AH
TPX
U3F
UF8 = TROJITÝ INFORMAČNÍ DISPLEJ LCD - DATUM/ČAS/TEPLOTA
UH0 = VÝSTRAHA BEZPEČNOSTNÍHO PÁSU,LH
UH1 = VÝSTRAHA BEZPEČNOSTNÍHO PÁSU,RH
UJ3
URA = SPÍNAČ OVLÁDÁNÍ RÁDIA
UW5 = REPRODUKTOROVÝ SYSTÉM 6,BASE
W4Y
WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO
XA3 = OPEL
Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ
Z1Y = BARVA,DVA POVLAKY
						Kód modelu: 0T 48
Kód balení: JL51
REGISTRAČNÍ ČÍSLO:
W0L:General Motors
A:Astra Platform
L48:5-DV. SEDAN
5:2005
5:Antwerp
80I = VNITŘEK-ČERNÝ
C60 = KLIMATIZACE
JL9 = ABS
LHD = ŘÍZENÍ LEVÉ
NT4 = EMISE,EEC 05
TM7 = BATERIE,60AH
TPX
U3F
UJ3
W4Y
XA3 = OPEL
- nedy666
díky moc
						- Frydex
To chceš kvůli toho vašeho trhače ? Já to tam mám i se sítí a ještě sem to nepoužil, ale asi to bude třeba, jak bude hafan.
- Mike.S
Jocker: myslel jsem si to, potom je to na tom obrázku od Zraloka, ty modře označené díly to je ono, jiný obrázek v EPC není
							Old cars:
Škoda 120L
Škoda Felicia Combi LXi
Actual car:
						Škoda 120L
Actual car:
No spiš jsem potřeboval zjistit, jestli je jiný i tapec stropu nebo je v tom místě na kastli nějaký závit bo jestli je to tam nacvaklé a stačilo by "pouze vyřezat tapec...ale to bude vědět s píš někdo kdo už měl strop rozebraný....
						- Mike.S
jj, zavolej RomanoviK, ten to vědět bude
							Old cars:
Škoda 120L
Actual car:
						Škoda 120L
Actual car:
Ahoj chlapci. Poprosil by som
VIN: W0L0AHL3592047443
Dik...
Dik...
Opel Astra Caravan 1.7 Cdti, 92 kw, r.v. 2009, M6
OP-COM 08/2010
						OP-COM 08/2010
Kód modelu: 0T 35
Kód balení: JO69
REGISTRAČNÍ ČÍSLO: DV086FF
Datum výroby: 21112008
W0L:General Motors
A:Astra Platform
L35:Estate
9:2009
2:Bochum
047443:SERIAL NUMBER
18X = BARVA ČALOUNĚNÍ SEDADLA TMAVĚ UHLOVÁ
2AU = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ
80I = VNITŘEK-ČERNÝ
AH3 = PŘEDNÍ SEDADLO,ŘIDIČ,RUČNÉ NASTAVENÍ
AJT = PRO PŘÍPRAVU K MONTÁŽI BEZPEČNOSTNÍ SÍTĚ
AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ
B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ
B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ
BNS = LIŠTA KRYCÍ DVEŘE VNITŘEK,SATÉNOVÁ STONE
BPI = LIŠTA PŘÍSTROJOVÉ DESKY,SATÉNOVÁ STONE
C60 = KLIMATIZACE
C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU
CT6 = PRO ITÁLII
D75 = KLIKA ÚPLNÁ VNĚJŠÍ
DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ
DDU = ZRCÁTKO,SESTAVA
DP6 = TĚLESO
DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ
E4Q = ENJOY
E94 = KRYT
ECA = KLÍČ
FX3 = PROGRAM ELEKTRONICKÉ STABILITY
FXB = POMĚR NÁPRAVY 3.65
JL9 = ABS
K13 = POUŽÍVÁ SE S FILTREM PEVNÝM ČÁSTIC VE VÝFUKOVÉM SYSTÉMU
LHD = ŘÍZENÍ LEVÉ
LPL = VZNĚTOVÉ MOTORY Z17DTR[LPL],A17DTR[LPL]
MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR)
N52 = VOLANT,TŘI PAPRSKY
N65 = PNEUMATIKA,NÁHRADNÍ,ÚSPORA PROSTORU
NS2 = PRO VARIABILNÍ POSILOVAČ ŘÍZENÍ
NT4 = EMISE,EEC 05
NZX = KRYT,KOLO
OHA = MÍSTNÍ GM Z EUROPE OHA
QN1 = KOLO,DISKOVÉ,OCELOVÉ,61/2JX16
T9M = ČALOUNĚNÍ ELBA
TM7 = BATERIE,60AH
TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ
TRP = RÁMEČEK,RADIOPŘIJÍMAČ
TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ
U07 = HOUKAČKA,TROUBA
U3B
U55
U68 = INFORMAČNÍ POČÍTAČ
UAC = INFORMAČNÍ PANEL LCD - VÍCEFUNKČNÍ
UJ3
V2T = NOSIČ,ZAVAZADEL,STŘEŠNÍ,S PRÁŠKOVOU ÚPRAVOU
V3D = NOSIČ ZAVAZADEL VOLNÝ STŘEŠNÍ,ČERNÝ
VG9 = OCHRANNÍ VOSK
VJU = STŘEDOVÝ PŘÍSTROJ NA PANELU,SATÉNOVÁ STONE
W4Y
WFR = TEXTILNÍ ČALOUNĚNÍ,TWIST/ELBA
XA3 = OPEL
XK4 = PRO ITÁLII
Z0H = PRO ITÁLII
						Kód modelu: 0T 35
Kód balení: JO69
W0L:General Motors
A:Astra Platform
L35:Estate
9:2009
2:Bochum
80I = VNITŘEK-ČERNÝ
C60 = KLIMATIZACE
CT6 = PRO ITÁLII
DP6 = TĚLESO
E4Q = ENJOY
E94 = KRYT
ECA = KLÍČ
JL9 = ABS
LHD = ŘÍZENÍ LEVÉ
NT4 = EMISE,EEC 05
NZX = KRYT,KOLO
TM7 = BATERIE,60AH
U3B
U55
UJ3
VG9 = OCHRANNÍ VOSK
W4Y
XA3 = OPEL
XK4 = PRO ITÁLII
Z0H = PRO ITÁLII
