mach00
Příspěvek od mach00 »
VIN: W0L0AHM7562187774
W0L: General Motors
A: Astra Platform
H: 2004 Platform Generation
M75: Monocab (Zafira)
6: 2006
2: Bochum
187774: SERIAL NUMBER
Kód modelu: 0QP75
Kód balení: LD61
1. reg. značka: M-Q 8183
Datum výroby: 12.5.2006
Typ motoru: Z19DT
Sériové číslo motoru: 4998204
Čalounění: XXVX
Výbava: 20S = BARVA STEHŮ,HVĚZDNĚ STŘÍBRNÁ 2AU = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 6Y4 = NÁHRADNÍ KOLO A PNEUMATIKA,VYNECHEJTE 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A88 = OPĚRKA HLAVY,PŘEDNÍ SEDADLO,AKTIVNÍ AE4 = PRO SPORTOVNÍ SEDADLA AF8 = KONTROLA ZAMYKÁNÍ POSTRANNÍCH DVEŘÍ,OCHRANA PROTI KRÁDEŽI AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AJT = PRO PŘÍPRAVU K MONTÁŽI BEZPEČNOSTNÍ SÍTĚ AQ0 = OPĚRKA HLAVY,ZADNÍ SEDADLO,VINYLOVÝ POTAH,DVA,KRAJNÍ AV4 = DĚLENÉ ZADNÍ SEDADLO AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY9 = OPĚRKA HLAVY,ZADNÍ,VINYL,STŘED B70 = KRYT PRAHU DVEŘÍ B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BA9 = CHLADNIČKA BF8 = ÚLOŽNÁ SCHRÁNKA,PŘEDNÍ SEDADLO,PRAVÉ BL5 = LIŠTA KRYCÍ DVEŘE VNITŘEK,STŘÍBRNÁ BLB = KRYCÍ LIŠTY PŘÍSTROJOVÉ DESKY,STŘÍBRNÁ BRE = IDENTIFIKAČNÍ KRITICKÝ BOD 2006 1/2 MR BW4 = S CHROMOVOU LIŠTOU BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE C2K = SKLO OKNA,KONZOLA PO CELÉ DÉLCE C68 = PRO ELEKTRONICKOU KLIMATIZACI C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CE4 = OSTŘIKOVAČ SVĚTLOMETU CT3 = PRO NĚMECKO D75 = KLIKA ÚPLNÁ VNĚJŠÍ DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4R = PRODEJNÍ BALÍK SADA-COSMO E94 = KRYT ECA = KLÍČ F52 = PODVOZEK SE SPORTOVNÍ ÚPRAVOU FE4 = SYSTÉM PRO SPECIÁLNÍ JÍZDU A JÍZDNÍ VLASTNOSTI (IDS+) FX3 = PROGRAM ELEKTRONICKÉ STABILITY FXB = POMĚR NÁPRAVY 3.65 FZ3 = PRO ZDOKONALENÝ ELEKTRONICKÝ PROGRAM STABILITY (STABILITA PŘÍVĚSU) FZM = NÍZKONÁKLADOVÁ STRUKTURA MODUL PŘEDNÍ ZÓNY G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K13 = POUŽÍVÁ SE S FILTREM PEVNÝM ČÁSTIC VE VÝFUKOVÉM SYSTÉMU K34 = REGULÁTOR RYCHLOSTI K60 = ALTERNÁTOR,100AMP KA1 = PRO VYHŘÍVANÁ PŘEDNÍ SEDADLA KC7 = ELEKTRICKÁ ZÁSUVKA,ZADNÍ SEDADLO KC8 = ZÁSUVKA,VÝSTUP POMOCNÉHO NAPÁJENÍ KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA KCN = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 3.POLOHA LHD = ŘÍZENÍ LEVÉ LPM = VZNĚTOVÝ MOTOR Z19DT MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR) N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NR1 = PRO REDUKOVANOU DRÁHU HŘEBENOVÉ TYČE NT4 = EMISE,EEC 05 OHB PXF = LEM,ALFA/VINYL QGT = PNEUMATIKY,225/45 R 17-91V QL4 = KOLO,DISKOVÉ,ALUMINIUM,7JX17 R2D T6K = PANEL VYBAVENÍ,VNITŘNÍ,VINYL T96 = SVĚTLO DO MLHY PŘEDNÍ T9S = SVÍTILNA ÚPLNÁ,VNITŘNÍ,PŘEDNÍ DVEŘE TGR TIK = CHLADICÍ SYSTÉM,CHLADIČ PLNICÍHO VZDUCHU TM7 = BATERIE,60AH TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ TT2 = SVĚTLOMETY SMĚROVÉ,VYSOKÁ INTENZITA VÝBOJKA,TLUMENÉ XENONOVÉ,DÁLKOVÉ XENONOVÉ/HALOGENOVÉ TTB = OSVĚTLENÍ VNITŘNÍ,STŘEŠNÍ, ZADNÍ KOMFORTNÍ A DVOJITÉ ČTECÍ,3. ŘADA U07 = HOUKAČKA,TROUBA U3A U66 = REPRODUKTOR,7 U71 = ANTÉNA,ÚPLNÁ,STŘECHA UA6 = OCHRANA PROTI VLOUPÁNÍ UAJ = GRAFICKÉ INFORMACE - BARVA UCE = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,NAVIGACE,ETR,TLUMENÍ UEC = SNÍMAČ INDIKÁTOR AUTOMATICKÉ RECIRKULACE VZDUCHU UEQ = ODPOJOVAČ AKUMULÁTORU UH0 = VÝSTRAHA BEZPEČNOSTNÍHO PÁSU,LH UJ3 UJC = SPÍNAČ SPORTOVNÍ REŽIM UK6 = POUŽITO U OVLÁDÁNÍ RÁDIA A ZDÍŘEK SLUCHÁTEK U ZADNÍHO SEDADLA UWA = PŘÍPRAVA PRO MOBILNÍ TELEFON,S OVLÁDÁNÍM HLASEM A SYSTÉMEM BLUETOOTH V2T = NOSIČ,ZAVAZADEL,STŘEŠNÍ,S PRÁŠKOVOU ÚPRAVOU V3E = DRŽÁK ZAVAZADEL VOLNÝ STŘEŠNÍ,STŘÍBRNÝ V4M = VYBAVENÍ 5-STAR,SADA NCAP VFE = NÁRAZNÍK PŘEDNÍ A ZADNÍ,OCHRANNÝ VÝLISEK,BAREVNÝ VG9 = OCHRANNÍ VOSK VNF = ODPOJOVAČ BATERIE W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO WBG = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,GPS WTS = SADA,PNEUMATIKA,OPRAVA PNEUMATIK,INTEGROVANÉ VYBAVENÍ XA3 = OPEL XG3 = PRO NĚMECKO Z0F = PRO NĚMECKO Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ ZQ8 = UŽITO SPOLU SE SPORTOVNÍM PODVOZKEM
vencator
Příspěvek od vencator »
Dekuju :)
zralok
Příspěvek od zralok »
Tak si ho nech vypsat z VTP to si myslím nebude problém
kodl
Příspěvek od kodl »
Dobrý den zajímá mě jak se pozná že auto má asr protikluz prodejce mi tvrdil že má ale dnes jsem se hrabal a nic
opel astra 1.6 W0L0AHL698G062243 rv.2007
Děkuji
Naposledy upravil(a) kodl dne 10 pro 2011, 09:09, celkem upraveno 1 x.
zralok
Kdy to bylo vyrobený? mě to nic nenašlo ! a zkontroluj si ten VIN maš tam místo 0 (nula) O - jako opice
kodl
Příspěvek od kodl »
snad už to bude v pořádku W0L0AHL698G062243 rv 2007 1.6 85kW opel astra sedan
děkuji
zralok
VIN: W0L0AHL698G062243
Kód modelu: 0TN69
Kód balení: I751
REGISTRAČNÍ ČÍSLO:
Datum výroby: 16112007
W0L:General Motors
A:Astra Platform
H:2004 Platform Generation
L69:4-DV. Sedan (F69)
8:2008
G:Gliwice
062243:SERIAL NUMBER
80I = VNITŘEK-ČERNÝ
A90 = KRYT PROSTORU NA ZAVAZADLA,DÁLKOVÉ UVOLNĚNÍ
AH3 = PŘEDNÍ SEDADLO,ŘIDIČ,RUČNÉ NASTAVENÍ
AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA
AJ7 = PRO BEZP. VAK ŘIDIČE, SPOJEZDCE A BOČNÍ VAK
AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED
BNS = LIŠTA KRYCÍ DVEŘE VNITŘEK,SATÉNOVÁ STONE
BPI = LIŠTA PŘÍSTROJOVÉ DESKY,SATÉNOVÁ STONE
C60 = KLIMATIZACE
CR7 = PRO MAĎARSKO
CR7
DP6 = TĚLESO
E4Q = ENJOY
ECA = KLÍČ
FX1 = KONEČNÝ POHON NÁPRAVY 3.94
JL9 = ABS
LDE = Z16EXR,A16XER[LDE] ZÁŽEHOVÝ MOTOR
LHD = ŘÍZENÍ LEVÉ
M25 = RUČNÍ PŘEVODOVKA,5 RYCHLOSTNÍ,F17 TYP
N52 = VOLANT,TŘI PAPRSKY
NT4 = EMISE,EEC 05
OHA = MÍSTNÍ GM Z EUROPE OHA
PHP = TEXTILNÍ ČALOUNĚNÍ,TABITA/ELBA
PY3 = KOLO,DISKOVÉ,OCELOVÉ,61/2JX16
QQ5 = PRO VELKÉ NÁHRAD.KOLO
T9W = OBKLAD,VNITŘNÍ,TABITA
TN6 = BATERIE,55AH
TTX = PRO POMOCNÝ KONEKTOR RÁDIA
U3F
U66 = REPRODUKTOR,7
UAC = INFORMAČNÍ PANEL LCD - VÍCEFUNKČNÍ
UCH = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,ETR,TLUMENÍ,MP3
UJ3
VG9 = OCHRANNÍ VOSK
VJU = STŘEDOVÝ PŘÍSTROJ NA PANELU,SATÉNOVÁ STONE
W4Y
XA3 = OPEL
XB2 = PRO MAĎARSKO
XJ9 = PRO MAĎARSKO
Z1O = PRO MAĎARSKO
kodl
Příspěvek od kodl »
jaké označení má asr děkuji
zralok
Jocker píše:PLS - W0L0AHL35C2005317 ď
VIN: W0L0AHL35C2005317
Kód modelu: 0T 35
Kód balení: JH61
REGISTRAČNÍ ČÍSLO:
Datum výroby: 15092011
W0L:General Motors
A:Astra Platform
L35:Estate
C:2012
2:Bochum
005317:SERIAL NUMBER
80I = VNITŘEK-ČERNÝ
A14 = SKLO,BOČNÍ OKNO,ZADNÍ,ZBARVENÉ
AT3 = ZESÍLENÉ UKOTVENÍ ZADRŽOVACÍHO SYSTÉMU ZADNÍ DĚTSKÉ SEDAČKY
B76 = PRO PŘÍSTROJ S ČERNÝM CIFERNÍKEM
BKV = LIŠTA PŘÍSTROJOVÉ DESKY VNITŘNÍ,UHLOVÁ
BYD = LIŠTA KRYCÍ DVEŘE VNITŘEK,VYNECHEJTE
CE1 = STÍRAČ,PŘEDNÍ,IMPULSOVÝ SYSTÉM
CR7 = PRO MAĎARSKO
DD8 = PRO VNITŘNÍ ZRCÁTKO CITLIVÉ NA SVĚTLO
DP6 = TĚLESO
E9D = POTAH,ZAROVNANÝ,KOLO,VARIANT 1
ECA = KLÍČ
GAL = VNĚJŠÍ LAK, VIZ KATALOG MODELŮ, ÚVOD, TABULKA LAKŮ
JL9 = ABS
LHD = ŘÍZENÍ LEVÉ
LPV = VZNĚTOVÝ MOTOR Z17DTJ[LPV],A17DTJ[LPV]
NE9 = EMISNÍ SYSTÉM EEC 09
NS2 = PRO VARIABILNÍ POSILOVAČ ŘÍZENÍ
OHG
OMO
QN1 = KOLO,DISKOVÉ,OCELOVÉ,61/2JX16
T2Q = REFLEKTORY,AUTOMATICKÉ ZAPÍNÁNÍ/VYPÍNÁNÍ
T9M = ČALOUNĚNÍ ELBA
T9P = DEKORACE TMAVÁ,TĚLESO SVĚTLOMETU
TM7 = BATERIE,60AH
TSQ = OSVĚTLENÍ INTERIÉRU DELUXE
TTX
U3F
U55
U66 = REPRODUKTOR,7
U68 = INFORMAČNÍ POČÍTAČ
UAG = GRAFICKÁ INFORMACE - JEDNOBAREVNÁ
UJ3
V48 = CHLAZENÍ,MAXIMÁLNÍ OCHRANA
VG9 = OCHRANNÍ VOSK
VGB = STŘEŠNÍ NOSIČ ZAVAZADEL,ELOXOVANÝ
VU2 = STŘEDOVÝ PŘÍSTROJ NA PANELU,CHROMOVANÁ MATT
W4Y
XA3 = OPEL
XB2 = PRO MAĎARSKO
XJ9 = PRO MAĎARSKO
Y67 = POŽADUJE PŘI OSAZENÉM SERVISNÍM DISPLEJI
Z1O = PRO MAĎARSKO
Příspěvek od Stan. »
FX3 = ESP (Elektronický Stabilizační Program)
