tak pravdepodobne v tech preukaze mam nezmysel ak mam napisany asr a esp asi na sto perc tam nemam
							opel zafira b 88kw 8v DPF 2007 enjoy
Sauce díky za informace
Dobrý den , nerad otravuji chtěl bych si koupit novější astru tak jestli by bylo možné poslat info???
VIN: W0L0AHL3572005037
Předem moc děkuji Ferry & František
Model Code: 0TN35
Package Code: IZS1
REG: L-AJ 3883
Production Date: 20060811
Typ motoru: Z16XEP
Sériové číslo motoru: 20HR2609
W0L:General Motors
A:Astra Platform
H:2004 Platform Generation
L35:Estate
7:2007
2:Bochum
005037:SERIAL NUMBER
2AU = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ
80I = VNITŘEK-ČERNÝ
80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ
80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ
A33 = ELEKTRICKY ŘÍZENÉ OKNA,ZADNÍ
A88 = OPĚRKA HLAVY,PŘEDNÍ SEDADLO,AKTIVNÍ
AH3 = PŘEDNÍ SEDADLO,ŘIDIČ,RUČNÉ NASTAVENÍ
AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA
AJT = PRO PŘÍPRAVU K MONTÁŽI BEZPEČNOSTNÍ SÍTĚ
AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ
AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED
B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ
B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ
BA9 = CHLADNIČKA
BL5 = LIŠTA KRYCÍ DVEŘE VNITŘEK,STŘÍBRNÁ
BLB = KRYCÍ LIŠTY PŘÍSTROJOVÉ DESKY,STŘÍBRNÁ
C68 = PRO ELEKTRONICKOU KLIMATIZACI
C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU
CE1 = STÍRAČ,PŘEDNÍ,IMPULSOVÝ SYSTÉM
CT3 = PRO NĚMECKO
D75 = KLIKA ÚPLNÁ VNĚJŠÍ
DD8 = PRO VNITŘNÍ ZRCÁTKO CITLIVÉ NA SVĚTLO
DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ
DDU = ZRCÁTKO,SESTAVA
DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ
DP6 = TĚLESO
DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA)
DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ
E4Q = ENJOY
E94 = KRYT
ECA = KLÍČ
FX1 = KONEČNÝ POHON NÁPRAVY 3.94
FX3 = PROGRAM ELEKTRONICKÉ STABILITY
G62 = 5 ŠROUB UPEVNĚNÍ KOLA
JL9 = ABS
K34 = REGULÁTOR RYCHLOSTI
K60 = ALTERNÁTOR,100AMP
KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA
LHD = ŘÍZENÍ LEVÉ
LJ7 = MOTOR Z16XEP[LJ7]
M25 = RUČNÍ PŘEVODOVKA,5 RYCHLOSTNÍ,F17 TYP
MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU
N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM
NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE
NT4 = EMISE,EEC 05
OHA = MÍSTNÍ GM Z EUROPE OHA
PHP = TEXTILNÍ ČALOUNĚNÍ,TABITA/ELBA
PY3 = KOLO,DISKOVÉ,OCELOVÉ,61/2JX16
QQ5 = PRO VELKÉ NÁHRAD.KOLO
R2D
T2Q = REFLEKTORY,AUTOMATICKÉ ZAPÍNÁNÍ/VYPÍNÁNÍ
T96 = SVĚTLO DO MLHY PŘEDNÍ
T9W = OBKLAD,VNITŘNÍ,TABITA
TN6 = BATERIE,55AH
TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ
TRP = RÁMEČEK,RADIOPŘIJÍMAČ
TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ
TSQ = OSVĚTLENÍ INTERIÉRU DELUXE
TTO = RÁDIO CHLADICÍ SYSTÉM
U3A
U55
U66 = REPRODUKTOR,7
U68 = INFORMAČNÍ POČÍTAČ
UAJ = GRAFICKÉ INFORMACE - BARVA
UCE = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,NAVIGACE,ETR,TLUMENÍ
UEC = SNÍMAČ INDIKÁTOR AUTOMATICKÉ RECIRKULACE VZDUCHU
UJ3
V2T = NOSIČ,ZAVAZADEL,STŘEŠNÍ,S PRÁŠKOVOU ÚPRAVOU
V3D = NOSIČ ZAVAZADEL VOLNÝ STŘEŠNÍ,ČERNÝ
VDR
VG9 = OCHRANNÍ VOSK
W4Y
WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO
WBG = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,GPS
XA3 = OPEL
XG3 = PRO NĚMECKO
Y67 = POŽADUJE PŘI OSAZENÉM SERVISNÍM DISPLEJI
Z0F = PRO NĚMECKO
Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ
						Model Code: 0TN35
Package Code: IZS1
REG: L-AJ 3883
Typ motoru: Z16XEP
W0L:General Motors
A:Astra Platform
L35:Estate
7:2007
2:Bochum
80I = VNITŘEK-ČERNÝ
BA9 = CHLADNIČKA
CT3 = PRO NĚMECKO
DP6 = TĚLESO
E4Q = ENJOY
E94 = KRYT
ECA = KLÍČ
JL9 = ABS
LHD = ŘÍZENÍ LEVÉ
NT4 = EMISE,EEC 05
R2D
TN6 = BATERIE,55AH
U3A
U55
U66 = REPRODUKTOR,7
UJ3
VDR
VG9 = OCHRANNÍ VOSK
W4Y
XA3 = OPEL
XG3 = PRO NĚMECKO
Z0F = PRO NĚMECKO
Děkuji mnohokrát Ferry
diky za vyhladanie vyba vy ale mam este jednu otazku mam alebo nemam esp v tech.pr mam napisane vo vybave asr mam tam nieco take alebo je to somarina velmi dik
No to je jednoduché, pokud se ti nerozsvítí kontrolka ESP při zapnutí zapalování, tak ho nemáš a nebo není funkční
mam este jednu otazku co to asr v tech.preukaze zda sa mi ze je to asistent protipreklzu to esp na sto percent nemam kontrolka mi tam nijaka nesvieti pri startovani diky za trpezlivost
						- Oťas
Tak máš jen protiprokluz (ASR) ....ESP je vlastně vylepšené ASR o hlídání podvozku proti smyku - laicky řečeno.
Edit:
I když je mi divný, že by zafira 2007 neměla ESP....
Edit:
Ahoj mohol by som poprosit o info VIN:W0L0AHL3582056026.Podla akeho programu zistujete tieto info TIS alebo EPC alebo nieco ine??Dakujem
