- Mike.S
napiš Vojtovi nebo zavolej RomanoviK, myslím, že oni budou vědět jak to s tím krytem je
Old cars:
Škoda 120L
Škoda Felicia Combi LXi
Actual car:
Škoda 120L
Actual car:
Ahoj poprosil by som info VIN:W0L0AHL3582150641
moja otazocka je ci ma DPF??
Dakujem
Dakujem
- Mike.S
W0L:General MotorsKubo píše:Ahoj poprosil by som info VIN:W0L0AHL3582150641
Dakujem
A:Astra Platform
H:2004 Platform Generation
L35:Estate
8:2008
2:Bochum
150641:SERIAL NUMBER
vyrobena: 19.3.2008
první RZ: DP616HC
motor: Z19DTH
č.motoru: 17340738
čalounění: XXVX
výbava:
20S = BARVA STEHŮ,HVĚZDNĚ STŘÍBRNÁ 2HU = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A14 = SKLO,BOČNÍ OKNO,ZADNÍ,ZBARVENÉ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO AF8 = KONTROLA ZAMYKÁNÍ POSTRANNÍCH DVEŘÍ,OCHRANA PROTI KRÁDEŽI AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AJT = PRO PŘÍPRAVU K MONTÁŽI BEZPEČNOSTNÍ SÍTĚ ALR AQ0 = OPĚRKA HLAVY,ZADNÍ SEDADLO,VINYLOVÝ POTAH,DVA,KRAJNÍ AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY9 = OPĚRKA HLAVY,ZADNÍ,VINYL,STŘED B70 = KRYT PRAHU DVEŘÍ B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BKX = S POLOLESKLOU KRYCÍ LIŠTOU Z MATNÉHO CHROMU BRL = IDENTIFIKAČNÍ KRITICKÝ BOD MR 2008 1/2 BS7 = TĚSNĚNÍ PRIMÁRNÍ,DVEŘE,DVĚ BARVY BS9 = TĚSNĚNÍ PRIMÁRNÍ,DVEŘE,SPODNÍ BSS = LIŠTA KRYCÍ DVEŘE VNITŘEK,CHROMOVANÁ MATT ČÁSTEČNĚ LESKLÁ BW4 = S CHROMOVOU LIŠTOU C61 = SEMI-AUTOMATICKÁ KLIMATIZACE C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CT6 = PRO ITÁLII D75 = KLIKA ÚPLNÁ VNĚJŠÍ DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4R = PRODEJNÍ BALÍK SADA-COSMO E94 = KRYT ECA = KLÍČ FE4 = SYSTÉM PRO SPECIÁLNÍ JÍZDU A JÍZDNÍ VLASTNOSTI (IDS+) FX3 = PROGRAM ELEKTRONICKÉ STABILITY FXB = POMĚR NÁPRAVY 3.65 G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K34 = REGULÁTOR RYCHLOSTI K60 = ALTERNÁTOR,100AMP KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LHD = ŘÍZENÍ LEVÉ LRD = VZNĚTOVÝ MOTOR Z19DTH MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR) N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM N65 = PNEUMATIKA,NÁHRADNÍ,ÚSPORA PROSTORU NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NR1 = PRO REDUKOVANOU DRÁHU HŘEBENOVÉ TYČE NT4 = EMISE,EEC 05 OHB OMO PXF = LEM,ALFA/VINYL QGF = PNEUMATIKY,205/55 R 16-91H QQ0 = KOLO 16X6.5,HLINÍK,7 DVOJITÝCH PAPRSKŮ T6K = PANEL VYBAVENÍ,VNITŘNÍ,VINYL T96 = SVĚTLO DO MLHY PŘEDNÍ T9S = SVÍTILNA ÚPLNÁ,VNITŘNÍ,PŘEDNÍ DVEŘE TM7 = BATERIE,60AH TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ TTX = PRO POMOCNÝ KONEKTOR RÁDIA U07 = HOUKAČKA,TROUBA U3B U55 U66 = REPRODUKTOR,7 U68 = INFORMAČNÍ POČÍTAČ UA6 = OCHRANA PROTI VLOUPÁNÍ UAG = GRAFICKÁ INFORMACE - JEDNOBAREVNÁ UCH = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,ETR,TLUMENÍ,MP3 UJ3 UJC = SPÍNAČ SPORTOVNÍ REŽIM V3E = DRŽÁK ZAVAZADEL VOLNÝ STŘEŠNÍ,STŘÍBRNÝ VG9 = OCHRANNÍ VOSK VGB = STŘEŠNÍ NOSIČ ZAVAZADEL,ELOXOVANÝ VK8 = DRŽÁK,BRÝLE VNF = ODPOJOVAČ BATERIE VVH = STŘEDOVÝ PŘÍSTROJ NA PANELU,UHLOVÁ PIANO W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO XA3 = OPEL XJ2 = NIŽŠÍ SPORTOVNÍ PODVOZEK XK4 = PRO ITÁLII Z0H = PRO ITÁLII Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ ZQ8 = UŽITO SPOLU SE SPORTOVNÍM PODVOZKEM
podle VIN DPF mít můžeš a nemusíš
Old cars:
Škoda 120L
Actual car:
Škoda 120L
Actual car:
Nejjednodušší a nejjistější je se ohnout a podívat pod auto.
Jinak se to pozná také podle štítku na B sloupku u spolujezdce. Pokud je ve čtverečku ve spodní části štítku hodnota 0,50 máš DPF. Pokud ho majitel před tebou nenechal odmontovat..
Mohl bych taky poprosit o info?
Předem děkuji.
VIN - W0L0AHL6775035997
Předem děkuji.
VIN: W0L0AHL6775035997
Kód modelu: 0CP67
Kód balení: LF61
REGISTRAČNÍ ČÍSLO:
Datum výroby: 20060929
Typ motoru: Z19DTH
Sériové číslo motoru: 17176458
W0L:General Motors
A:Astra Platform
L67:No Desc Avail
7:2007
5:Antwerp
035997:SERIAL NUMBER
4CU = VNĚJŠÍ LAK, VIZ KATALOG MODELŮ, ÚVOD, TABULKA LAKŮ
80I = VNITŘEK-ČERNÝ
A33 = ELEKTRICKY ŘÍZENÉ OKNA,ZADNÍ
A53 = PŘEDNÍ SEDADLO,SPOLUJEZDEC,6CESTNÝ RUČNÍ
AHB = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE
AJ7 = PRO BEZP. VAK ŘIDIČE, SPOJEZDCE A BOČNÍ VAK
APX = SÍŤ KOMFORTNÍ
B58 = KRYCÍ PODLAHOVÉ ROHOŽKY,PŘEDNÍ A ZADNÍ KOBERCOVÁ VLOŽKA
BNS = LIŠTA KRYCÍ DVEŘE VNITŘEK,SATÉNOVÁ STONE
BPI = LIŠTA PŘÍSTROJOVÉ DESKY,SATÉNOVÁ STONE
C32 = PRO SYSTÉM QUICKHEAT
CE1 = STÍRAČ,PŘEDNÍ,IMPULSOVÝ SYSTÉM
CE4 = OSTŘIKOVAČ SVĚTLOMETU
CM8 = POUŽÍT S DÁLK.OVLADAČEM MOTOROVÉ SKLÁD.STŘECHY
CR7 = PRO MAĎARSKO
DD8 = PRO VNITŘNÍ ZRCÁTKO CITLIVÉ NA SVĚTLO
DP6 = TĚLESO
DPP = TĚLESO
DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA)
E3C = KRYT
ECA = KLÍČ
JL9 = ABS
K13 = POUŽÍVÁ SE S FILTREM PEVNÝM ČÁSTIC VE VÝFUKOVÉM SYSTÉMU
KA1 = PRO VYHŘÍVANÁ PŘEDNÍ SEDADLA
KG9 = ALTERNÁTOR,140A
LHD = ŘÍZENÍ LEVÉ
LRD = VZNĚTOVÝ MOTOR Z19DTH[LRD]
N35 = VOLANT,SPORT,KŮŽE
NT4 = EMISE,EEC 05
OHB
OIG
QGT = PNEUMATIKY,225/45 R 17-91V
QV2 = KOLO 17X7, HLINÍK, 5 DVOJITÝCH PAPRSKŮ, STYLOVÉ
R2L
T2Q = REFLEKTORY,AUTOMATICKÉ ZAPÍNÁNÍ/VYPÍNÁNÍ
T67 = BATERIE,70AH
TSQ = OSVĚTLENÍ INTERIÉRU DELUXE
TT2 = SVĚTLOMETY SMĚROVÉ,VYSOKÁ INTENZITA VÝBOJKA,TLUMENÉ XENONOVÉ,DÁLKOVÉ XENONOVÉ/HALOGENOVÉ
TTO = RÁDIO CHLADICÍ SYSTÉM
U3F
U55
U66 = REPRODUKTOR,7
UAJ = GRAFICKÉ INFORMACE - BARVA
UCL = RÁDIO AM/FM STEREO,HLEDÁNÍ,DVD,NAVIGACE,ETR,TLUMENÍ
UD7 = ČIDLO PARKOVACÍHO SYSTÉMU
UH0 = VÝSTRAHA BEZPEČNOSTNÍHO PÁSU,LH
UH1 = VÝSTRAHA BEZPEČNOSTNÍHO PÁSU,RH
V3R = VÝSUVNÁ TYČ OCHRANY PŘI PŘEKLOPENÍ,AUTOMATICKÁ
VG9 = OCHRANNÍ VOSK
VOD = MŘÍŽKA CHLADIČE,MŘÍŽOVANÁ,ČERNÁ,S CHROMOVANOU TYČÍ
W4Y
WBG = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,GPS
XA3 = OPEL
XB2 = PRO MAĎARSKO
XJ9 = PRO MAĎARSKO
Y67 = POŽADUJE PŘI OSAZENÉM SERVISNÍM DISPLEJI
Z1O = PRO MAĎARSKO
Kód modelu: 0CP67
Kód balení: LF61
REGISTRAČNÍ ČÍSLO:
Typ motoru: Z19DTH
W0L:General Motors
A:Astra Platform
L67:No Desc Avail
7:2007
5:Antwerp
80I = VNITŘEK-ČERNÝ
APX = SÍŤ KOMFORTNÍ
CR7 = PRO MAĎARSKO
DP6 = TĚLESO
DPP = TĚLESO
E3C = KRYT
ECA = KLÍČ
JL9 = ABS
LHD = ŘÍZENÍ LEVÉ
NT4 = EMISE,EEC 05
OHB
OIG
R2L
T67 = BATERIE,70AH
U3F
U55
U66 = REPRODUKTOR,7
VG9 = OCHRANNÍ VOSK
W4Y
XA3 = OPEL
XB2 = PRO MAĎARSKO
XJ9 = PRO MAĎARSKO
Z1O = PRO MAĎARSKO
Ahoj, chtěl bych poprosit o info k tomuto VIN W0L0AHL3555243845 . Moc děkuji.
Opel Astra H Caravan, 1.9CDTI 88kW, 10/2005
VIN: W0L0AHL3555243845QQQ píše:Ahoj, chtěl bych poprosit o info k tomuto VIN W0L0AHL3555243845 . Moc děkuji.
W0L: General Motors
A: Astra Platform
H: 2004 Platform Generation
L35: Estate
5: 2005
5: Antwerp
243845: SERIAL NUMBER
Kód modelu: 0TN35
Kód balení: LN63
1. registrační značka: EU-MS 1548
Datum výroby: 29.5.2005
Typ motoru: Z19DTJ
Sériové číslo motoru: 17016718
Čalounění: XXRN
Výbava:
2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 4AU = VNĚJŠÍ BARVA,VIZ SEZNAM BAREV V ÚVODĚ KATALOGU 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A14 = SKLO,BOČNÍ OKNO,ZADNÍ,ZBARVENÉ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO A53 = PŘEDNÍ SEDADLO,SPOLUJEZDEC,6CESTNÝ RUČNÍ A88 = OPĚRKA HLAVY,PŘEDNÍ SEDADLO,AKTIVNÍ ADC = IDENTIFIKACE EFEKTIVNÍ BODOVÉ ŘÍZENÍ-ŘÍDICÍ JEDNOTKA JEDNOTKA CENTRÁLNÍHO ZAMYKÁNÍ DVEŘÍ AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AHB = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AIT = PRO DVOUSTUPŇOVÝ AIRBAG AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA AJT = PRO PŘÍPRAVU K MONTÁŽI BEZPEČNOSTNÍ SÍTĚ AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BA9 = CHLADNIČKA BGZ = IDENT.EFEKTIVNÍ BOD CON. BL5 = LIŠTA KRYCÍ DVEŘE VNITŘEK,STŘÍBRNÁ BLB = KRYCÍ LIŠTY PŘÍSTROJOVÉ DESKY,STŘÍBRNÁ BW4 = S CHROMOVOU LIŠTOU BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE C68 = PRO ELEKTRONICKOU KLIMATIZACI C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU COB = VYROBENÉ V ANTWERPÁCH 2 CT3 = PRO NĚMECKO D75 = KLIKA ÚPLNÁ VNĚJŠÍ DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4Q = ENJOY E94 = KRYT ECA = KLÍČ FX3 = PROGRAM ELEKTRONICKÉ STABILITY FXB = POMĚR NÁPRAVY 3.65 G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K09 = ALTERNÁTOR,120AMP K13 = POUŽÍVÁ SE S FILTREM PEVNÝM ČÁSTIC VE VÝFUKOVÉM SYSTÉMU K34 = REGULÁTOR RYCHLOSTI KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LHD = ŘÍZENÍ LEVÉ LRA = Z19DTJ NAFTOVÝ MOTOR MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR) N52 = VOLANT,TŘI PAPRSKY NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NS2 = PRO VARIABILNÍ POSILOVAČ ŘÍZENÍ NT4 = EMISE,EEC 05 OHA = MÍSTNÍ GM Z EUROPE OHA OMO PBE = LEM,TABITA/MALTA,STYLOVÉ PY3 = KOLO,DISKOVÉ,OCELOVÉ,61/2JX16 QGF = PNEUMATIKY,205/55 R 16-91H QQ5 = PRO VELKÉ NÁHRAD.KOLO T9W = OBKLAD,VNITŘNÍ,TABITA TM7 = BATERIE,60AH TPX TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ U3A U66 = REPRODUKTOR,7 UAH = DISPLEJ INFOTAINMENT,GRAFICKÝ INFORMAČNÍ DISPLEJ (GID),VAR2 UCH = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,ETR,TLUMENÍ,MP3 UEC = SNÍMAČ INDIKÁTOR AUTOMATICKÉ RECIRKULACE VZDUCHU UEQ = ODPOJOVAČ AKUMULÁTORU UJ3 V2T = NOSIČ,ZAVAZADEL,STŘEŠNÍ,S PRÁŠKOVOU ÚPRAVOU V3E = DRŽÁK ZAVAZADEL VOLNÝ STŘEŠNÍ,STŘÍBRNÝ VFE = NÁRAZNÍK PŘEDNÍ A ZADNÍ,OCHRANNÝ VÝLISEK,BAREVNÝ W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y W7K = MOTOR,KAISERSLAUTERN WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO XA3 = OPEL XG3 = PRO NĚMECKO Z0F = PRO NĚMECKO Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ Z1Y = BARVA,DVA POVLAKY
Zdravim, můžu taky požádat o info o mém vozu, zde je VIN-ko
W0L0AHL35520797704
díky moc Petr
W0L0AHL35520797704
díky moc Petr
Je ten VIN opravdu správný? Nic mi to nenašlo, kromě toho, že je to Astra Caravan z roku 2005 vyrobená v Bochumi...
