mach00
Příspěvek od mach00 » 17 srp 2011, 17:24
W0L0AHL3552098960
W0L: General Motors
A: Astra Platform
H: 2004 Platform Generation
L35: Estate
5: 2005
2: Bochum
098960: SERIAL NUMBER
Kód modelu: 0TN35
Kód balení: JM52
Datum výroby: 5.1.2005
Typ motoru: Z17DTH
Sériové číslo motoru: 01202282
Čalounění: XXRN
Výbava:
2HU = VNĚJŠÍ BARVA,VIZ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 6Y4 = NÁHRADNÍ KOLO A PNEUMATIKA,VYNECHEJTE 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ 8V2 A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO A88 = OPĚRKA HLAVY,PŘEDNÍ SEDADLO,AKTIVNÍ AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DV AAJT = PRO PŘÍPRAVU K MONTÁŽI BEZPEČNOSTNÍ SÍTĚ AM4 = ZADNÍ DĚLENÉ OPĚRADLO SEDADLA,SKLOPNÉ,VLASTNÍ AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BGZ = IDENT.EFEKTIVNÍ BOD CON. BL5 = LIŠTA KRYCÍ DVEŘE VNITŘEK,STŘÍBRNÁ BLB = KRYCÍ LIŠTY PŘÍSTROJOVÉ DESKY,STŘÍBRNÁ BOC = VYROBENÉ V BOCHUM C32 = PRO SYSTÉM QUICKHEAT C60 = KLIMATIZACE C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CT2 = PRO RAKOUSKO D75 = KLIKA ÚPLNÁ VNĚJŠÍ DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4Q = ENJOY E94 = KRYTECA = KLÍČ FR7 = POMĚR NÁPRAVY 3.95 (PŘEDNÍ) G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K34 = REGULÁTOR RYCHLOSTI K63 = ALTERNÁTOR,110 AKCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LHD = ŘÍZENÍ LEVÉ LPZ = VZNĚTOVÝ MOTOR Z17DTH MG1 = RUČNÍ PŘEVODOVKA,5 RYCHLOSTNÍ, F23 TYP MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU N52 = VOLANT,TŘI PAPRSKY NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NS2 = PRO VARIABILNÍ POSILOVAČ ŘÍZENÍ NT4 = EMISE,EEC 05 OHA = MÍSTNÍ GM Z EUROPE OHA PBE = LEM,TABITA/MALTA,STYLOVÉ PY3 = KOLO,DISKOVÉ,OCELOVÉ,61/2JX16 QGF = PNEUMATIKY,205/55 R 16-91H T67 = BATERIE,70AH T9W = OBKLAD,VNITŘNÍ,TABITA TPX TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ U3A UAC = INFORMAČNÍ PANEL LCD - VÍCEFUNKČNÍ UEQ = ODPOJOVAČ AKUMULÁTORU UH0 = VÝSTRAHA BEZPEČNOSTNÍHO PÁSU,LH UH1 = VÝSTRAHA BEZPEČNOSTNÍHO PÁSU,RH UJ3 URA = SPÍNAČ OVLÁDÁNÍ RÁDIA UW5 = REPRODUKTOROVÝ SYSTÉM 6,BASE V2T = NOSIČ,ZAVAZADEL,STŘEŠNÍ,S PRÁŠKOVOU ÚPRAVOU V3D = NOSIČ ZAVAZADEL VOLNÝ STŘEŠNÍ,ČERNÝ VFE = NÁRAZNÍK PŘEDNÍ A ZADNÍ,OCHRANNÝ VÝLISEK,BAREVNÝ W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y W9R = PRO RAKOUSKO WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO WTR = DOČASNÁ OPRAVA PNEUMATIKY XA3 = OPEL Z0E = PRO RAKOUSKO Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ Z1Y = BARVA,DVA POVLAKY
mznr
Příspěvek od mznr » 18 srp 2011, 11:48
ďakujem ešte raz!
david.tomko
Příspěvek od david.tomko » 18 srp 2011, 16:30
Mike.S píše:SADA-ZÁBRANA PRO PSA (PODLE POTŘEBY SE POUŽIJE 93165060 17 07 937) (KROMĚ ZADNÍHO POSUVNÉHO SEDADLA): 17 07 888 nebo http://autokelly.cz/#PATH=4732230;47322 ... ST=0|LNG=0|
Díky, jen mi nefunguje ten odkaz na autokelly. Jak jsi se k tomu proklikal?
lkralicek
Příspěvek od lkralicek » 18 srp 2011, 18:55
Já bych potřeboval vědět z kolika dílů se skládá lišta se čtyřmi tlačítky (vyhřívání sedadel, zamykání a tlačítko SPORT) na středovém panelu. Jde to koupit jen jako celek nebo jdou koupit spínače, tlačítka atd??? Děkuji
Naposledy upravil(a) lkralicek dne 19 srp 2011, 20:46, celkem upraveno 1 x.
Mike.S
Příspěvek od Mike.S » 18 srp 2011, 19:01
www.autokelly.cz -> vlevo Autopříslušenství -> v Autodoplňky Vnitřní doplňky vozidel -> Doplňky do zavazadlového prostoru -> Sítě do zavazadlového prostoru -> a je to ta se psem :mrgreen:
Old cars:
Škoda 120L
Škoda Felicia Combi LXi
Actual car:
Strapo2000
Příspěvek od Strapo2000 » 19 srp 2011, 15:38
Ahoj,
môžem aj ja požiadať o info?
VIN: W0L0AHL3592027979
VOPRED DIK :)
Mike.S
Příspěvek od Mike.S » 19 srp 2011, 15:57
Strapo2000 píše:Ahoj,
VOPRED DIK :)
W0L:General Motors
A:Astra Platform
H:2004 Platform Generation
L35:Estate
9:2009
2:Bochum
027979:SERIAL NUMBER
vyrobena: 17.9.2008
první RZ: M-ST 2990
motor: Z17DTJ
č.motoru: 1861363
čalounění: TABR
výbava:
18X = BARVA ČALOUNĚNÍ SEDADLA TMAVĚ UHLOVÁ 2AU = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 6Y4 = NÁHRADNÍ KOLO A PNEUMATIKA,VYNECHEJTE 80I = VNITŘEK-ČERNÝ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ 8V2 A14 = SKLO,BOČNÍ OKNO,ZADNÍ,ZBARVENÉ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO A88 = OPĚRKA HLAVY,PŘEDNÍ SEDADLO,AKTIVNÍ AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA AJT = PRO PŘÍPRAVU K MONTÁŽI BEZPEČNOSTNÍ SÍTĚ AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BNS = LIŠTA KRYCÍ DVEŘE VNITŘEK,SATÉNOVÁ STONE BPI = LIŠTA PŘÍSTROJOVÉ DESKY,SATÉNOVÁ STONE BW4 = S CHROMOVOU LIŠTOU BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE C32 = PRO SYSTÉM QUICKHEAT C3U = STŘEŠNÍ OKNO,POSUVNÉ,ELEKTRICKÉ,SKLO C68 = PRO ELEKTRONICKOU KLIMATIZACI C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CE1 = STÍRAČ,PŘEDNÍ,IMPULSOVÝ SYSTÉM CE4 = OSTŘIKOVAČ SVĚTLOMETU CT3 = PRO NĚMECKO D75 = KLIKA ÚPLNÁ VNĚJŠÍ DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO DD8 = PRO VNITŘNÍ ZRCÁTKO CITLIVÉ NA SVĚTLO DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4Q E94 = KRYT ECA = KLÍČ FX3 = PROGRAM ELEKTRONICKÉ STABILITY FXB = POMĚR NÁPRAVY 3.65 G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K13 = POUŽÍVÁ SE S FILTREM PEVNÝM ČÁSTIC VE VÝFUKOVÉM SYSTÉMU K34 = REGULÁTOR RYCHLOSTI KA1 = PRO VYHŘÍVANÁ PŘEDNÍ SEDADLA KC8 = ZÁSUVKA,VÝSTUP POMOCNÉHO NAPÁJENÍ KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA KG9 = ALTERNÁTOR,140A LHD = ŘÍZENÍ LEVÉ LPV = VZNĚTOVÝ MOTOR Z17DTJ,A17DTJ MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR) N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NR1 = PRO REDUKOVANOU DRÁHU HŘEBENOVÉ TYČE NT4 = EMISE,EEC 05 OHA = MÍSTNÍ GM Z EUROPE OHA OMO QGF = PNEUMATIKY,205/55 R 16-91H QL5 = KOLO,VOZOVKA,HLINÍK,10 PŘÍČEK,61/2JX16 T2Q = REFLEKTORY,AUTOMATICKÉ ZAPÍNÁNÍ/VYPÍNÁNÍ T67 = BATERIE,70AH T96 = SVĚTLO DO MLHY PŘEDNÍ T9M = ČALOUNĚNÍ ELBA T9P = DEKORACE TMAVÁ,TĚLESO SVĚTLOMETU TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ TSQ TT2 = SVĚTLOMETY SMĚROVÉ,VYSOKÁ INTENZITA VÝBOJKA,TLUMENÉ XENONOVÉ,DÁLKOVÉ XENONOVÉ/HALOGENOVÉ TTX = PRO POMOCNÝ KONEKTOR RÁDIA U3A U55 U66 = REPRODUKTOR,7 U68 = INFORMAČNÍ POČÍTAČ UAG = GRAFICKÁ INFORMACE - JEDNOBAREVNÁ UCH = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,ETR,TLUMENÍ,MP3 UJ3 UJC = SPÍNAČ SPORTOVNÍ REŽIM V3E = DRŽÁK ZAVAZADEL VOLNÝ STŘEŠNÍ,STŘÍBRNÝ VG2 = OCHRANNÍ VOSK, VYNECHEJTE VGB = STŘEŠNÍ NOSIČ ZAVAZADEL,ELOXOVANÝ VJU = STŘEDOVÝ PŘÍSTROJ NA PANELU,SATÉNOVÁ STONE VQ9 = ODMONTOVATELNÁ SPOJKA ZÁVLEKU W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y W7Z = ZAŘÍZENÍ,ZIMA WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO WFR = TEXTILNÍ ČALOUNĚNÍ,TWIST/ELBA WTR = DOČASNÁ OPRAVA PNEUMATIKY XA3 = OPEL XG3 = PRO NĚMECKO XJ2 = NIŽŠÍ SPORTOVNÍ PODVOZEK Y67 = POŽADUJE PŘI OSAZENÉM SERVISNÍM DISPLEJI Z0F = PRO NĚMECKO Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ ZQ8 = UŽITO SPOLU SE SPORTOVNÍM PODVOZKEM
Old cars:
Škoda 120L
Actual car:
Strapo2000
Příspěvek od Strapo2000 » 19 srp 2011, 21:24
diky moc :)
Westler
Příspěvek od Westler » 22 srp 2011, 00:35
Potreboval bych poradit. Jeden hodny motorkar mi ulomil zrcatko a ujel. Sklo je OK, ale upadly oba kryci plasty. Potreboval bych cisla dilu horniho lakovaneho krytu a jeste spodniho nelakovaneho (nemyslim ram s naklapenim, ale kryt vpredu pod lakovanym dilem). Jde o zrcatko spolujezdce s vyhrivanim bez el. sklapeni, po faceliftu.
Diky moc.
lkralicek
Příspěvek od lkralicek » 22 srp 2011, 08:13
lkralicek píše:Já bych potřeboval vědět z kolika dílů se skládá lišta se čtyřmi tlačítky (vyhřívání sedadel, zamykání a tlačítko SPORT) na středovém panelu. Jde to koupit jen jako celek nebo jdou koupit spínače, tlačítka atd??? Děkuji
Dotaz stále aktuální :D
