Mike.S
Příspěvek od Mike.S »
TomahawkCZ píše:pomoci ceho dekodujes VINka??? zkousel jsem to v EPC, ale vin nenalezeno... ze by NEorigo? :D
ninak bych taky poprosil... DEKUJI
WOLOAHL3552193611
bodejď by Ti ho našel, když ho máš blbě opsané, Ty máš WOLO a má být W-nula-L-nula-..... ;)
tady to máš:
W0L:General Motors
A:Astra Platform
H:2004 Platform Generation
L35:Estate
5:2005
2:Bochum
193611:SERIAL NUMBER
vyrobena: 11.5.2005
čalounění: XXQY
motor: Z18XE
č. motoru: 20FE0434
výbava:
1RU = VNĚJŠÍ BARVA,VIZ SEZNAM BAREV V ÚVODĚ KATALOGU 2H9 = 18 BENZÍNOVÝ MOTOR 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO ADC = IDENTIFIKACE EFEKTIVNÍ BODOVÉ ŘÍZENÍ-ŘÍDICÍ JEDNOTKA JEDNOTKA CENTRÁLNÍHO ZAMYKÁNÍ DVEŘÍ AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AIT = PRO DVOUSTUPŇOVÝ AIRBAG AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA AJ7 = PRO BEZP. VAK ŘIDIČE, SPOJEZDCE A BOČNÍ VAK AM4 = ZADNÍ DĚLENÉ OPĚRADLO SEDADLA,SKLOPNÉ,VLASTNÍ AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED B70 = KRYT PRAHU DVEŘÍ B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BA9 = CHLADNIČKA BGZ = IDENT.EFEKTIVNÍ BOD CON. BL5 = LIŠTA KRYCÍ DVEŘE VNITŘEK,STŘÍBRNÁ BLB = KRYCÍ LIŠTY PŘÍSTROJOVÉ DESKY,STŘÍBRNÁ BOC = VYROBENÉ V BOCHUM BS9 = TĚSNĚNÍ PRIMÁRNÍ,DVEŘE,SPODNÍ BW4 = S CHROMOVOU LIŠTOU BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE C32 = PRO SYSTÉM QUICKHEAT C68 = PRO ELEKTRONICKOU KLIMATIZACI C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CR7 = PRO MAĎARSKO D75 = KLIKA ÚPLNÁ VNĚJŠÍ DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E94 = KRYT ECA = KLÍČ FX1 = KONEČNÝ POHON NÁPRAVY 3.94 G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K09 = ALTERNÁTOR,120AMP K34 = REGULÁTOR RYCHLOSTI KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LHD = ŘÍZENÍ LEVÉ M25 = RUČNÍ PŘEVODOVKA,5 RYCHLOSTNÍ,F17 TYP MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NT4 = EMISE,EEC 05 OHD PAU = LEM,BRISTOL/AMANA QGF = PNEUMATIKY,205/55 R 16-91H QL6 = KOLO,VOZOVKA,HLINÍK,5 PŘÍČEK,61/2JX16 QQ5 = PRO VELKÉ NÁHRAD.KOLO T96 = SVĚTLO DO MLHY PŘEDNÍ T9K = OBKLAD,VNITŘNÍ,AMANA T9S = SVÍTILNA ÚPLNÁ,VNITŘNÍ,PŘEDNÍ DVEŘE TN7 = BATERIE,66AH TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ U07 = HOUKAČKA,TROUBA U3F U55 U66 = REPRODUKTOR,7 U68 = INFORMAČNÍ POČÍTAČ UAH = DISPLEJ INFOTAINMENT,GRAFICKÝ INFORMAČNÍ DISPLEJ (GID),VAR2 UCH = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,ETR,TLUMENÍ,MP3 UEQ = ODPOJOVAČ AKUMULÁTORU UJ3 V2T = NOSIČ,ZAVAZADEL,STŘEŠNÍ,S PRÁŠKOVOU ÚPRAVOU V3E = DRŽÁK ZAVAZADEL VOLNÝ STŘEŠNÍ,STŘÍBRNÝ VFE = NÁRAZNÍK PŘEDNÍ A ZADNÍ,OCHRANNÝ VÝLISEK,BAREVNÝ VK8 = DRŽÁK,BRÝLE W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO XA3 = OPEL XB2 = PRO MAĎARSKO XJ9 = PRO MAĎARSKO Y67 = POŽADUJE PŘI OSAZENÉM SERVISNÍM DISPLEJI Z0L = ELEGANCE Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ Z1O = PRO MAĎARSKO Z1Y = BARVA,DVA POVLAKY
Old cars:
Škoda 120L
Škoda Felicia Combi LXi
Actual car:
JirkaF
Příspěvek od JirkaF »
Děkuji Vojtavojto. Chytám každý desátý... :D
TomahawkCZ
Příspěvek od TomahawkCZ »
ajaj :oops:
dekuji...
Oťas
Příspěvek od Oťas »
Byl by někdo tak laskav a zkusil W0L0AHL3562139515
děkuji předem.
Oťas
Příspěvek od Oťas »
:arrow:
Mike.S
Oťas píše:Byl by někdo tak laskav a zkusil W0L0AHL3562139515
děkuji předem.
W0L:General Motors
A:Astra Platform
L35:Estate
6:2006
2:Bochum
139515:SERIAL NUMBER
vyrobena: 8.3.2006
čalounění: XXVM
motor: Z19DT
č. motoru: 4925517
výbava:
2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 4DU = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA AJ7 = PRO BEZP. VAK ŘIDIČE, SPOJEZDCE A BOČNÍ VAK AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BA9 = CHLADNIČKA BL5 = LIŠTA KRYCÍ DVEŘE VNITŘEK,STŘÍBRNÁ BLB = KRYCÍ LIŠTY PŘÍSTROJOVÉ DESKY,STŘÍBRNÁ BRE = IDENTIFIKAČNÍ KRITICKÝ BOD 2006 1/2 MR C68 = PRO ELEKTRONICKOU KLIMATIZACI C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CE4 = OSTŘIKOVAČ SVĚTLOMETU CR7 = PRO MAĎARSKO D75 = KLIKA ÚPLNÁ VNĚJŠÍ DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DGZ = SCHRÁNKA V PŘÍSTROJOVÉ DESCE DĚLÍCÍ PŘEPÁŽKA DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4Q E94 = KRYT ECA = KLÍČ FX3 = PROGRAM ELEKTRONICKÉ STABILITY FXB = POMĚR NÁPRAVY 3.65 G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K60 = ALTERNÁTOR,100AMP KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LHD = ŘÍZENÍ LEVÉ LPM = VZNĚTOVÝ MOTOR Z19DT MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR) N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NS2 = PRO VARIABILNÍ POSILOVAČ ŘÍZENÍ NT4 = EMISE,EEC 05 OHA = MÍSTNÍ GM Z EUROPE OHA PHP = TEXTILNÍ ČALOUNĚNÍ,TABITA/ELBA QGF = PNEUMATIKY,205/55 R 16-91H QL5 = KOLO,VOZOVKA,HLINÍK,10 PŘÍČEK,61/2JX16 QQ5 = PRO VELKÉ NÁHRAD.KOLO T96 = SVĚTLO DO MLHY PŘEDNÍ T9W = OBKLAD,VNITŘNÍ,TABITA TM7 = BATERIE,60AH TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ TT6 = REFLEKTOR,XENON U3F U55 U68 = INFORMAČNÍ POČÍTAČ U71 = ANTÉNA,ÚPLNÁ,STŘECHA UAH = DISPLEJ INFOTAINMENT,GRAFICKÝ INFORMAČNÍ DISPLEJ (GID),VAR2 UEQ = ODPOJOVAČ AKUMULÁTORU UJ3 URA = SPÍNAČ OVLÁDÁNÍ RÁDIA UW5 = REPRODUKTOROVÝ SYSTÉM 6,BASE V2T = NOSIČ,ZAVAZADEL,STŘEŠNÍ,S PRÁŠKOVOU ÚPRAVOU V3D = NOSIČ ZAVAZADEL VOLNÝ STŘEŠNÍ,ČERNÝ VDR VG9 = OCHRANNÍ VOSK VNF = ODPOJOVAČ BATERIE W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO XA3 = OPEL XB2 = PRO MAĎARSKO XJ9 = PRO MAĎARSKO Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ Z1O = PRO MAĎARSKO
Old cars:
Škoda 120L
Actual car:
Oťas
Příspěvek od Oťas »
Mike.S
Díky moc... 8-)
machy
Příspěvek od machy »
vojtavojta: diky! m.
děkuji předem.
tak tady to máš:
W0L: General Motors
0: Ne Speciální vozidla
: Astra platforma
H: 2004 Platforma generace
L35: Estate
6:2006
2: Bochum
139515: pořadové číslo
mot Typ: Z19DT
Č. ser.mot: 4925517
Datum výroby: 20060308
Model Code: 0TN35
Malování kód GM-4DU
2J1 = NÁTĚRY, INTERIER PATRO, STANDARD 80i = INTERIÉR-BLACK 80X = INTERIER DESIGN BODY-BLACK FINISH laloku 80Y = DVEŘE, BLACK = přední SEAT A51 skořápky AH4 = PŘEDSEDNICTVÍ PŘEDNÍ, ovladač, manual AHA = ŘÍZENÉ bederní AJ0 = OPĚRKY HLAVY , opěrka, látková, dva AJ7 = řidiče, spolujezdce a boční airbagy AY5 = opěrky hlavy, opěrka, látková, STŘEDNÍ B75 = ZAVAZADLA POKRYTÍ
, TEAM. B86 = COLOR VÝLISKŮ boční BA9 = TANK COLD BL5 = Lisovaný vnitřní dveře, SILVER BLB = Lisovaný CONSOLE INSTRUMENTS, SILVER BRE = kontrole totožnosti BOD 2006 polovina MY pro klimatizaci C68 = C95 = ELECTRONIC LIGHT, stropní, TEAM., DUAL lehké čtení ROZSTŘIKOVAČ reflektor CE4 = CR7 = D75 = PRO MAĎARSKO Kliky, TEAM., DA7 = vnější přední loketní opěrky sedadla, DDG = LEVÝ MIRROR, ELECTRIC, vpravo-vlevo DDU = MIRROR, TEAM. DGZ = schránky v § RADA. SPLIT DT4 = POPELNÍKY a lehčí DVA = SET RATE, BLACK, černá s Stříbrné prsteny BODŮ FX3 = Elektronický stabilizační program FXB = 3,65 nápravy poměr G62 = Šrouby 5 JL9 = ABS K60 = alternátor, 100A KCL = VYTÁPĚNÍ CHANNEL, zadní boční 2-GA = LHD řídící stanoviště LEVÝ LPM = vznětový motor Z19DT MM3 = s manuální převodovkou MZ4 = manuální převodovka, 6 rychlostních = N34 ŘÍZENÍ, tři paprsky, KŮŽE, TEAM. NC0 = ZAŘÍZENÍ, EVROPSKÉ UNIE NA PODPORU NS2 = ŘÍZENÍ rychlost-dependentní NT4 = emise, EHS PHP 05 = úpravy tkanin, Tabitha / ELBA QGF = pneumatik 205/55 R 16-91H QL5 = NEAR, mobilní, hliník, 10 Paprsky , 61/2JX16 QQ5 = rezervní kolo full-T96 = přední mlhové T9W = PLATE FINISH, VNITŘNÍ, Tabitha TM7 = baterie, 60Ah TPV = mříž, černá, s chromovými pásky TR0 = osvětlení. Interiér, střecha, zadní A TWIN Upozornit na ČTENÍ RADIO RAMA TRP = TSP = LIGHT SET, TEAM., SPOTLIGHT. TT6 = INTERIÉR SVĚTLOMETY, XENON informace o počítači U68 = U71 = střešní anténa, TEAM. UAH = DISPLAY SYSTÉM AUDIO-VIDEO DISPLAY Infor. GRAFIKA (GID), var2 = UEQ SWITCH OFF vypínač baterie ŘÍZENÍ URA = UW5 RADIO REPRODUKTORŮ = 6, V2T = Basic Rack lepidlo, RACK, STŘEŠNÍ, prášek-lakované střešní nosiče V3D = - TRANSPARENT STŘEŠNÍ, BLACK VG9 = VNF = WAX ODOLNÉ ISOLATOR pouzdro na baterie W1Y = ovládání rádia na řízení W4Y WBE = ZAŘÍZENÍ UNIT přijímač, rádio Z1F = SENSOR, LIMIT systém ponechaný
Oťas
Příspěvek od Oťas »
to vojtavojta
Tobě taky mockrát díky, na předchozí straně už mi udělal výpis "Mike.S", ale to nevadí..
