Příspěvek od jakubino »
marianito68 píše:priatelia,
poprosim info o vozidle W0L0AHM757G123133
dakujem
Marián
W0L:General Motors
0:VOZIDLO BEZ ZVLD�STN� ÚPRAVY
A:Astra Platform
H:2004 Platform Generation
M75:Monocab (Zafira)
7:2007
G:Gliwice
123133:SERIAL NUMBER
2AU = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ
80I = VNITŘEK-ČERNÝ
80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ
80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ
AH3 = PŘEDNÍ SEDADLO,ŘIDIČ,RUČNÉ NASTAVENÍ
AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA
AJ7 = PRO BEZP. VAK ŘIDIČE, SPOJEZDCE A BOČNÍ VAK
AJT = PRO PŘÍPRAVU K MONTÁŽI BEZPEČNOSTNÍ SÍTĚ
AV4 = DĚLENÉ ZADNÍ SEDADLO
AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED
B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ
B76 = PRO PŘÍSTROJ S ČERNÝM CIFERNÍKEM
BL0 = LIŠTA KRYCÍ DVEŘE VNITŘEK,UHLOVÁ METALÍZA
BLJ = LIŠTA PŘÍSTROJOVÉ DESKY VNITŘNÍ,UHLOVÁ METALÍZA
BRG = IDENTIFIKAČNÍ KRITICKÝ BOD 2007 1/2 MR
C60 = KLIMATIZACE
CR7 = PRO MAĎARSKO
CR7
DDS = ZRCÁTKO,SESTAVA
DDU = ZRCÁTKO,SESTAVA
DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA)
FXB = POMĚR NÁPRAVY 3.65
G62 = 5 ŠROUB UPEVNĚNÍ KOLA
JL9 = ABS
K13 = POUŽÍVÁ SE S FILTREM PEVNÝM ČÁSTIC VE VÝFUKOVÉM SYSTÉMU
K60 = ALTERNÁTOR,100AMP
KC7 = ELEKTRICKÁ ZÁSUVKA,ZADNÍ SEDADLO
KC8 = ZÁSUVKA,VÝSTUP POMOCNÉHO NAPÁJENÍ
KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA
LHD = ŘÍZENÍ LEVÉ
LPP = Z19DTL[LPP] NAFTOVÝ MOTOR
MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU
MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR)
N52 = VOLANT,TŘI PAPRSKY
NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE
NR1 = PRO REDUKOVANOU DRÁHU HŘEBENOVÉ TYČE
NT4 = EMISE,EEC 05
OCU
OHI = MÍSTNÍ GM Z EUROPE OHI
PFM = ČALOUNĚNÍ,ALPHA/ELBA
PY3 = KOLO,DISKOVÉ,OCELOVÉ,61/2JX16
QQ5 = PRO VELKÉ NÁHRAD.KOLO
T96 = SVĚTLO DO MLHY PŘEDNÍ
T9M = ČALOUNĚNÍ ELBA
TM7 = BATERIE,60AH
TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ
TRP = RÁMEČEK,RADIOPŘIJÍMAČ
TTO = RÁDIO CHLADICÍ SYSTÉM
U3F
UAC = INFORMAČNÍ PANEL LCD - VÍCEFUNKČNÍ
UJ3
URA = SPÍNAČ OVLÁDÁNÍ RÁDIA
UW6 = REPRODUKTOR,6
VG9 = OCHRANNÍ VOSK
VNF = ODPOJOVAČ BATERIE
W4Y
WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO
XA3 = OPEL
XB2 = PRO MAĎARSKO
XJ9 = PRO MAĎARSKO
Z1F = RYCHLOMĚR KM/H
Z1O = PRO MAĎARSKO
marianito68
Příspěvek od marianito68 »
priatelia,
je mozne, ze specifikacia/vybava vozidla podla VIN nesedi uplne presne s tym, co je deklarovane v profile auta na predaj uvedeneho v inzerate? dokonca podla VIN by tam mal byt Z19DTL a v inzerate je uvedene, ze je to benzin 1.8 103kW.
Nemelo by to tak byt.
pueblo
Příspěvek od pueblo »
Ahoj kolegové, prosím, pomozte mi. Sháním číslo dílu hlukové izolace do motoru na Zafiru. U Astry je to jeden kus, ale u Zafiry je jedna část za motorem na přepážce mezi kabinou a motorovým prostórem a druhá, menší je mezi motorem a sklem, pod dutinou, kde běhá táhlo stěračů. Nevím jak to víc přiblížit. V EPC jsem hledal, ale asi to neumím, nepodařilo se.
Potřeboval bych tedy číslo toho menšího, horního dílu izloace.....
Díky
zkoušel si: karoserie vnitřní vybavení - izolace ?
pueblo
Zkoušel, ale nejsem si vůbec jistej, protože tam není uvedenej můj motor Z18XER. Navíc mi to podle obrázku přijde jako ta přepážka samotná (13151286)a ne ten filcovej nesmysl :( Nerad bych si objednal něco jinýho....
když si tam napíšeš svoje VIN, tak by to mělo najít jenom ty díly, co tam pasujou
pueblo
No ať dělám co dělám, asi to neumím. I když si zadám VIN, nenacházím co hledám. Mezi díly je PŘÍPONKA PÉROVÁ, IZOLÁTOR, PŘEDNÍ STĚNA, HORNÍ, ale ten izolátor, přední stěny horní tam nevidím. Byl jsem znovu v autě, jestli se nemýlím a není to z jednoho kusu, ale není......
lubomlp
Příspěvek od lubomlp »
cauko
poprosim info o vozidle WOLOXCE7584007023
dakujem
W0L:General Motors
X:Corsa
C:Meriva
E75:Monocab (E75)
8:2008
4:Zaragoza
007023:SERIAL NUMBER
Motor Z13DTJ
18I = OBLOŽENÍ VNITŘNÍHO PROSTORU TMAVĚ UHLOVÁ
18X = BARVA ČALOUNĚNÍ SEDADLA TMAVĚ UHLOVÁ
18Y = OZDOBNÁ LIŠTA DVEŘNÍHO PANELU,BAREVNÁ
A32 = ELEKTRICKY ŘÍZENÉ OKNA,PŘEDNÍ
A8D = TYPOVÝ ŠTÍTEK,OPEL
AAU = VNĚJŠÍ BARVA,VIZ SEZNAM BAREV V ÚVODĚ KATALOGU
AG4 = PŘEDNÍ SEDADLO,LEVÉ,REGULÁTOR VÝŠKY,RUČNÝ
AK5 = PRO BEZP.VAK ŘIDIČE A SPOLUJEZDCE
AQ6 = PŘEDNÍ SEDADLO,NASTAVITELNÁ OPĚRKA
AU0 = ZÁMEK DVEŘÍ,S DÁLKOVÝM OVLÁDÁNÍM
AWF = S ÚLOŽNOU KAPSOU
B40 = ZAKRÝVAJÍCÍ LOŽNÝ PROSTOR,PEVNÝ
B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ
BF8 = ÚLOŽNÁ SCHRÁNKA,PŘEDNÍ SEDADLO,PRAVÉ
BNG = DVEŘNÍ KRYCÍ LIŠTA VNITŘEK,UHLOVÁ MAZE
BNN = ÚLOŽNÁ SCHRÁNKA,LOŽNÝ PROSTOR
BYF = LIŠTA PŘÍSTROJOVÉ DESKY VNITŘEK,UHLOVÁ MAZE
C60 = KLIMATIZACE
C76 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,ZADNÍ ČTVRT,KOMFORTNÍ A DVOJITÁ ČTECÍ
C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU
CR7 = PRO MAĎARSKO
D18 = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,CHROMOVANÉ KRUHY
D75 = KLIKA ÚPLNÁ VNĚJŠÍ
D91
DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO
DJ9 = ZRCADLO,ELEKTRICKÉ A VYTÁPĚNÉ,ŠIROKÉ,PRAVÉ,LEVÉ
ECA = KLÍČ
FX1 = KONEČNÝ POHON NÁPRAVY 3.94
G61 = 4 ŠROUB UPEVNĚNÍ KOLA
GDI = TEXTILNÍ ČALOUNĚNÍ,PUNCH/ELBA
JBG = PÁKA RUČNÍ BRZDY,CHROM S VYSOKÝM LESKEM
JL9 = ABS
K27 = PALIVOVÝ FILTR
KIS = KRYTKA,RUKOJEŤ ŘADICÍ PÁKY,S CHROMOVÝM KROUŽKEM
LDP = VZNĚTOVÉ MOTORY Z13DTJ[LDP],A13DTJ
LHD = ŘÍZENÍ LEVÉ
M26 = RUČNÍ PŘEVODOVKA,5 RYCHLOSTNÍ,F17 TYP
N33 = PRO NASTAVITELNÝ SLOUPEK ŘÍZENÍ
NP5 = VOLANT,KŮŽE
NT4 = EMISE,EEC 05
OFZ
OHA = MÍSTNÍ GM Z EUROPE OHA
PG1 = KOLO,VOZOVKA,OCEL,6JX15
QLF = PNEUMATIKY,185/60 R 15-88H
T74
TM7 = BATERIE,60AH
TTX
U3F
UCH = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,ETR,TLUMENÍ,MP3
UF8 = TROJITÝ INFORMAČNÍ DISPLEJ LCD - DATUM/ČAS/TEPLOTA
UJ3
UW6 = REPRODUKTOR,6
VG9 = OCHRANNÍ VOSK
VHC = ZÁCHYTNÝ HÁK PRO NÁKLAD,OPĚRADLO ZADNÍHO SEDADLA
VK8 = DRŽÁK,BRÝLE
W2N = PÍSMO,LATERAL, VYNECHEJTE
W3F = POTAH,ZAROVNANÝ,KOLO,VARIANT 7
W4Y
WAG = TYPOVÝ ŠTÍTEK,MERIVA
XA3 = OPEL
XB2 = PRO MAĎARSKO
XJ9 = PRO MAĎARSKO
XL8 = PRO FREKVENCI 433 MHZ
XM5 = ZAŘÍZENÍ,ÚROVEŇ 1
Z1O = PRO MAĎARSKO
