hazmec: děkuju ti
peter13675
poprosim WOLOAHL3592018363
dik
dik
W0L:General Motors
0:VOZIDLO BEZ ZVLD�STN� ÚPRAVY
A:Astra Platform
H:2004 Platform Generation
L35:Estate
9:2009
2:Bochum
018363:SERIAL NUMBER
20S = BARVA STEHŮ,HVĚZDNĚ STŘÍBRNÁ
4AU = VNĚJŠÍ LAK, VIZ KATALOG MODELŮ, ÚVOD, TABULKA LAKŮ
80I = VNITŘEK-ČERNÝ
80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ
80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ
A14 = SKLO,BOČNÍ OKNO,ZADNÍ,ZBARVENÉ
A33 = ELEKTRICKY ŘÍZENÉ OKNA,ZADNÍ
A88 = OPĚRKA HLAVY,PŘEDNÍ SEDADLO,AKTIVNÍ
AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ
AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE
ANY = KOLEJNICE A VÁZACÍ ÚCHYTY PRO NÁKLAD
AQ0 = OPĚRKA HLAVY,ZADNÍ SEDADLO,VINYLOVÝ POTAH,DVA,KRAJNÍ
AQ2 = SÍŤ KOMFORTNÍ
AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ
B70 = KRYT PRAHU DVEŘÍ
B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ
B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ
BKX = S POLOLESKLOU KRYCÍ LIŠTOU Z MATNÉHO CHROMU
BS9 = TĚSNĚNÍ PRIMÁRNÍ,DVEŘE,SPODNÍ
BSS = LIŠTA KRYCÍ DVEŘE VNITŘEK,CHROMOVANÁ MATT ČÁSTEČNĚ LESKLÁ
BW4 = S CHROMOVOU LIŠTOU
BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE
C32 = PRO SYSTÉM QUICKHEAT
C68 = PRO ELEKTRONICKOU KLIMATIZACI
C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU
CE1 = STÍRAČ,PŘEDNÍ,IMPULSOVÝ SYSTÉM
CT1 = PRO BELGII
CT1
D75 = KLIKA ÚPLNÁ VNĚJŠÍ
DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO
DD8 = PRO VNITŘNÍ ZRCÁTKO CITLIVÉ NA SVĚTLO
DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ
DDU = ZRCÁTKO,SESTAVA
DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ
DP6 = TĚLESO
DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA)
DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ
E4R = PRODEJNÍ BALÍK SADA-COSMO
E94 = KRYT
ECA = KLÍČ
FXB = POMĚR NÁPRAVY 3.65
G62 = 5 ŠROUB UPEVNĚNÍ KOLA
JL9 = ABS
K13 = POUŽÍVÁ SE S FILTREM PEVNÝM ČÁSTIC VE VÝFUKOVÉM SYSTÉMU
K34 = REGULÁTOR RYCHLOSTI
KC8 = ZÁSUVKA,VÝSTUP POMOCNÉHO NAPÁJENÍ
KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA
KG9 = ALTERNÁTOR,140A
LHD = ŘÍZENÍ LEVÉ
LPV = VZNĚTOVÝ MOTOR Z17DTJ[LPV],A17DTJ[LPV]
MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU
MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR)
N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM
NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE
NS2 = PRO VARIABILNÍ POSILOVAČ ŘÍZENÍ
NT4 = EMISE,EEC 05
OHB
OMO
PXF = LEM,ALFA/VINYL
QQ0 = KOLO 16X6.5,HLINÍK,7 DVOJITÝCH PAPRSKŮ
QQ5 = PRO VELKÉ NÁHRAD.KOLO
R2F
T2Q = REFLEKTORY,AUTOMATICKÉ ZAPÍNÁNÍ/VYPÍNÁNÍ
T67 = BATERIE,70AH
T6K = PANEL VYBAVENÍ,VNITŘNÍ,VINYL
T96 = SVĚTLO DO MLHY PŘEDNÍ
T9S = SVÍTILNA ÚPLNÁ,VNITŘNÍ,PŘEDNÍ DVEŘE
TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ
TRP = RÁMEČEK,RADIOPŘIJÍMAČ
TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ
TSQ = OSVĚTLENÍ INTERIÉRU DELUXE
TTO = RÁDIO CHLADICÍ SYSTÉM
TTX
U07 = HOUKAČKA,TROUBA
U3C
U55
U66 = REPRODUKTOR,7
U68 = INFORMAČNÍ POČÍTAČ
UAJ = GRAFICKÉ INFORMACE - BARVA
UCE = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,NAVIGACE,ETR,TLUMENÍ
UD7 = ČIDLO PARKOVACÍHO SYSTÉMU
UJ3
V3E = DRŽÁK ZAVAZADEL VOLNÝ STŘEŠNÍ,STŘÍBRNÝ
VG2 = OCHRANNÍ VOSK, VYNECHEJTE
VGB = STŘEŠNÍ NOSIČ ZAVAZADEL,ELOXOVANÝ
VK8 = DRŽÁK,BRÝLE
VQ9 = ODMONTOVATELNÁ SPOJKA ZÁVLEKU
VVH = STŘEDOVÝ PŘÍSTROJ NA PANELU,UHLOVÁ PIANO
W4Y
WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO
WBG = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,GPS
XA3 = OPEL
XK1 = PRO BELGII
Y67 = POŽADUJE PŘI OSAZENÉM SERVISNÍM DISPLEJI
Z0D = PRO BELGII
Z0D
Z1F = RYCHLOMĚR KM/H
A:Astra Platform
L35:Estate
9:2009
2:Bochum
80I = VNITŘEK-ČERNÝ
AQ2 = SÍŤ KOMFORTNÍ
CT1 = PRO BELGII
CT1
DP6 = TĚLESO
E94 = KRYT
ECA = KLÍČ
JL9 = ABS
LHD = ŘÍZENÍ LEVÉ
NT4 = EMISE,EEC 05
OHB
OMO
R2F
T67 = BATERIE,70AH
TTX
U3C
U55
U66 = REPRODUKTOR,7
UJ3
VK8 = DRŽÁK,BRÝLE
W4Y
XA3 = OPEL
XK1 = PRO BELGII
Z0D = PRO BELGII
Z0D
Ak mozem poprosit W0L0AHL3582030363 vopred dakujem
W0L:General Motors
A:Astra Platform
L35:Estate
8:2008
2:Bochum
030363:SERIAL NUMBER
80I = VNITŘEK-ČERNÝ
AF8 = KONTROLA ZAMYKÁNÍ POSTRANNÍCH DVEŘÍ,OCHRANA PROTI KRÁDEŽI
AJT = PRO PŘÍPRAVU K MONTÁŽI BEZPEČNOSTNÍ SÍTĚ
AY9 = OPĚRKA HLAVY,ZADNÍ,VINYL,STŘED
BS7 = TĚSNĚNÍ PRIMÁRNÍ,DVEŘE,DVĚ BARVY
C61 = SEMI-AUTOMATICKÁ KLIMATIZACE
CT6 = PRO ITÁLII
CT6
DP6 = TĚLESO
E94 = KRYT
ECA = KLÍČ
FX3 = PROGRAM ELEKTRONICKÉ STABILITY
JL9 = ABS
K60 = ALTERNÁTOR,100AMP
LHD = ŘÍZENÍ LEVÉ
LPL = VZNĚTOVÉ MOTORY Z17DTR[LPL],A17DTR[LPL]
N65 = PNEUMATIKA,NÁHRADNÍ,ÚSPORA PROSTORU
NR1 = PRO REDUKOVANOU DRÁHU HŘEBENOVÉ TYČE
NT4 = EMISE,EEC 05
OHB
OMO
TM7 = BATERIE,60AH
U3B
U55
UA6 = OCHRANA PROTI VLOUPÁNÍ
UAG = GRAFICKÁ INFORMACE - JEDNOBAREVNÁ
UJ3
UJC = SPÍNAČ SPORTOVNÍ REŽIM
URA = SPÍNAČ OVLÁDÁNÍ RÁDIA
UW5 = REPRODUKTOROVÝ SYSTÉM 6,BASE
VG9 = OCHRANNÍ VOSK
VK8 = DRŽÁK,BRÝLE
W4Y
XA3 = OPEL
XJ2 = NIŽŠÍ SPORTOVNÍ PODVOZEK
XK4 = PRO ITÁLII
Z0H = PRO ITÁLII
ZQ8 = UŽITO SPOLU SE SPORTOVNÍM PODVOZKEM
A:Astra Platform
L35:Estate
8:2008
2:Bochum
80I = VNITŘEK-ČERNÝ
CT6 = PRO ITÁLII
CT6
DP6 = TĚLESO
E94 = KRYT
ECA = KLÍČ
JL9 = ABS
LHD = ŘÍZENÍ LEVÉ
NT4 = EMISE,EEC 05
OHB
OMO
TM7 = BATERIE,60AH
U3B
U55
UJ3
VG9 = OCHRANNÍ VOSK
VK8 = DRŽÁK,BRÝLE
W4Y
XA3 = OPEL
XK4 = PRO ITÁLII
Z0H = PRO ITÁLII
- Radoš92
Když je napsáno 4AU = VNĚJŠÍ LAK, VIZ KATALOG MODELŮ, ÚVOD, TABULKA LAKŮ, máte tam záznamy, který kód je přesně nějaká barva? Myslím popis barvy?
Prosim WOLOAHM7562072037 děkuji
- Frydex
REGISTRAČNÍ ČÍSLO: Datum výroby: 20051122 Značka: Opel Vauxhall VIN: W0L0AHM7562072037 Kód modelu: 0QV75 Kód balení: LD61
W0L:General Motors
A:Astra Platform
M75:Monocab (Zafira)
6:2006
2:Bochum
072037:SERIAL NUMBER
28S = SE SEŠITÍM V TMAVOŠEDÉ BARVĚ 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 3KU = VNĚJŠÍ BARVA,VIZ SEZNAM BAREV V ÚVODĚ KATALOGU 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A33 = ELEKTRICKY ŘÍZENÉ OKNA,ZADNÍ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO A88 = OPĚRKA HLAVY,PŘEDNÍ SEDADLO,AKTIVNÍ AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA ANY = KOLEJNICE A VÁZACÍ ÚCHYTY PRO NÁKLAD AV4 = DĚLENÉ ZADNÍ SEDADLO AWY = ZÁDRŽNÝ SYSTÉM ZADNÍ SEDADLO,RAMENNÍ,ZATAHOVÁNÍ,ODDĚLITELNÝ KOTVICÍ BOD BEZPEČNOSTNÍHO PÁSU AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED B58 = KRYCÍ PODLAHOVÉ ROHOŽKY,PŘEDNÍ A ZADNÍ KOBERCOVÁ VLOŽKA B70 = KRYT PRAHU DVEŘÍ B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BA9 = CHLADNIČKA BF8 = ÚLOŽNÁ SCHRÁNKA,PŘEDNÍ SEDADLO,PRAVÉ BNV = LIŠTA PŘÍSTROJOVÉ DESKY VNITŘNÍ,TIGER WALNUT BNY = LIŠTA KRYCÍ DVEŘE VNITŘEK,TIGER WALNUT BOC = VYROBENÉ V BOCHUM BW4 = S CHROMOVOU LIŠTOU BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE C68 = PRO ELEKTRONICKOU KLIMATIZACI C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CE1 = STÍRAČ,PŘEDNÍ,IMPULSOVÝ SYSTÉM CT1 = PRO BELGII D75 = KLIKA ÚPLNÁ VNĚJŠÍ DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO DD8 = PRO VNITŘNÍ ZRCÁTKO CITLIVÉ NA SVĚTLO DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ DP6 = TĚLESO DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E94 = KRYT ECA = KLÍČ FXB = POMĚR NÁPRAVY 3.65 G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K13 = POUŽÍVÁ SE S FILTREM PEVNÝM ČÁSTIC VE VÝFUKOVÉM SYSTÉMU K34 = REGULÁTOR RYCHLOSTI K60 = ALTERNÁTOR,100AMP KC7 = ELEKTRICKÁ ZÁSUVKA,ZADNÍ SEDADLO KC8 = ZÁSUVKA,VÝSTUP POMOCNÉHO NAPÁJENÍ KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LHD = ŘÍZENÍ LEVÉ LPM = VZNĚTOVÝ MOTOR Z19DT MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR) N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NR1 = PRO REDUKOVANOU DRÁHU HŘEBENOVÉ TYČE NT4 = EMISE,EEC 05 OGI OHD PXE = TEXTILNÍ ČALOUNĚNÍ,SCALA/ELBA QGF = PNEUMATIKY,205/55 R 16-91H QL5 = KOLO,VOZOVKA,HLINÍK,10 PŘÍČEK,61/2JX16 QQ5 = PRO VELKÉ NÁHRAD.KOLO R2F T2Q = REFLEKTORY,AUTOMATICKÉ ZAPÍNÁNÍ/VYPÍNÁNÍ T9M = ČALOUNĚNÍ ELBA T9S = SVÍTILNA ÚPLNÁ,VNITŘNÍ,PŘEDNÍ DVEŘE TM7 = BATERIE,60AH TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ TSQ = OSVĚTLENÍ INTERIÉRU DELUXE TTB = OSVĚTLENÍ VNITŘNÍ,STŘEŠNÍ, ZADNÍ KOMFORTNÍ A DVOJITÉ ČTECÍ,3. ŘADA U07 = HOUKAČKA,TROUBA U3F U55 U66 = REPRODUKTOR,7 U68 = INFORMAČNÍ POČÍTAČ U71 = ANTÉNA,ÚPLNÁ,STŘECHA UAJ = GRAFICKÉ INFORMACE - BARVA UCE = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,NAVIGACE,ETR,TLUMENÍ UD5 = ČIDLO, PARKOVACÍ SYSTÉM UEQ = ODPOJOVAČ AKUMULÁTORU UH0 = VÝSTRAHA BEZPEČNOSTNÍHO PÁSU,LH UJ3 V2T = NOSIČ,ZAVAZADEL,STŘEŠNÍ,S PRÁŠKOVOU ÚPRAVOU V3E = DRŽÁK ZAVAZADEL VOLNÝ STŘEŠNÍ,STŘÍBRNÝ V4M = VYBAVENÍ 5-STAR,SADA NCAP VFE = NÁRAZNÍK PŘEDNÍ A ZADNÍ,OCHRANNÝ VÝLISEK,BAREVNÝ VG2 = OCHRANNÍ VOSK, VYNECHEJTE VK8 = DRŽÁK,BRÝLE VNF = ODPOJOVAČ BATERIE W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO WBG = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,GPS XA3 = OPEL XK1 = PRO BELGII Y67 = POŽADUJE PŘI OSAZENÉM SERVISNÍM DISPLEJI Z0D = PRO BELGII Z0L = ELEGANCE Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ Z1Y = BARVA,DVA POVLAKY
W0L:General Motors
A:Astra Platform
6:2006
2:Bochum
Zdravim zhanam cislo dielu prichytiek krytu motora Z17DTR 92kW 2008
Dobrý den,mohu poprosit o zjištění W0L0TGF751H028831 děkuji
