Solik, neni to onoSolik píše:Mělo by to být toto:
24 13155713 22 65 657 DESTIČKA UPEVŇOVACÍ, BEDERNÍ OPĚRKA, PŘEDNÍ SEDADLO, LEV. (PRO RUČNÍ NASTAVENÍ BEDERNÍ OPĚRY PÁTEŘE)
- jour
hatatitlas
Ahoj, prosim o info k VIN: W0L0AHM757G114754
Dik
Dik
W0L: General Motors
A: Astra Platform
H: 2004 Platform Generation
M75: Monocab (Zafira)
7: 2007
G: Gliwice
114754: SERIAL NUMBER
Kód modelu: 0QS75
Kód balení: KD52
1.reg.značka: WE-624CL
Datum výroby: 20.3.2007
Typ motoru: Z18XER
Sériové číslo motoru: 20JW1842
Čalounění: XXVQ
Výbava: 2AU = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ 2H0 = MOTOR BENZINOVÝ C18SEL[2H0],Z18XER[2H0],A18XER[2H0] 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A14 = SKLO,BOČNÍ OKNO,ZADNÍ,ZBARVENÉ A88 = OPĚRKA HLAVY,PŘEDNÍ SEDADLO,AKTIVNÍ AE4 = PRO SPORTOVNÍ SEDADLA AH3 = PŘEDNÍ SEDADLO,ŘIDIČ,RUČNÉ NASTAVENÍ AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA AJT = PRO PŘÍPRAVU K MONTÁŽI BEZPEČNOSTNÍ SÍTĚ AV4 = DĚLENÉ ZADNÍ SEDADLO AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED B70 = KRYT PRAHU DVEŘÍ B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BF8 = ÚLOŽNÁ SCHRÁNKA,PŘEDNÍ SEDADLO,PRAVÉ BLN = LIŠTA KRYCÍ DVEŘE VNITŘEK BLUDIŠTĚ,CHROMOVÁ BLP = KRYCÍ LIŠTY PŘÍSTROJOVÉ DESKY,MATNĚ CHROMOVANÁ BRG = IDENTIFIKAČNÍ KRITICKÝ BOD 2007 1/2 MR BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE C61 = SEMI-AUTOMATICKÁ KLIMATIZACE C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CT2 = PRO RAKOUSKO D18 = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,CHROMOVANÉ KRUHY D75 = KLIKA ÚPLNÁ VNĚJŠÍ DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) E94 = KRYT ECA = KLÍČ F52 = PODVOZEK SE SPORTOVNÍ ÚPRAVOU FX1 = KONEČNÝ POHON NÁPRAVY 3.94 FX3 = PROGRAM ELEKTRONICKÉ STABILITY FZ3 = ZDOKONALENÝ ELEKTRONICKÝ PROGRAM STABILITY G62 = 5 ŠROUB UPEVNĚNÍ KOLA JF5 = POUŽITO SPOLU S PEDÁLEM SPORT ZE SLITINY JL9 = ABS K09 = ALTERNÁTOR,120AMP K34 = REGULÁTOR RYCHLOSTI KC7 = ELEKTRICKÁ ZÁSUVKA,ZADNÍ SEDADLO KC8 = ZÁSUVKA,VÝSTUP POMOCNÉHO NAPÁJENÍ KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LHD = ŘÍZENÍ LEVÉ M25 = RUČNÍ PŘEVODOVKA,5 RYCHLOSTNÍ,F17 TYP MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU N35 = VOLANT,SPORT,KŮŽE NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NR1 = PRO REDUKOVANOU DRÁHU HŘEBENOVÉ TYČE NT4 = EMISE,EEC 05 OHC PHQ = TEXTILNÍ ČALOUNĚNÍ,ALPHA STŘÍBRNÁ/ELBA QGF = PNEUMATIKY,205/55 R 16-91H QQ5 = PRO VELKÉ NÁHRAD.KOLO S89 = KOLO 16X6.5,HLINÍK,5 DVOJITÝCH PAPRSKŮ T61 = PRO SYSTÉM DENNÍCH SVĚTEL T96 = SVĚTLO DO MLHY PŘEDNÍ T9M = ČALOUNĚNÍ ELBA TN6 = BATERIE,55AH TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ TTB = OSVĚTLENÍ VNITŘNÍ,STŘEŠNÍ, ZADNÍ KOMFORTNÍ A DVOJITÉ ČTECÍ,3. ŘADA TTO = RÁDIO CHLADICÍ SYSTÉM U07 = HOUKAČKA,TROUBA U3A U71 = ANTÉNA,ÚPLNÁ,STŘECHA UAC = INFORMAČNÍ PANEL LCD - VÍCEFUNKČNÍ UH0 = VÝSTRAHA BEZPEČNOSTNÍHO PÁSU,LH UJ3 UJC = SPÍNAČ SPORTOVNÍ REŽIM URA = SPÍNAČ OVLÁDÁNÍ RÁDIA UW6 = REPRODUKTOR,6 V2T = NOSIČ,ZAVAZADEL,STŘEŠNÍ,S PRÁŠKOVOU ÚPRAVOU V3D = NOSIČ ZAVAZADEL VOLNÝ STŘEŠNÍ,ČERNÝ V4M = VYBAVENÍ 5-STAR,SADA NCAP VFB = TĚLESO CHRÁNIČE,POŠKOZENÍ PLECHU KRAJNÍHO DÍLU ZADNÍ ČTVRTI VFE = NÁRAZNÍK PŘEDNÍ A ZADNÍ,OCHRANNÝ VÝLISEK,BAREVNÝ VG9 = OCHRANNÍ VOSK VK8 = DRŽÁK,BRÝLE VU2 = STŘEDOVÝ PŘÍSTROJ NA PANELU,CHROMOVANÁ MATT W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y W7P = ŠTÍTEK,SPORT W9R = PRO RAKOUSKO WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO XA3 = OPEL Z0E = PRO RAKOUSKO Z1F = RYCHLOMĚR KM/H ZQ8 = UŽITO SPOLU SE SPORTOVNÍM PODVOZKEM
W0L: General Motors
A: Astra Platform
7: 2007
G: Gliwice
Kód modelu: 0QS75
Kód balení: KD52
Typ motoru: Z18XER
Čalounění: XXVQ
Ahoj-prosím o info k WIN - W0L0AHL4882226229
Děkuji
Děkuji
- Frydex
REGISTRAČNÍ ČÍSLO: EU-WF 4662 Datum výroby: 20080703 Značka: Opel Vauxhall VIN: W0L0AHL4882226229 Kód modelu: 0TN48 Kód balení: I753
Typ motoru: Z16XER
Sériové číslo motoru: 20MJ2981
W0L:General Motors
A:Astra Platform
H:2004 Platform Generation
L48:5-DV. SEDAN
8:2008
2:Bochum
226229:SERIAL NUMBER
2AU = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO A88 = OPĚRKA HLAVY,PŘEDNÍ SEDADLO,AKTIVNÍ AH3 = PŘEDNÍ SEDADLO,ŘIDIČ,RUČNÉ NASTAVENÍ AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA ALR AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BA9 = CHLADNIČKA BNS = LIŠTA KRYCÍ DVEŘE VNITŘEK,SATÉNOVÁ STONE BPI = LIŠTA PŘÍSTROJOVÉ DESKY,SATÉNOVÁ STONE BRL = IDENTIFIKAČNÍ KRITICKÝ BOD MR 2008 1/2 C68 = PRO ELEKTRONICKOU KLIMATIZACI C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CE1 = STÍRAČ,PŘEDNÍ,IMPULSOVÝ SYSTÉM CE4 = OSTŘIKOVAČ SVĚTLOMETU CT3 = PRO NĚMECKO CT3 D75 = KLIKA ÚPLNÁ VNĚJŠÍ DD8 = PRO VNITŘNÍ ZRCÁTKO CITLIVÉ NA SVĚTLO DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4Q = ENJOY ECA = KLÍČ FX1 = KONEČNÝ POHON NÁPRAVY 3.94 FX3 = PROGRAM ELEKTRONICKÉ STABILITY G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K34 = REGULÁTOR RYCHLOSTI K60 = ALTERNÁTOR,100AMP KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LDE = Z16EXR,A16XER ZÁŽEHOVÝ MOTOR LHD = ŘÍZENÍ LEVÉ M25 = RUČNÍ PŘEVODOVKA,5 RYCHLOSTNÍ,F17 TYP MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NT4 = EMISE,EEC 05 OHA = MÍSTNÍ GM Z EUROPE OHA P92 = KRYT,KOLO 16PALCOVÉ PROVEDENÍ CHAMPAGNE MR07 PHP = TEXTILNÍ ČALOUNĚNÍ,TABITA/ELBA QMT = PNEUMATIKY VŠECHNY 205/55R16-91H BW R/ST TL ALS QN1 = KOLO,DISKOVÉ,OCELOVÉ,61/2JX16 QQ5 = PRO VELKÉ NÁHRAD.KOLO T2Q = REFLEKTORY,AUTOMATICKÉ ZAPÍNÁNÍ/VYPÍNÁNÍ T96 = SVĚTLO DO MLHY PŘEDNÍ T9M = ČALOUNĚNÍ ELBA T9P = DEKORACE TMAVÁ,TĚLESO SVĚTLOMETU TN6 = BATERIE,55AH TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ TSQ = OSVĚTLENÍ INTERIÉRU DELUXE TT2 = SVĚTLOMETY SMĚROVÉ,VYSOKÁ INTENZITA VÝBOJKA,TLUMENÉ XENONOVÉ,DÁLKOVÉ XENONOVÉ/HALOGENOVÉ U3A U55 U68 = INFORMAČNÍ POČÍTAČ UAG = GRAFICKÁ INFORMACE - JEDNOBAREVNÁ UEC = SNÍMAČ INDIKÁTOR AUTOMATICKÉ RECIRKULACE VZDUCHU UH0 = VÝSTRAHA BEZPEČNOSTNÍHO PÁSU,LH UH1 = VÝSTRAHA BEZPEČNOSTNÍHO PÁSU,RH UJ3 URA = SPÍNAČ OVLÁDÁNÍ RÁDIA UW5 = REPRODUKTOROVÝ SYSTÉM 6,BASE VG2 = OCHRANNÍ VOSK, VYNECHEJTE VJU = STŘEDOVÝ PŘÍSTROJ NA PANELU,SATÉNOVÁ STONE W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO XA3 = OPEL XG3 = PRO NĚMECKO Y67 = POŽADUJE PŘI OSAZENÉM SERVISNÍM DISPLEJI Z0F = PRO NĚMECKO Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ
Typ motoru: Z16XER
W0L:General Motors
A:Astra Platform
L48:5-DV. SEDAN
8:2008
2:Bochum
- Radoš92
Prosím prosím: W0L0TGF7532276474
- Frydex
REGISTRAČNÍ ČÍSLO: HP-SH 711 Datum výroby: 20030623 Značka: Opel Vauxhall VIN: W0L0TGF7532276474 Kód modelu: 0QY75 Kód balení: KH51
Typ motoru: Z18XE
Sériové číslo motoru: 20BM6086
W0L:General Motors
T:Astra
G:Astra
F75:Zafira
3:2003
2:Bochum
276474:SERIAL NUMBER
2H9 = 18 BENZÍNOVÝ MOTOR 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 4AU = VNĚJŠÍ BARVA,VIZ SEZNAM BAREV V ÚVODĚ KATALOGU 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A14 = SKLO,BOČNÍ OKNO,ZADNÍ,ZBARVENÉ A23 = PŘEDNÍ SKLO,REFLEXIVNÍ TEPLO A32 = ELEKTRICKY ŘÍZENÉ OKNA,PŘEDNÍ A33 = ELEKTRICKY ŘÍZENÉ OKNA,ZADNÍ A88 = OPĚRKA HLAVY,PŘEDNÍ SEDADLO,AKTIVNÍ AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AHB = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AJ3 = PRO BEZPEČNOSTNÍ VAK U ŘIDIČE AJ4 = PRO BEZPEČNOSTNÍ VAK AN4 = SEDADLO PRO DÍTĚ,OCHRANNÝ SYSTÉM AP0 = PRO BOČNÍ VZDUCHOVÝ POLŠTÁŘ,LEVÝ AP1 = PRO BOČNÍ VZDUCHOVÝ POLŠTÁŘ,PRAVÝ AQ6 = PŘEDNÍ SEDADLO,NASTAVITELNÁ OPĚRKA AS1 = PRO SKLÁPECÍ PŘEDNÍ SEDADLO,PRAVÉ ASF = VZDUCHOVÝ POLŠTÁŘ,PRAVÝ/LEVÝ,RÁMEC STŘECHY AT0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,CELÁ AU0 = ZÁMEK DVEŘÍ,S DÁLKOVÝM OVLÁDÁNÍM AY3 = OPĚRKA HLAVY,PŘEDNÍ,TEXTIL,CELÁ AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED B70 = KRYT PRAHU DVEŘÍ B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ BB7 = POUŽÍT S CHROMOVÝMI VNITŘNÍMI DVEŘNÍMI KLIKAMI BOC = VYROBENÉ V BOCHUM C35 = OHŘÍVAČ,ZADNÍ ODDĚLENÍ C60 = KLIMATIZACE C68 = PRO ELEKTRONICKOU KLIMATIZACI CE4 = OSTŘIKOVAČ SVĚTLOMETU CT3 = PRO NĚMECKO CT3 D16 = SDRUŽENÝ PŘÍSTROJ,BÍLÝ,ČERNÝ,CHROMOVANÉ KRUHY D75 = KLIKA ÚPLNÁ VNĚJŠÍ DA5 = LOKETNÍ OPĚRKA,ZADNÍ,STŘED DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO DD8 = PRO VNITŘNÍ ZRCÁTKO CITLIVÉ NA SVĚTLO DL8 = ZRCADLO,ELEKTRICKÉ A VYTÁPĚNÉ,PRAVÉ,LEVÉ DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) FX3 = PROGRAM ELEKTRONICKÉ STABILITY G62 = 5 ŠROUB UPEVNĚNÍ KOLA GT6 = POMĚR NÁPRAVY 4.19 JBG = PÁKA RUČNÍ BRZDY,CHROM S VYSOKÝM LESKEM JL9 = ABS K09 = ALTERNÁTOR,120AMP KA1 = PRO VYHŘÍVANÁ PŘEDNÍ SEDADLA KC5 = ZÁSUVKA,ELEKTRICKÉ PŘÍSLUŠENSTVÍ(12V) LHD = ŘÍZENÍ LEVÉ M79 = RUČNÍ PŘEVODOVKA,5 RYCHLOSTNÍ MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU N33 = PRO NASTAVITELNÝ SLOUPEK ŘÍZENÍ N40 = POSILOVAČ ŘÍZENÍ, BEZ PROMĚNNÉHO POMĚRU NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NP5 = VOLANT,KŮŽE NT4 = EMISE,EEC 05 NW6 = KOLO,VOZOVKA,9 PODLOUHLÝCH OTVORŮ,51/2JX13 NW9 = ŘÍZENÍ TAŽENÍ ODN P34 = KOLO A PNEUMATIKA,NÁHRADNÍ PBZ = OVLÁDÁNÍ SEDÁKU SEDADLA,SKLOPNÉ,VLEVO PCE = OVLÁDÁNÍ SEDÁKU SEDADLA,SKLOPNÉ,VPRAVO QBE = PNEUMATIKY,205/55 R 16-89V R2D T96 = SVĚTLO DO MLHY PŘEDNÍ T97 = REFLEKTOR,XENON T9M = ČALOUNĚNÍ ELBA T9P = DEKORACE TMAVÁ,TĚLESO SVĚTLOMETU TN6 = BATERIE,55AH U07 = HOUKAČKA,TROUBA U3A U55 UJ3 UR4 = RÁDIO NCDR 2011/1100 UV5 = MULTI-FUNKČNÍ DISPLEJ,VAT3 UV9 = DISPLEJ,NAVIGAČNÍ SYSTÉM UZ8 = REPRODUKTOR,8 BOSE V22 = MŘÍŽKA,CHLADIČ,CHRÓMOVÁ LIŠTA VQ9 = ODMONTOVATELNÁ SPOJKA ZÁVLEKU VU2 = STŘEDOVÝ PŘÍSTROJ NA PANELU,CHROMOVANÁ MATT W01 W1G = PRO CD PŘEHRÁVAČ W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W2N = PÍSMO,LATERAL, VYNECHEJTE W3X = MOTOR,SZENTGOTTHARD W4Y W7Z = ZAŘÍZENÍ,ZIMA W9I = ČALOUNĚNÍ XENO / ELBA W9M = PRO DODATEČNÉ DÍLY SYSTÉMU ONSTAR NEBO NAVIG.SYSTÉMU W9U = DINKS WD4 = IDENT.EFEKTIVNÍ BOD CON. XA3 = OPEL XG3 = PRO NĚMECKO XK5 = ZAŘÍZENÍ,ŠPERK XL8 = PRO FREKVENCI 433 MHZ Z0F = PRO NĚMECKO Z0F Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ Z1Y = BARVA,DVA POVLAKY ZQ9 = VNĚJŠÍ VYBAVENÍ,ČERNÉ
Typ motoru: Z18XE
W0L:General Motors
T:Astra
G:Astra
F75:Zafira
3:2003
2:Bochum
- Radoš92
Díky.
Ahoj,taky prosím o info VIN: W0L0AHM758G189383
Dík.
Dík.
Opel Zafira 1,9 CDTi 110kW Facelift 2008
