REGISTRAČNÍ ČÍSLO: DM222YY Datum výroby: 20071102 Značka: Opel Vauxhall VIN: W0L0AHM758G052134 Kód modelu: 0QN75 Kód balení: LD68
Typ motoru: Z19DT
Sériové číslo motoru: 5781923
W0L:General Motors
A:Astra Platform
H:2004 Platform Generation
M75:Monocab (Zafira)
8:2008
G:Gliwice
052134:SERIAL NUMBER
2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 4CU = VNĚJŠÍ BARVA,VIZ SEZNAM BAREV V ÚVODĚ KATALOGU 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO AH3 = PŘEDNÍ SEDADLO,ŘIDIČ,RUČNÉ NASTAVENÍ AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA AJT = PRO PŘÍPRAVU K MONTÁŽI BEZPEČNOSTNÍ SÍTĚ AV4 = DĚLENÉ ZADNÍ SEDADLO AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BF8 = ÚLOŽNÁ SCHRÁNKA,PŘEDNÍ SEDADLO,PRAVÉ BL5 = LIŠTA KRYCÍ DVEŘE VNITŘEK,STŘÍBRNÁ BLB = KRYCÍ LIŠTY PŘÍSTROJOVÉ DESKY,STŘÍBRNÁ BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE C60 = KLIMATIZACE C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CT6 = PRO ITÁLII CT6 D75 = KLIKA ÚPLNÁ VNĚJŠÍ DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4Q = ENJOY E94 = KRYT ECA = KLÍČ FX3 = PROGRAM ELEKTRONICKÉ STABILITY FXB = POMĚR NÁPRAVY 3.65 FZ3 = PRO ZDOKONALENÝ ELEKTRONICKÝ PROGRAM STABILITY (STABILITA PŘÍVĚSU) G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K13 = POUŽÍVÁ SE S FILTREM PEVNÝM ČÁSTIC VE VÝFUKOVÉM SYSTÉMU K60 = ALTERNÁTOR,100AMP KC7 = ELEKTRICKÁ ZÁSUVKA,ZADNÍ SEDADLO KC8 = ZÁSUVKA,VÝSTUP POMOCNÉHO NAPÁJENÍ KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LHD = ŘÍZENÍ LEVÉ LPM = VZNĚTOVÝ MOTOR Z19DT MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR) N52 = VOLANT,TŘI PAPRSKY NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NR1 = PRO REDUKOVANOU DRÁHU HŘEBENOVÉ TYČE NT4 = EMISE,EEC 05 OHA = MÍSTNÍ GM Z EUROPE OHA P92 = KRYT,KOLO 16PALCOVÉ PROVEDENÍ CHAMPAGNE MR07 PHP = TEXTILNÍ ČALOUNĚNÍ,TABITA/ELBA QGF = PNEUMATIKY,205/55 R 16-91H QN1 = KOLO,DISKOVÉ,OCELOVÉ,61/2JX16 QQ5 = PRO VELKÉ NÁHRAD.KOLO T96 = SVĚTLO DO MLHY PŘEDNÍ T9W = OBKLAD,VNITŘNÍ,TABITA TM7 = BATERIE,60AH TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ TTB = OSVĚTLENÍ VNITŘNÍ,STŘEŠNÍ, ZADNÍ KOMFORTNÍ A DVOJITÉ ČTECÍ,3. ŘADA U07 = HOUKAČKA,TROUBA U3B U55 U68 = INFORMAČNÍ POČÍTAČ UAC = INFORMAČNÍ PANEL LCD - VÍCEFUNKČNÍ UH0 = VÝSTRAHA BEZPEČNOSTNÍHO PÁSU,LH UJ3 URA = SPÍNAČ OVLÁDÁNÍ RÁDIA UW5 = REPRODUKTOROVÝ SYSTÉM 6,BASE V2T = NOSIČ,ZAVAZADEL,STŘEŠNÍ,S PRÁŠKOVOU ÚPRAVOU V3D = NOSIČ ZAVAZADEL VOLNÝ STŘEŠNÍ,ČERNÝ V4M = VYBAVENÍ 5-STAR,SADA NCAP VFE = NÁRAZNÍK PŘEDNÍ A ZADNÍ,OCHRANNÝ VÝLISEK,BAREVNÝ VG9 = OCHRANNÍ VOSK VNF = ODPOJOVAČ BATERIE VU3 = STŘEDOVÝ PŘÍSTROJ NA PANELU,UHLOVÁ METALÍZA W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO XA3 = OPEL XK4 = PRO ITÁLII Z0H = PRO ITÁLII Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ
Cartman
Příspěvek od Cartman »
Ahoj, až budeš mít čas, můžeš se prosím mrknout na Astra H:
W0L0AHL3582060684, díky předem!
Astra H Caravan 1.6, Z16XER 2008
REGISTRAČNÍ ČÍSLO: Datum výroby: 20071105 Značka: Opel VIN: W0L0AHL3582060684 Kód modelu: 0TN35 Kód balení: I751
Typ motoru: Z16XER
Sériové číslo motoru: 20KZ1701
W0L:General Motors
A:Astra Platform
L35:Estate
8:2008
2:Bochum
060684:SERIAL NUMBER
Kód řízení GM*: XXVM
2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 4CU = VNĚJŠÍ BARVA,VIZ SEZNAM BAREV V ÚVODĚ KATALOGU 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA AJ7 = PRO BEZP. VAK ŘIDIČE, SPOJEZDCE A BOČNÍ VAK AM4 = ZADNÍ DĚLENÉ OPĚRADLO SEDADLA,SKLOPNÉ,VLASTNÍ AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BA9 = CHLADNIČKA BNS = LIŠTA KRYCÍ DVEŘE VNITŘEK,SATÉNOVÁ STONE BPI = LIŠTA PŘÍSTROJOVÉ DESKY,SATÉNOVÁ STONE C68 = PRO ELEKTRONICKOU KLIMATIZACI C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CR7 = PRO MAĎARSKO CR7 D75 = KLIKA ÚPLNÁ VNĚJŠÍ DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4Q = ENJOY E94 = KRYT ECA = KLÍČ FX1 = KONEČNÝ POHON NÁPRAVY 3.94 G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K60 = ALTERNÁTOR,100AMP KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LDE = Z16EXR,A16XER ZÁŽEHOVÝ MOTOR LHD = ŘÍZENÍ LEVÉ M25 = RUČNÍ PŘEVODOVKA,5 RYCHLOSTNÍ,F17 TYP MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NT4 = EMISE,EEC 05 OHA = MÍSTNÍ GM Z EUROPE OHA PHP = TEXTILNÍ ČALOUNĚNÍ,TABITA/ELBA QGF = PNEUMATIKY,205/55 R 16-91H QL5 = KOLO,VOZOVKA,HLINÍK,10 PŘÍČEK,61/2JX16 QQ5 = PRO VELKÉ NÁHRAD.KOLO T96 = SVĚTLO DO MLHY PŘEDNÍ T9W = OBKLAD,VNITŘNÍ,TABITA TN6 = BATERIE,55AH TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ TTX = PRO POMOCNÝ KONEKTOR RÁDIA U3F U66 = REPRODUKTOR,7 UAG = GRAFICKÁ INFORMACE - JEDNOBAREVNÁ UCH = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,ETR,TLUMENÍ,MP3 UEC = SNÍMAČ INDIKÁTOR AUTOMATICKÉ RECIRKULACE VZDUCHU UJ3 V2T = NOSIČ,ZAVAZADEL,STŘEŠNÍ,S PRÁŠKOVOU ÚPRAVOU V3D = NOSIČ ZAVAZADEL VOLNÝ STŘEŠNÍ,ČERNÝ VG9 = OCHRANNÍ VOSK VJU = STŘEDOVÝ PŘÍSTROJ NA PANELU,SATÉNOVÁ STONE W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO XA3 = OPEL XB2 = PRO MAĎARSKO XJ9 = PRO MAĎARSKO Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ Z1O = PRO MAĎARSKO
Cartman
moc díky za noční analýzu ;)
ale vypadá to, že nemám ESP, že ne?
Kód FX3 tam nevidím, takže nee.... ;)
bacardi
Příspěvek od bacardi »
vies aj vectru C ? WOLOZCF6871109497
dakujem
OPEL Vectra C 1,9 88kw 2007
REGISTRAČNÍ ČÍSLO: Datum výroby: 20070523 Značka: Opel Vauxhall VIN: W0L0ZCF6871109497 Kód modelu: 0JL68 Kód balení: LS62
Typ motoru: Z17DT
W0L:General Motors
Z:Vectra
C:Vectra
F68:5-DV. SEDAN
7:2007
1:Rüsselsheim
109497:SERIAL NUMBER
2HU = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ 2J8 32X = BARVA ČALOUNĚNÍ SEDADLA BARVA UHLOVÁ 32Y = BARVA ČALOUNĚNÍ PLECHOVÉHO VÝLISKU DVEŘÍ UHLOVÁ 5QB 80I = VNITŘEK-ČERNÝ A33 = ELEKTRICKY ŘÍZENÉ OKNA,ZADNÍ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO AF8 = KONTROLA ZAMYKÁNÍ POSTRANNÍCH DVEŘÍ,OCHRANA PROTI KRÁDEŽI AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED BA9 = CHLADNIČKA BD8 = LIŠTA,CELK.,STŘEŠNÍ,V BARVĚ KAROSERIE BNN = ÚLOŽNÁ SCHRÁNKA,LOŽNÝ PROSTOR BRG = IDENTIFIKAČNÍ KRITICKÝ BOD 2007 1/2 MR BTI = LIŠTA VNITŘNÍ UHLOVÁ METALÍZA,VLOŽKA HLINÍK MATT BW4 = S CHROMOVOU LIŠTOU C77 = VENTILÁTOR,UMĚLÉ VĚTRÁNÍ C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CE1 = STÍRAČ,PŘEDNÍ,IMPULSOVÝ SYSTÉM CJ2 = OVLÁDÁNÍ KLIMATIZACE CR7 = PRO MAĎARSKO CR7 D09 = LOKETNÍ OPĚRKA,PŘEDNÍ,STŘED D75 = KLIKA ÚPLNÁ VNĚJŠÍ DD8 = PRO VNITŘNÍ ZRCÁTKO CITLIVÉ NA SVĚTLO DG1 = ZRCÁTKO,CELK.,SVĚTLOCITLIVÉ NA STRANĚ ŘIDIČE,TÓNOVANÉ NA STRANĚ PASAŽÉRA DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) DW0 = VLOŽKA,ČERNÁ,STŘÍBRNÉ KROUŽKY LAKOVANÉ EA1 = KAPSA,OPĚRADLO PŘEDNÍHO SEDADLA,LH EA2 = KAPSA,OPĚRADLO PŘEDNÍHO SEDADLA,RH FX3 = PROGRAM ELEKTRONICKÉ STABILITY FX4 = KONEČNÝ POHON NÁPRAVY 3.35 JL9 = ABS K34 = REGULÁTOR RYCHLOSTI K60 = ALTERNÁTOR,100AMP KKV = KRYT,VEDENÍ,VOLIČ ŘAZENÍ,TUNELOVÁ KONZOLA LHD = ŘÍZENÍ LEVÉ LPM = VZNĚTOVÝ MOTOR Z19DT MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR) N55 = VOLANT, TROJPŘÍČKOVÝ, KOŽENÝ NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NT4 = EMISE,EEC 05 OHK P92 = KRYT,KOLO 16PALCOVÉ PROVEDENÍ CHAMPAGNE MR07 PAZ = OBKLAD,VNITŘEK,TUNIS PXE = TEXTILNÍ ČALOUNĚNÍ,SCALA/ELBA QFA = PNEUMATIKY,215/55 R 16-93H QN1 = KOLO,DISKOVÉ,OCELOVÉ,61/2JX16 QQ5 = PRO VELKÉ NÁHRAD.KOLO SVA = DRŽÁK,POHÁR,PŘEDNÍ SVB = DRŽÁK ŠÁLKU,ZADNÍ T2Q = REFLEKTORY,AUTOMATICKÉ ZAPÍNÁNÍ/VYPÍNÁNÍ T67 = BATERIE,70AH T96 = SVĚTLO DO MLHY PŘEDNÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ U08 = POUŽITO SPOLU S VÍCETÓNOVOU HOUKAČKOU U3F U55 U66 = REPRODUKTOR,7 U68 = INFORMAČNÍ POČÍTAČ UA6 = OCHRANA PROTI VLOUPÁNÍ UAG = GRAFICKÁ INFORMACE - JEDNOBAREVNÁ UCH = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,ETR,TLUMENÍ,MP3 UEC = SNÍMAČ INDIKÁTOR AUTOMATICKÉ RECIRKULACE VZDUCHU UJ3 UZB = SVĚTLO,BOČNÍ,ZADNÍ,BÍLÉ VG9 = OCHRANNÍ VOSK VHU = NÁRAZNÍK PŘEDNÍ,SPORT VK8 = DRŽÁK,BRÝLE VNF = ODPOJOVAČ BATERIE VYE = HLAVICE ŘADICÍ PÁKY,KOŽENÁ,SPORTOVNÍ W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W2N = PÍSMO,LATERAL, VYNECHEJTE W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO WFB = NOVÁ ŘÍDICÍ JEDNOTKA XA3 = OPEL XB2 = PRO MAĎARSKO XJ9 = PRO MAĎARSKO Y67 = POŽADUJE PŘI OSAZENÉM SERVISNÍM DISPLEJI Z0M = MODEL PŘESTAVBY ELEGANCE 2 Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ Z1O = PRO MAĎARSKO
bacardi
dakujem :lol:
filipek013
Příspěvek od filipek013 »
Nazdar, poprosim info k mojej astre: W0L0AHL3572126780
dikes
REGISTRAČNÍ ČÍSLO: DG582PJ Datum výroby: 20070208 Značka: Opel Vauxhall VIN: W0L0AHL3572126780 Kód modelu: 0TP35 Kód balení: LF67
Typ motoru: Z19DTH
Ser.č.motru: 17217591
W0L:General Motors
A:Astra Platform
L35:Estate
7:2007
2:Bochum
126780:SERIAL NUMBER
20S = BARVA STEHŮ,HVĚZDNĚ STŘÍBRNÁ 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 3KU = VNĚJŠÍ BARVA,VIZ SEZNAM BAREV V ÚVODĚ KATALOGU 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A14 = SKLO,BOČNÍ OKNO,ZADNÍ,ZBARVENÉ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AJT = PRO PŘÍPRAVU K MONTÁŽI BEZPEČNOSTNÍ SÍTĚ AQ0 = OPĚRKA HLAVY,ZADNÍ SEDADLO,VINYLOVÝ POTAH,DVA,KRAJNÍ AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY9 = OPĚRKA HLAVY,ZADNÍ,VINYL,STŘED B70 = KRYT PRAHU DVEŘÍ B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BKX = S POLOLESKLOU KRYCÍ LIŠTOU Z MATNÉHO CHROMU BRG = IDENTIFIKAČNÍ KRITICKÝ BOD 2007 1/2 MR BS7 = TĚSNĚNÍ PRIMÁRNÍ,DVEŘE,DVĚ BARVY BS9 = TĚSNĚNÍ PRIMÁRNÍ,DVEŘE,SPODNÍ BSS = LIŠTA KRYCÍ DVEŘE VNITŘEK,CHROMOVANÁ MATT ČÁSTEČNĚ LESKLÁ BW4 = S CHROMOVOU LIŠTOU BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE C61 = SEMI-AUTOMATICKÁ KLIMATIZACE C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CT6 = PRO ITÁLII CT6 D75 = KLIKA ÚPLNÁ VNĚJŠÍ DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4R = PRODEJNÍ BALÍK SADA-COSMO E94 = KRYT ECA = KLÍČ FE4 = SYSTÉM PRO SPECIÁLNÍ JÍZDU A JÍZDNÍ VLASTNOSTI (IDS+) FX3 = PROGRAM ELEKTRONICKÉ STABILITY FXB = POMĚR NÁPRAVY 3.65 G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K34 = REGULÁTOR RYCHLOSTI K60 = ALTERNÁTOR,100AMP KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LHD = ŘÍZENÍ LEVÉ LRD = VZNĚTOVÝ MOTOR Z19DTH MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR) N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM N65 = PNEUMATIKA,NÁHRADNÍ,ÚSPORA PROSTORU NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NR1 = PRO REDUKOVANOU DRÁHU HŘEBENOVÉ TYČE NT4 = EMISE,EEC 05 OHB OMO PXF = LEM,ALFA/VINYL QGF = PNEUMATIKY,205/55 R 16-91H QQ0 = KOLO 16X6.5,HLINÍK,7 DVOJITÝCH PAPRSKŮ T6K = PANEL VYBAVENÍ,VNITŘNÍ,VINYL T96 = SVĚTLO DO MLHY PŘEDNÍ T9S = SVÍTILNA ÚPLNÁ,VNITŘNÍ,PŘEDNÍ DVEŘE TM7 = BATERIE,60AH TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ TTO = RÁDIO CHLADICÍ SYSTÉM U07 = HOUKAČKA,TROUBA U3B U55 U68 = INFORMAČNÍ POČÍTAČ UAG = GRAFICKÁ INFORMACE - JEDNOBAREVNÁ UJ3 UJC = SPÍNAČ SPORTOVNÍ REŽIM URA = SPÍNAČ OVLÁDÁNÍ RÁDIA UW6 = REPRODUKTOR,6 V3E = DRŽÁK ZAVAZADEL VOLNÝ STŘEŠNÍ,STŘÍBRNÝ VDR VG9 = OCHRANNÍ VOSK VGB = STŘEŠNÍ NOSIČ ZAVAZADEL,ELOXOVANÝ VK8 = DRŽÁK,BRÝLE VNF = ODPOJOVAČ BATERIE VVH = STŘEDOVÝ PŘÍSTROJ NA PANELU,UHLOVÁ PIANO W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO XA3 = OPEL XJ2 = NIŽŠÍ SPORTOVNÍ PODVOZEK XK4 = PRO ITÁLII Z0H = PRO ITÁLII Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ ZQ8 = UŽITO SPOLU SE SPORTOVNÍM PODVOZKEM
