- Frydex
nero:
..... ostatní nevím, pod čím mám hledat.
Ahojte poprosil by som o rozklad
W0L0AHL3592054721
Dakujem
W0L0AHL3592054721
Dakujem
- Frydex
REGISTRAČNÍ ČÍSLO: DS641AB Datum výroby: 20081211
Značka: Opel Vauxhall
VIN: W0L0AHL3592054721 Kód modelu: 0TP35 Kód balení: JI69
Typ motoru: Z17DTJ
W0L:General Motors
A:Astra Platform
H:2004 Platform Generation
L35:Estate
9:2009
2:Bochum
054721:SERIAL NUMBER
20S = BARVA STEHŮ,HVĚZDNĚ STŘÍBRNÁ 2AU = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A14 = SKLO,BOČNÍ OKNO,ZADNÍ,ZBARVENÉ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AJT = PRO PŘÍPRAVU K MONTÁŽI BEZPEČNOSTNÍ SÍTĚ AQ0 = OPĚRKA HLAVY,ZADNÍ SEDADLO,VINYLOVÝ POTAH,DVA,KRAJNÍ AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY9 = OPĚRKA HLAVY,ZADNÍ,VINYL,STŘED B56 = LIŠTA KYVADLOVÁ KAROSÉRIE BARVA B70 = KRYT PRAHU DVEŘÍ B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BKX = S POLOLESKLOU KRYCÍ LIŠTOU Z MATNÉHO CHROMU BPF = PŘÍPRAVA V NÁRAZNÍKU VPŘEDU,SPODNÍ HRANA SPOJLERU BPG = PŘÍPRAVA V NÁRAZNÍKU VZADU,SPODNÍ HRANA SPOJLERU BS9 = TĚSNĚNÍ PRIMÁRNÍ,DVEŘE,SPODNÍ BSS = LIŠTA KRYCÍ DVEŘE VNITŘEK,CHROMOVANÁ MATT ČÁSTEČNĚ LESKLÁ BW4 = S CHROMOVOU LIŠTOU BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE C61 = SEMI-AUTOMATICKÁ KLIMATIZACE C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CT6 = PRO ITÁLII CT6 D75 = KLIKA ÚPLNÁ VNĚJŠÍ DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4R = PRODEJNÍ BALÍK SADA-COSMO E94 = KRYT ECA = KLÍČ FX3 = PROGRAM ELEKTRONICKÉ STABILITY FXB = POMĚR NÁPRAVY 3.65 G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K13 = POUŽÍVÁ SE S FILTREM PEVNÝM ČÁSTIC VE VÝFUKOVÉM SYSTÉMU K34 = REGULÁTOR RYCHLOSTI K60 = ALTERNÁTOR,100AMP KB5 = ASISTENT ROZJEZDU DO KOPCE KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LHD = ŘÍZENÍ LEVÉ LPV = VZNĚTOVÝ MOTOR Z17DTJ,A17DTJ MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR) N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM N65 = PNEUMATIKA,NÁHRADNÍ,ÚSPORA PROSTORU NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NR1 = PRO REDUKOVANOU DRÁHU HŘEBENOVÉ TYČE NT4 = EMISE,EEC 05 OBM OCX OHB OMO PXF = LEM,ALFA/VINYL QGT = PNEUMATIKY,225/45 R 17-91V QL4 = KOLO,DISKOVÉ,ALUMINIUM,7JX17 T6K = PANEL VYBAVENÍ,VNITŘNÍ,VINYL T96 = SVĚTLO DO MLHY PŘEDNÍ T9S = SVÍTILNA ÚPLNÁ,VNITŘNÍ,PŘEDNÍ DVEŘE TM7 = BATERIE,60AH TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ TTX = PRO POMOCNÝ KONEKTOR RÁDIA U07 = HOUKAČKA,TROUBA U3B U55 U66 = REPRODUKTOR,7 U68 = INFORMAČNÍ POČÍTAČ UAG = GRAFICKÁ INFORMACE - JEDNOBAREVNÁ UCH = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,ETR,TLUMENÍ,MP3 UD7 = ČIDLO PARKOVACÍHO SYSTÉMU UJ3 UJ9 = INDIKÁTOR PODHUŠTĚNÍ PNEUMATIKY UJC = SPÍNAČ SPORTOVNÍ REŽIM V3E = DRŽÁK ZAVAZADEL VOLNÝ STŘEŠNÍ,STŘÍBRNÝ VG9 = OCHRANNÍ VOSK VGB = STŘEŠNÍ NOSIČ ZAVAZADEL,ELOXOVANÝ VK8 = DRŽÁK,BRÝLE VVH = STŘEDOVÝ PŘÍSTROJ NA PANELU,UHLOVÁ PIANO W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO XA3 = OPEL XJ2 = NIŽŠÍ SPORTOVNÍ PODVOZEK XK4 = PRO ITÁLII Z0H = PRO ITÁLII Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ ZQ8 = UŽITO SPOLU SE SPORTOVNÍM PODVOZKEM
Typ motoru: Z17DTJ
W0L:General Motors
A:Astra Platform
L35:Estate
9:2009
2:Bochum
Prosím o info o vozu Opel Astra-H
VIN: W0L0AHL4868116031
Opel Astra H Caravan, 1.9 CDTI 16V (Z19DTH) - 110kW
Opel Vectra C Caravan, 1.9 CDTI 16V (Z19DTH) - 110kW
OP-COM 8/2010 Firmware V01.44
- Frydex
REGISTRAČNÍ ČÍSLO: VB -AJ 49 Datum výroby: 20060329 Značka: Opel Vauxhall VIN: W0L0AHL4868116031 Kód modelu: 0TN48 Kód balení: IZS1
Typ motoru: Zvolte jedno: Z16XEP
Sériové číslo motoru: 20GY1414
W0L:General Motors
A:Astra Platform
L48:5-DV. SEDAN
6:2006
8:Ellesmere Port
116031:SERIAL NUMBER
2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 4XU = VNĚJŠÍ BARVA,VIZ SEZNAM BAREV V ÚVODĚ KATALOGU 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO A88 = OPĚRKA HLAVY,PŘEDNÍ SEDADLO,AKTIVNÍ AH3 = PŘEDNÍ SEDADLO,ŘIDIČ,RUČNÉ NASTAVENÍ AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BL5 = LIŠTA KRYCÍ DVEŘE VNITŘEK,STŘÍBRNÁ BLB = KRYCÍ LIŠTY PŘÍSTROJOVÉ DESKY,STŘÍBRNÁ BRE = IDENTIFIKAČNÍ KRITICKÝ BOD 2006 1/2 MR C60 = KLIMATIZACE C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CT3 = PRO NĚMECKO CT3 D75 = KLIKA ÚPLNÁ VNĚJŠÍ DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DGZ = SCHRÁNKA V PŘÍSTROJOVÉ DESCE DĚLÍCÍ PŘEPÁŽKA DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4Q = ENJOY ECA = KLÍČ FX1 = KONEČNÝ POHON NÁPRAVY 3.94 FX3 = PROGRAM ELEKTRONICKÉ STABILITY G61 = 4 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K34 = REGULÁTOR RYCHLOSTI K60 = ALTERNÁTOR,100AMP KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LHD = ŘÍZENÍ LEVÉ LJ7 = MOTOR Z16XEP M25 = RUČNÍ PŘEVODOVKA,5 RYCHLOSTNÍ,F17 TYP MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU N52 = VOLANT,TŘI PAPRSKY NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NT4 = EMISE,EEC 05 OHA = MÍSTNÍ GM Z EUROPE OHA PHP = TEXTILNÍ ČALOUNĚNÍ,TABITA/ELBA PY3 = KOLO,DISKOVÉ,OCELOVÉ,61/2JX16 QGF = PNEUMATIKY,205/55 R 16-91H QQ5 = PRO VELKÉ NÁHRAD.KOLO T9W = OBKLAD,VNITŘNÍ,TABITA TN6 = BATERIE,55AH TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ U3A U66 = REPRODUKTOR,7 UAC = INFORMAČNÍ PANEL LCD - VÍCEFUNKČNÍ UCH = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,ETR,TLUMENÍ,MP3 UEQ = ODPOJOVAČ AKUMULÁTORU UH0 = VÝSTRAHA BEZPEČNOSTNÍHO PÁSU,LH UH1 = VÝSTRAHA BEZPEČNOSTNÍHO PÁSU,RH UJ3 VDR VG9 = OCHRANNÍ VOSK W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO XA3 = OPEL XG3 = PRO NĚMECKO Z0F = PRO NĚMECKO Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ
W0L:General Motors
A:Astra Platform
L48:5-DV. SEDAN
6:2006
8:Ellesmere Port
Děkuji.
Prosím o číslo dílu pravé mřížky (výdechu/trysky) topení na astra H. Ulámaly se mi lamely. Pokud někdo můžete zjisti... Dík
Pánové dokážete mi podle VIN: W0L0AHM759G062166 najít servočerpadlo k posilovači řízení? Přesný typ co tam je?
Nemám momentálně auto u sebe a chvíli mít nebudu tak jestli to jde podle VIN. Děkuji
Zafira B 2009 1.7 CDTi, 92 kW
- Frydex
Jos:
13228918 - 68 14 864 - KOMORA ODVZDUŠŇOVACÍ TRYSKY, VNĚJŠÍ, PRAV. - Opel Cena s DPH 967,2 Kč
Zajdi si na vrakáč raději.... nebo
https://www.opel-astra-h.cz/forum/viewto ... =36&t=4145
- Frydex
paulinek:
93196804 - 9 48 725 - ČERPADLO POSILOVAČE ŘÍZENÍ ÚPLNÉ, S DRŽÁKEM, LSŘ (BEZ TEPELNÉHO ŠTÍTU) Z18XER, A18XER, Z20LER, Z20LEH, Z17DTJ, A17DTJ, A17DTR, Z19DTL, Z19DT, Z19DTH, Z16YNG
Opel Cena s DPH 38 035,2 Kč
Můžeš mi říct, co ti na něm odešlo, nebo proč ho sháníš ?
