Ahoj, mohol by som tiež poprosiť o rozpis VIN?
VIN: W0L0AHL 358 210 7882
ďakujem (môžeš buď sem alebo SZ)
Opel Astra H, kombi, 1,9 CDTi, 110 kw, Z19DTH, r.v. 2008
Filtry na garančku:
1.7 CDTi 81kW r.v.2011
Olej, palivo, kabina, vzduch
popř. dodám VIN.
Díky
popř. dodám VIN.
Díky
- Frydex
REGISTRAČNÍ ČÍSLO: RZ-TR 561 Datum výroby: 20080123 Značka: Opel Vauxhall VIN: W0L0AHL3582107882 Kód modelu: 0TP35 Kód balení: LF61
Typ motoru: Z19DTH
Sériové číslo motoru: 17318638
W0L:General Motors
A:Astra Platform
H:2004 Platform Generation
L35:Estate
8:2008
2:Bochum
107882:SERIAL NUMBER
1RU = VNĚJŠÍ BARVA,VIZ SEZNAM BAREV V ÚVODĚ KATALOGU 20S = BARVA STEHŮ,HVĚZDNĚ STŘÍBRNÁ 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A14 = SKLO,BOČNÍ OKNO,ZADNÍ,ZBARVENÉ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO A88 = OPĚRKA HLAVY,PŘEDNÍ SEDADLO,AKTIVNÍ AH3 = PŘEDNÍ SEDADLO,ŘIDIČ,RUČNÉ NASTAVENÍ AJT = PRO PŘÍPRAVU K MONTÁŽI BEZPEČNOSTNÍ SÍTĚ AQ0 = OPĚRKA HLAVY,ZADNÍ SEDADLO,VINYLOVÝ POTAH,DVA,KRAJNÍ AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY9 = OPĚRKA HLAVY,ZADNÍ,VINYL,STŘED B70 = KRYT PRAHU DVEŘÍ B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BA9 = CHLADNIČKA BKX = S POLOLESKLOU KRYCÍ LIŠTOU Z MATNÉHO CHROMU BRL = IDENTIFIKAČNÍ KRITICKÝ BOD MR 2008 1/2 BS7 = TĚSNĚNÍ PRIMÁRNÍ,DVEŘE,DVĚ BARVY BS9 = TĚSNĚNÍ PRIMÁRNÍ,DVEŘE,SPODNÍ BSS = LIŠTA KRYCÍ DVEŘE VNITŘEK,CHROMOVANÁ MATT ČÁSTEČNĚ LESKLÁ BW4 = S CHROMOVOU LIŠTOU BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE C68 = PRO ELEKTRONICKOU KLIMATIZACI C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CE1 = STÍRAČ,PŘEDNÍ,IMPULSOVÝ SYSTÉM CT3 = PRO NĚMECKO CT3 D75 = KLIKA ÚPLNÁ VNĚJŠÍ DD8 = PRO VNITŘNÍ ZRCÁTKO CITLIVÉ NA SVĚTLO DDH = ZRCADLO,ELEKTRICKÉ A VYTÁPĚNÉ,PRAVÉ,LEVÉ DDI = ZRCÁTKO,SESTAVA DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4R = PRODEJNÍ BALÍK SADA-COSMO E94 = KRYT ECA = KLÍČ FX3 = PROGRAM ELEKTRONICKÉ STABILITY FXB = POMĚR NÁPRAVY 3.65 G62 = 5 ŠROUB UPEVNĚNÍ KOLA G67 = AUTOMATICKÉ SAMO-VYROVNÁVACÍ ZAŘÍZENÍ JL9 = ABS K13 = POUŽÍVÁ SE S FILTREM PEVNÝM ČÁSTIC VE VÝFUKOVÉM SYSTÉMU K34 = REGULÁTOR RYCHLOSTI K60 = ALTERNÁTOR,100AMP KB5 = ASISTENT ROZJEZDU DO KOPCE KC8 = ZÁSUVKA,VÝSTUP POMOCNÉHO NAPÁJENÍ KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LHD = ŘÍZENÍ LEVÉ LRD = VZNĚTOVÝ MOTOR Z19DTH MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR) N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NS2 = PRO VARIABILNÍ POSILOVAČ ŘÍZENÍ NT4 = EMISE,EEC 05 OHB OIF OMO PXF = LEM,ALFA/VINYL QBE = PNEUMATIKY,205/55 R 16-89V QQ0 = KOLO 16X6.5,HLINÍK,7 DVOJITÝCH PAPRSKŮ QQ5 = PRO VELKÉ NÁHRAD.KOLO R2D T2Q = REFLEKTORY,AUTOMATICKÉ ZAPÍNÁNÍ/VYPÍNÁNÍ T6K = PANEL VYBAVENÍ,VNITŘNÍ,VINYL T96 = SVĚTLO DO MLHY PŘEDNÍ T9S = SVÍTILNA ÚPLNÁ,VNITŘNÍ,PŘEDNÍ DVEŘE TGR TM7 = BATERIE,60AH TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ TSQ = OSVĚTLENÍ INTERIÉRU DELUXE TTO = RÁDIO CHLADICÍ SYSTÉM TTX = PRO POMOCNÝ KONEKTOR RÁDIA U07 = HOUKAČKA,TROUBA U3A U55 U66 = REPRODUKTOR,7 U68 = INFORMAČNÍ POČÍTAČ UAG = GRAFICKÁ INFORMACE - JEDNOBAREVNÁ UCE = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,NAVIGACE,ETR,TLUMENÍ UD7 = ČIDLO PARKOVACÍHO SYSTÉMU UEC = SNÍMAČ INDIKÁTOR AUTOMATICKÉ RECIRKULACE VZDUCHU UJ3 UJ9 = INDIKÁTOR PODHUŠTĚNÍ PNEUMATIKY UWA = PŘÍPRAVA PRO MOBILNÍ TELEFON,S OVLÁDÁNÍM HLASEM A SYSTÉMEM BLUETOOTH V3E = DRŽÁK ZAVAZADEL VOLNÝ STŘEŠNÍ,STŘÍBRNÝ VG2 = OCHRANNÍ VOSK, VYNECHEJTE VGB = STŘEŠNÍ NOSIČ ZAVAZADEL,ELOXOVANÝ VK8 = DRŽÁK,BRÝLE VNF = ODPOJOVAČ BATERIE VQ9 = ODMONTOVATELNÁ SPOJKA ZÁVLEKU VVH = STŘEDOVÝ PŘÍSTROJ NA PANELU,UHLOVÁ PIANO W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO WBG = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,GPS XA3 = OPEL XG3 = PRO NĚMECKO Y67 = POŽADUJE PŘI OSAZENÉM SERVISNÍM DISPLEJI Z0F = PRO NĚMECKO Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ
Typ motoru: Z19DTH
W0L:General Motors
A:Astra Platform
L35:Estate
8:2008
2:Bochum
- Frydex
98018448 - 56 50 375 -DÍL, ČISTIČ OLEJE, S TĚSNÍCÍMI KROUŽKY - Cena s DPH 349,8 Kč
93183389) (58 34 040) -DÍL, ČISTIČ VZDUCHU (NLS.-POUŽÍT 93192882 - 58 34 279) - Cena s DPH 511,2 Kč
93190458 - 58 18 083 -SADA, VLOŽKA ČISTIČE S TĚSNĚNÍM, ČISTIČ PALIVA JEDNODUCHÝ - Cena s DPH 466,2 Kč
13175553 - 68 08 606 -ČISTIČ, VENTILACE INTERIÉRU (FILTER NA PYL) - Cena s DPH 561 Kč
13175554 - 68 08 607 -ČISTIČ, VENTILACE INTERIÉRU (AKTIVNÍ UHLÍ) - Cena s DPH 1 034,4 Kč
Celkem - 1888,- s obyč pylovým - (2361,- s uhlíkovým pylákem)
Zdravím,
Můžu poprosit o dekodování VIN W0L0AHL3555229643 .
Předem díky
Předem díky
Opel Astra H 1,7, 74 KW
VIN: W0L0AHL3555229643
W0L: General Motors
A: Astra Platform
H: 2004 Platform Generation
L35: Estate
5: 2005
5: Antwerp
229643: SERIAL NUMBER
Kód modelu: 0TN35
Kód balení: JM54
REGISTRAČNÍ ČÍSLO: CW418VK
Datum výroby: 10.6.2005
Typ motoru: Z17DTH
Sériové číslo motoru: 01332819
Čalounění: XXRN
Výbava:
2AU = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO ADC = IDENTIFIKACE EFEKTIVNÍ BODOVÉ ŘÍZENÍ-ŘÍDICÍ JEDNOTKA JEDNOTKA CENTRÁLNÍHO ZAMYKÁNÍ DVEŘÍ AH3 = PŘEDNÍ SEDADLO,ŘIDIČ,RUČNÉ NASTAVENÍ AIT = PRO DVOUSTUPŇOVÝ AIRBAG AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ BA9 = CHLADNIČKA BGZ = IDENT.EFEKTIVNÍ BOD CON. BL5 = LIŠTA KRYCÍ DVEŘE VNITŘEK,STŘÍBRNÁ BLB = KRYCÍ LIŠTY PŘÍSTROJOVÉ DESKY,STŘÍBRNÁ C68 = PRO ELEKTRONICKOU KLIMATIZACI C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU COB = VYROBENÉ V ANTWERPÁCH 2 CT6 = PRO ITÁLII D75 = KLIKA ÚPLNÁ VNĚJŠÍ DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DGZ = SCHRÁNKA V PŘÍSTROJOVÉ DESCE DĚLÍCÍ PŘEPÁŽKA DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4Q = ENJOY E94 = KRYT ECA = KLÍČ FR7 = POMĚR NÁPRAVY 3.95 (PŘEDNÍ) G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K60 = ALTERNÁTOR,100AMP KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LHD = ŘÍZENÍ LEVÉ LPZ = VZNĚTOVÝ MOTOR Z17DTH[LPZ] MG1 = RUČNÍ PŘEVODOVKA,5 RYCHLOSTNÍ,F23 TYP MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU N52 = VOLANT,TŘI PAPRSKY N65 = PNEUMATIKA,NÁHRADNÍ,ÚSPORA PROSTORU NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NS2 = PRO VARIABILNÍ POSILOVAČ ŘÍZENÍ NT4 = EMISE,EEC 05 OHA = MÍSTNÍ GM Z EUROPE OHA PBE = LEM,TABITA/MALTA,STYLOVÉ PY3 = KOLO,DISKOVÉ,OCELOVÉ,61/2JX16 QGF = PNEUMATIKY,205/55 R 16-91H T96 = SVĚTLO DO MLHY PŘEDNÍ T9W = OBKLAD,VNITŘNÍ,TABITA TM7 = BATERIE,60AH TPX TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ U07 = HOUKAČKA,TROUBA U3B UAH = DISPLEJ INFOTAINMENT,GRAFICKÝ INFORMAČNÍ DISPLEJ (GID),VAR2 UEQ = ODPOJOVAČ AKUMULÁTORU UJ3 URA = SPÍNAČ OVLÁDÁNÍ RÁDIA UW5 = REPRODUKTOROVÝ SYSTÉM 6,BASE V2T = NOSIČ,ZAVAZADEL,STŘEŠNÍ,S PRÁŠKOVOU ÚPRAVOU V3D = NOSIČ ZAVAZADEL VOLNÝ STŘEŠNÍ,ČERNÝ VFE = NÁRAZNÍK PŘEDNÍ A ZADNÍ,OCHRANNÝ VÝLISEK,BAREVNÝ W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO XA3 = OPEL XK4 = PRO ITÁLII Z0H = PRO ITÁLII Z1F = RYCHLOMĚR KM/H Z1Y = BARVA,DVA POVLAKY
W0L: General Motors
A: Astra Platform
L35: Estate
5: 2005
5: Antwerp
Kód modelu: 0TN35
Kód balení: JM54
Typ motoru: Z17DTH
Čalounění: XXRN
Výbava:
Mohl bych také poprosit o info?
VIN: W0L0AHL4845178965
Předem děkuji
Předem děkuji
Astra H, 1,6 Twinport 77 kw, r.v. 2004
- Frydex
Na sraz do Ovy přijedeš ?
REGISTRAČNÍ ČÍSLO: Datum výroby: 20040503 Značka: Opel Vauxhall VIN: W0L0AHL4845178965 Kód modelu: 0TV48 Kód balení: IZS4
Typ motoru:Z16XEP
Sériové číslo motoru 20CZ3643
W0L:General Motors
A:Astra Platform
L48:5-DV. SEDAN
4:2004
5:Antwerp
178965:SERIAL NUMBER
28S = SE SEŠITÍM V TMAVOŠEDÉ BARVĚ 2AU = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A33 = ELEKTRICKY ŘÍZENÉ OKNA,ZADNÍ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED B58 = KRYCÍ PODLAHOVÉ ROHOŽKY,PŘEDNÍ A ZADNÍ KOBERCOVÁ VLOŽKA B70 = KRYT PRAHU DVEŘÍ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BA9 = CHLADNIČKA BD8 = LIŠTA,CELK.,STŘEŠNÍ,V BARVĚ KAROSERIE BKH = KRYCÍ LIŠTY PŘÍSTROJOVÉ DESKY,STÍNOVANÉ ŽILKOVÁNÍ DŘEVA BNF = LIŠTA KRYCÍ DVEŘE VNITŘEK,TEXTURA DŘEVA BS9 = TĚSNĚNÍ PRIMÁRNÍ,DVEŘE,SPODNÍ BW4 = S CHROMOVOU LIŠTOU BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE C68 = PRO ELEKTRONICKOU KLIMATIZACI C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CE1 = STÍRAČ,PŘEDNÍ,IMPULSOVÝ SYSTÉM COB = VYROBENÉ V ANTWERPÁCH 2 CU3 = PRO FRANCII CU3 D75 = KLIKA ÚPLNÁ VNĚJŠÍ DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO DD8 = PRO VNITŘNÍ ZRCÁTKO CITLIVÉ NA SVĚTLO DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DGZ = SCHRÁNKA V PŘÍSTROJOVÉ DESCE DĚLÍCÍ PŘEPÁŽKA DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ ECA = KLÍČ FX1 = KONEČNÝ POHON NÁPRAVY 3.94 FX3 = PROGRAM ELEKTRONICKÉ STABILITY G61 = 4 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K09 = ALTERNÁTOR,120AMP K34 = REGULÁTOR RYCHLOSTI KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LHD = ŘÍZENÍ LEVÉ LJ7 = MOTOR Z16XEP M25 = RUČNÍ PŘEVODOVKA,5 RYCHLOSTNÍ,F17 TYP MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM N65 = PNEUMATIKA,NÁHRADNÍ,ÚSPORA PROSTORU NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NT4 = EMISE,EEC 05 OHD PAU = LEM,BRISTOL/AMANA QGF = PNEUMATIKY,205/55 R 16-91H QL5 = KOLO,VOZOVKA,HLINÍK,10 PŘÍČEK,61/2JX16 T2Q = REFLEKTORY,AUTOMATICKÉ ZAPÍNÁNÍ/VYPÍNÁNÍ T9K = OBKLAD,VNITŘNÍ,AMANA T9S = SVÍTILNA ÚPLNÁ,VNITŘNÍ,PŘEDNÍ DVEŘE TN6 = BATERIE,55AH TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ TSQ = OSVĚTLENÍ INTERIÉRU DELUXE U07 = HOUKAČKA,TROUBA U3D U55 U66 = REPRODUKTOR,7 U68 = INFORMAČNÍ POČÍTAČ UAG = GRAFICKÁ INFORMACE - JEDNOBAREVNÁ UCH = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,ETR,TLUMENÍ,MP3 UEC = SNÍMAČ INDIKÁTOR AUTOMATICKÉ RECIRKULACE VZDUCHU UEQ = ODPOJOVAČ AKUMULÁTORU UH1 = VÝSTRAHA BEZPEČNOSTNÍHO PÁSU,RH UJ3 VFE = NÁRAZNÍK PŘEDNÍ A ZADNÍ,OCHRANNÝ VÝLISEK,BAREVNÝ VK8 = DRŽÁK,BRÝLE W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO XA3 = OPEL XK2 = PRO FRANCII Y67 = POŽADUJE PŘI OSAZENÉM SERVISNÍM DISPLEJI Z0L = ELEGANCE Z0W = PRO FRANCII Z0W Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ Z1Y = BARVA,DVA POVLAKY
Typ motoru:Z16XEP
W0L:General Motors
A:Astra Platform
L48:5-DV. SEDAN
4:2004
5:Antwerp
Zdravím,jsem čerstvý Oplák Zafira B
mohl bych poprosit,jestli mám filtr pevných částic,Díky moc
VIN:W0L0AHM757G146169
