Pepajz
Příspěvek od Pepajz »
Mohl bych poprosit o info k mému autu? VIN: W0L0AHL4892069918
Předem díky Pepa
1,7 CDTI, 74kw, rok výroby 2009
REGISTRAČNÍ ČÍSLO: Datum výroby: 20090210 Značka: Opel Vauxhall VIN: W0L0AHL4892069918 Kód modelu: 0TL48 Kód balení: JM51
W0L:General Motors
A:Astra Platform
H:2004 Platform Generation
L48:5-DV. SEDAN
9:2009
2:Bochum
069918:SERIAL NUMBER
2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 4CU = VNĚJŠÍ BARVA,VIZ SEZNAM BAREV V ÚVODĚ KATALOGU 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO AH3 = PŘEDNÍ SEDADLO,ŘIDIČ,RUČNÉ NASTAVENÍ AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA AJ7 = PRO BEZP. VAK ŘIDIČE, SPOJEZDCE A BOČNÍ VAK AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED B76 = PRO PŘÍSTROJ S ČERNÝM CIFERNÍKEM B87 = S ČERNOU KRYCÍ LIŠTOU BKV = LIŠTA PŘÍSTROJOVÉ DESKY VNITŘNÍ,UHLOVÁ BSI = IDENT.EFEKTIVNÍ BOD CON. BYD = LIŠTA KRYCÍ DVEŘE VNITŘEK,VYNECHEJTE C60 = KLIMATIZACE CR7 = PRO MAĎARSKO CR7 DDV = ZRCÁTKO,SESTAVA DHA = ZRCÁTKO,SESTAVA, ZPĚTNÉ,VNITŘNÍ DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) FR7 = POMĚR NÁPRAVY 3.95 (PŘEDNÍ) G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K60 = ALTERNÁTOR,100AMP KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LHD = ŘÍZENÍ LEVÉ LPZ = VZNĚTOVÝ MOTOR Z17DTH MG1 = RUČNÍ PŘEVODOVKA,5 RYCHLOSTNÍ,F23 TYP MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NS2 = PRO VARIABILNÍ POSILOVAČ ŘÍZENÍ NT4 = EMISE,EEC 05 OHI = MÍSTNÍ GM Z EUROPE OHI PA7 = KOLO,DISKOVÉ,OCEL,61/2Jx15 PFM = ČALOUNĚNÍ,ALPHA/ELBA QQ5 = PRO VELKÉ NÁHRAD.KOLO QXL = PNEUMATIKY,195/65 R 15-91T(AW) T96 = SVĚTLO DO MLHY PŘEDNÍ T9M = ČALOUNĚNÍ ELBA TM7 = BATERIE,60AH TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ U3F UF8 = TROJITÝ INFORMAČNÍ DISPLEJ LCD - DATUM/ČAS/TEPLOTA UJ3 URA = SPÍNAČ OVLÁDÁNÍ RÁDIA UW5 = REPRODUKTOROVÝ SYSTÉM 6,BASE VG9 = OCHRANNÍ VOSK VU2 = STŘEDOVÝ PŘÍSTROJ NA PANELU,CHROMOVANÁ MATT W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO XA3 = OPEL XB2 = PRO MAĎARSKO XJ9 = PRO MAĎARSKO Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ Z1O = PRO MAĎARSKO
Ceda1980
Příspěvek od Ceda1980 »
Zdravím mohl bych taky obtěžovat Předem Díky 8-) VIN WOLOAHM757G034858
OPEL Zafira ( 2007 ) COSMO 1,9 CDTi 88 kw automat Pannacotta
mach00
Příspěvek od mach00 »
VIN: W0L0AHM757G034858
W0L: General Motors
A: Astra Platform
H: 2004 Platform Generation
M75: Monocab (Zafira)
7: 2007
G: Gliwice
034858: SERIAL NUMBER
Kód modelu: 0Q 75
Kód balení: LC61
Datum výroby: 16.10.2006
Typ motoru: Z19DT
Sériové číslo motoru: 5176667
Čalounění: XXVX
Výbava: 1RU = VNĚJŠÍ LAK, VIZ KATALOG MODELŮ, ÚVOD, TABULKA LAKŮ 20S = BARVA STEHŮ,HVĚZDNĚ STŘÍBRNÁ 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A14 = SKLO,BOČNÍ OKNO,ZADNÍ,ZBARVENÉ A23 = PŘEDNÍ SKLO,REFLEXIVNÍ TEPLO A33 = ELEKTRICKY ŘÍZENÉ OKNA,ZADNÍ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO A88 = OPĚRKA HLAVY,PŘEDNÍ SEDADLO,AKTIVNÍ AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AJT = PRO PŘÍPRAVU K MONTÁŽI BEZPEČNOSTNÍ SÍTĚ ANY = KOLEJNICE A VÁZACÍ ÚCHYTY PRO NÁKLAD AQ0 = OPĚRKA HLAVY,ZADNÍ SEDADLO,VINYLOVÝ POTAH,DVA,KRAJNÍ AV4 = DĚLENÉ ZADNÍ SEDADLO AWY = ZÁDRŽNÝ SYSTÉM ZADNÍ SEDADLO,RAMENNÍ,ZATAHOVÁNÍ,ODDĚLITELNÝ KOTVICÍ BOD BEZPEČNOSTNÍHO PÁSU AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY9 = OPĚRKA HLAVY,ZADNÍ,VINYL,STŘED B70 = KRYT PRAHU DVEŘÍ B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BA9 = CHLADNIČKA BF8 = ÚLOŽNÁ SCHRÁNKA,PŘEDNÍ SEDADLO,PRAVÉ BL5 = LIŠTA KRYCÍ DVEŘE VNITŘEK,STŘÍBRNÁ BLB = KRYCÍ LIŠTY PŘÍSTROJOVÉ DESKY,STŘÍBRNÁ BW4 = S CHROMOVOU LIŠTOU BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE C68 = PRO ELEKTRONICKOU KLIMATIZACI C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CE1 = STÍRAČ,PŘEDNÍ,IMPULSOVÝ SYSTÉM CT1 = PRO BELGII D75 = KLIKA ÚPLNÁ VNĚJŠÍ D95 DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO DD8 = PRO VNITŘNÍ ZRCÁTKO CITLIVÉ NA SVĚTLO DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4R = PRODEJNÍ BALÍK SADA-COSMO E94 = KRYT ECA = KLÍČ G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K09 = ALTERNÁTOR,120AMP K13 = POUŽÍVÁ SE S FILTREM PEVNÝM ČÁSTIC VE VÝFUKOVÉM SYSTÉMU K34 = REGULÁTOR RYCHLOSTI KC7 = ELEKTRICKÁ ZÁSUVKA,ZADNÍ SEDADLO KC8 = ZÁSUVKA,VÝSTUP POMOCNÉHO NAPÁJENÍ KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LHD = ŘÍZENÍ LEVÉ LPM = VZNĚTOVÝ MOTOR Z19DT[LPM] M36 = AF40-6 AUTOMATICKÁ PŘEVODOVKA MM1 = POUŽITO SPOLU S AUTOAMTICKOU PŘEVODOVKOU N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NR1 = PRO REDUKOVANOU DRÁHU HŘEBENOVÉ TYČE NT4 = EMISE,EEC 05 OHB PXF = LEM,ALFA/VINYL QGF = PNEUMATIKY,205/55 R 16-91H QL5 = KOLO,VOZOVKA,HLINÍK,10 PŘÍČEK,61/2JX16 QQ5 = PRO VELKÉ NÁHRAD.KOLO R2F T2Q = REFLEKTORY,AUTOMATICKÉ ZAPÍNÁNÍ/VYPÍNÁNÍ T6K = PANEL VYBAVENÍ,VNITŘNÍ,VINYL T96 = SVĚTLO DO MLHY PŘEDNÍ T9S = SVÍTILNA ÚPLNÁ,VNITŘNÍ,PŘEDNÍ DVEŘE TM7 = BATERIE,60AH TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ TSQ = OSVĚTLENÍ INTERIÉRU DELUXE TTB = OSVĚTLENÍ VNITŘNÍ,STŘEŠNÍ, ZADNÍ KOMFORTNÍ A DVOJITÉ ČTECÍ,3. ŘADA TTO = RÁDIO CHLADICÍ SYSTÉM U07 = HOUKAČKA,TROUBA U3C U55 U66 = REPRODUKTOR,7 U68 = INFORMAČNÍ POČÍTAČ U71 = ANTÉNA,ÚPLNÁ,STŘECHA UAJ = GRAFICKÉ INFORMACE - BARVA UCE = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,NAVIGACE,ETR,TLUMENÍ UD5 = ČIDLO, PARKOVACÍ SYSTÉM UEC = SNÍMAČ INDIKÁTOR AUTOMATICKÉ RECIRKULACE VZDUCHU UH0 = VÝSTRAHA BEZPEČNOSTNÍHO PÁSU,LH UJ3 UJC = SPÍNAČ SPORTOVNÍ REŽIM V2T = NOSIČ,ZAVAZADEL,STŘEŠNÍ,S PRÁŠKOVOU ÚPRAVOU V3E = DRŽÁK ZAVAZADEL VOLNÝ STŘEŠNÍ,STŘÍBRNÝ V4M = VYBAVENÍ 5-STAR,SADA NCAP VFE = NÁRAZNÍK PŘEDNÍ A ZADNÍ,OCHRANNÝ VÝLISEK,BAREVNÝ VG2 = OCHRANNÍ VOSK, VYNECHEJTE VK8 = DRŽÁK,BRÝLE VNF = ODPOJOVAČ BATERIE W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO WBG = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,GPS XA3 = OPEL XK1 = PRO BELGII Y67 = POŽADUJE PŘI OSAZENÉM SERVISNÍM DISPLEJI Z0D = PRO BELGII Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ
ice1975
Příspěvek od ice1975 »
ahoj. sháním výkres sestavy (kusovník) okruhu klimatizace na mojí astru. potřebuju identifikovat jednu hadici/trubici, která je prasklá. máte to někdo k dispozici. předem dík.
Ceda1980
Díky mooooooc za info :lol: Takže jsem se ujistil že ESP opravdu nemám myslel jsem jestli tam není nějaká chyba Prodejce mě ujišťoval že v autě je Nóóóóóó to jsem zvědav jak se bude chovat automat v zimě na sněhu :o Docela jsem na to spoléhal že mi v některých situacích pomůže Autamat má první a vůbec si nedokážu tu jízdu na sněhu představit Ale ještě jednou Díííííky
Tak některé hadice se rozlišujou taky podle identu klimy, na prvním obrázku pro motor Z17DTH určena hadice č 23. Druhý obrázek je shodný právě podle identu, označeno jako - TRUBKA, TEKUTÉ CHLADIVO, VÝPARNÍK A ODVODŇOVAČ. Zkus na to kouknout, nějak z toho nejsem chytrý.
ice1975
ta druhá hadice je hodně podobná té mé. až na to, že ta slabší hadice není tak dlouhá. mám manuál AC a na kompresoru je ident.WJ.
Frydex píše:Tak některé hadice se rozlišujou taky podle identu klimy, na prvním obrázku pro motor Z17DTH určena hadice č 23. Druhý obrázek je shodný právě podle identu, označeno jako - TRUBKA, TEKUTÉ CHLADIVO, VÝPARNÍK A ODVODŇOVAČ. Zkus na to kouknout, nějak z toho nejsem chytrý.
která druhá ? :?:
ice1975
no ta druhá.... ;) TRUBKA, TEKUTÉ CHLADIVO, VÝPARNÍK A ODVODŇOVAČ.... 8-)
Frydex píše:která druhá ? :?:
