W0L:General Motors
A:Astra Platform
H:2004 Platform Generation
L35:Estate
8:2008
2:Bochum
030363:SERIAL NUMBER
20S = BARVA STEHŮ,HVĚZDNĚ STŘÍBRNÁ 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 4AU = VNĚJŠÍ BARVA,VIZ SEZNAM BAREV V ÚVODĚ KATALOGU 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A14 = SKLO,BOČNÍ OKNO,ZADNÍ,ZBARVENÉ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO AF8 = KONTROLA ZAMYKÁNÍ POSTRANNÍCH DVEŘÍ,OCHRANA PROTI KRÁDEŽI AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AJT = PRO PŘÍPRAVU K MONTÁŽI BEZPEČNOSTNÍ SÍTĚ AQ0 = OPĚRKA HLAVY,ZADNÍ SEDADLO,VINYLOVÝ POTAH,DVA,KRAJNÍ AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY9 = OPĚRKA HLAVY,ZADNÍ,VINYL,STŘED B70 = KRYT PRAHU DVEŘÍ B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BKX = S POLOLESKLOU KRYCÍ LIŠTOU Z MATNÉHO CHROMU BS7 = TĚSNĚNÍ PRIMÁRNÍ,DVEŘE,DVĚ BARVY BS9 = TĚSNĚNÍ PRIMÁRNÍ,DVEŘE,SPODNÍ BSS = LIŠTA KRYCÍ DVEŘE VNITŘEK,CHROMOVANÁ MATT ČÁSTEČNĚ LESKLÁ BW4 = S CHROMOVOU LIŠTOU BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE C61 = SEMI-AUTOMATICKÁ KLIMATIZACE C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CT6 = PRO ITÁLII CT6 D75 = KLIKA ÚPLNÁ VNĚJŠÍ DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4R = PRODEJNÍ BALÍK SADA-COSMO E94 = KRYT ECA = KLÍČ FX3 = PROGRAM ELEKTRONICKÉ STABILITY FXB = POMĚR NÁPRAVY 3.65 G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K13 = POUŽÍVÁ SE S FILTREM PEVNÝM ČÁSTIC VE VÝFUKOVÉM SYSTÉMU K60 = ALTERNÁTOR,100AMP KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LHD = ŘÍZENÍ LEVÉ LPL = VZNĚTOVÉ MOTORY Z17DTR,A17DTR MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR) N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM N65 = PNEUMATIKA,NÁHRADNÍ,ÚSPORA PROSTORU NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NR1 = PRO REDUKOVANOU DRÁHU HŘEBENOVÉ TYČE NT4 = EMISE,EEC 05 OHB OMO PXF = LEM,ALFA/VINYL QGF = PNEUMATIKY,205/55 R 16-91H QQ0 = KOLO 16X6.5,HLINÍK,7 DVOJITÝCH PAPRSKŮ T6K = PANEL VYBAVENÍ,VNITŘNÍ,VINYL T96 = SVĚTLO DO MLHY PŘEDNÍ T9S = SVÍTILNA ÚPLNÁ,VNITŘNÍ,PŘEDNÍ DVEŘE TM7 = BATERIE,60AH TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ U07 = HOUKAČKA,TROUBA U3B U55 U68 = INFORMAČNÍ POČÍTAČ UA6 = OCHRANA PROTI VLOUPÁNÍ UAG = GRAFICKÁ INFORMACE - JEDNOBAREVNÁ UJ3 UJC = SPÍNAČ SPORTOVNÍ REŽIM URA = SPÍNAČ OVLÁDÁNÍ RÁDIA UW5 = REPRODUKTOROVÝ SYSTÉM 6,BASE V3E = DRŽÁK ZAVAZADEL VOLNÝ STŘEŠNÍ,STŘÍBRNÝ VG9 = OCHRANNÍ VOSK VGB = STŘEŠNÍ NOSIČ ZAVAZADEL,ELOXOVANÝ VK8 = DRŽÁK,BRÝLE VVH = STŘEDOVÝ PŘÍSTROJ NA PANELU,UHLOVÁ PIANO W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO XA3 = OPEL XJ2 = NIŽŠÍ SPORTOVNÍ PODVOZEK XK4 = PRO ITÁLII Z0H = PRO ITÁLII Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ ZQ8 = UŽITO SPOLU SE SPORTOVNÍM PODVOZKEM
martulik
Příspěvek od martulik »
Ahoj,mohl bych poprosit o výpis tohoto vin? Předem děkuji martulik
WOLOZCF3551115737
mach00
Příspěvek od mach00 »
VIN: W0L0ZCF3551115737
W0L: General Motors
Z: Vectra
C: Vectra
F35: 5-DV. KOMBI
5: 2005
1: Rüsselsheim
115737: SERIAL NUMBER
Kód modelu: 0J 35
Kód balení: LK65
1. reg. značka: 5715DKS
Datum výroby: 29.4.2005
Typ motoru: Z19DT
Sériové číslo motoru: 4508372
Čalounění: XXNO
Výbava: 10U = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ 14X = BARVA ČALOUNĚNÍ SEDADLA UHLOVÁ/SVĚTLE UHLOVÁ 2J8 31F = VOLANT,BAREVNÝ 80I = VNITŘEK-ČERNÝ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A14 = SKLO,BOČNÍ OKNO,ZADNÍ,ZBARVENÉ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO ABQ AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ BA9 = CHLADNIČKA BD8 = LIŠTA,CELK.,STŘEŠNÍ,V BARVĚ KAROSERIE BDU = DEKORACE,SPORT BGZ = IDENT.EFEKTIVNÍ BOD CON. C77 = VENTILÁTOR,UMĚLÉ VĚTRÁNÍ CJ2 = OVLÁDÁNÍ KLIMATIZACE CT9 = PRO ŠPANĚLSKO D09 = LOKETNÍ OPĚRKA,PŘEDNÍ,STŘED D75 = KLIKA ÚPLNÁ VNĚJŠÍ DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) DW0 = VLOŽKA,ČERNÁ,STŘÍBRNÉ KROUŽKY LAKOVANÉ FX3 = PROGRAM ELEKTRONICKÉ STABILITY FX4 = KONEČNÝ POHON NÁPRAVY 3.35 JBF = PÁKA RUČNÍ BRZDY,CHROM MATT JL9 = ABS K60 = ALTERNÁTOR,100AMP KH2 = KRYTKA,RUKOJEŤ ŘADICÍ PÁKY,CHROM MATT KKS = KRYT,VEDENÍ,VOLIČ ŘAZENÍ,TUNELOVÁ KONZOLA LHD = ŘÍZENÍ LEVÉ LPM = VZNĚTOVÝ MOTOR Z19DT[LPM] MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU MZ3 = PŘEVODOVKA S RUČNÍM ŘAZENÍM F40 (WR) N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM N65 = PNEUMATIKA,NÁHRADNÍ,ÚSPORA PROSTORU NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NT3 = EMISE,EEC 00 NW7 = ŘÍZENÍ TAŽENÍ ODL OGV QFY = PNEUMATIKY,215/50 R 17-91H QU6 = KOLO 17X7,HLINÍK,7 LICHOBĚŽNÍKOVÝCH PAPRSKŮ RUE = VYROBENÉ V RUESSELSHEIMU T67 = BATERIE,70AH T6C = PANEL VYBAVENÍ,VNITŘNÍ,STANDARD,VARIANT 1 T71 = DEKORACE TMAVÁ,KRYT SVĚTLOMETU T96 = SVĚTLO DO MLHY PŘEDNÍ U08 = POUŽITO SPOLU S VÍCETÓNOVOU HOUKAČKOU U3E U91 = ANTÉNA KRÁTKÁ,STŘEŠNÍ,RÁDIO UAH = DISPLEJ INFOTAINMENT,GRAFICKÝ INFORMAČNÍ DISPLEJ (GID),VAR2 UEC = SNÍMAČ INDIKÁTOR AUTOMATICKÉ RECIRKULACE VZDUCHU UJ3 URA = SPÍNAČ OVLÁDÁNÍ RÁDIA UW6 = REPRODUKTOR,6 V2T = NOSIČ,ZAVAZADEL,STŘEŠNÍ,S PRÁŠKOVOU ÚPRAVOU V3D = NOSIČ ZAVAZADEL VOLNÝ STŘEŠNÍ,ČERNÝ VHT = NÁRAZNÍK PŘEDNÍ,PREMIUM VY7 = PÁKA PŘEVODOVKY,KŮŽE W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W2N = PÍSMO,LATERAL, VYNECHEJTE W4Y W6U = VYBAVENÍ,TEXTIL,STANDARD,VARIANT 2 W9S = PRO ŠPANĚLSKO WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO XA3 = OPEL Z0J = COMFORT Z0T = PRO ŠPANĚLSKO Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ Z1Y = BARVA,DVA POVLAKY
martancom
Příspěvek od martancom »
Zdravim, tiez poprosim o info.
VIN: W0L0AHM7562234054
vdaka
ZafiraB Z19DT 1.9CDTi 88kW 2006 PANORAMA
mach00
W0L: General Motors
A: Astra Platform
H: 2004 Platform Generation
M75: Monocab (Zafira)
6: 2006
2: Bochum
234054: SERIAL NUMBER
Kód modelu: 0Q 75
Kód balení: LD66
1. reg. značka: DD364CS
Datum výroby: 12.7.2006
Typ motoru: Z19DT
Sériové číslo motoru: 5102391
Čalounění: XXVX
Výbava: 20S = BARVA STEHŮ,HVĚZDNĚ STŘÍBRNÁ 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 3KU = VNĚJŠÍ LAK, VIZ KATALOG MODELŮ, ÚVOD, TABULKA LAKŮ 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A23 = PŘEDNÍ SKLO,REFLEXIVNÍ TEPLO A33 = ELEKTRICKY ŘÍZENÉ OKNA,ZADNÍ AE4 = PRO SPORTOVNÍ SEDADLA AF8 = KONTROLA ZAMYKÁNÍ POSTRANNÍCH DVEŘÍ,OCHRANA PROTI KRÁDEŽI AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AJT = PRO PŘÍPRAVU K MONTÁŽI BEZPEČNOSTNÍ SÍTĚ AQ0 = OPĚRKA HLAVY,ZADNÍ SEDADLO,VINYLOVÝ POTAH,DVA,KRAJNÍ AV4 = DĚLENÉ ZADNÍ SEDADLO AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY9 = OPĚRKA HLAVY,ZADNÍ,VINYL,STŘED B70 = KRYT PRAHU DVEŘÍ B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BF8 = ÚLOŽNÁ SCHRÁNKA,PŘEDNÍ SEDADLO,PRAVÉ BLK = KRYCÍ LIŠTY PŘÍSTROJOVÉ DESKY,ŘADA KOVOVÁ STŘÍBRNÁ BLM = LIŠTA KRYCÍ DVEŘE VNITŘEK,ŘADA KOVOVÁ STŘÍBRNÁ BRE = IDENTIFIKAČNÍ KRITICKÝ BOD 2006 1/2 MR BW4 = S CHROMOVOU LIŠTOU BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE C2K = SKLO OKNA,KONZOLA PO CELÉ DÉLCE C61 = SEMI-AUTOMATICKÁ KLIMATIZACE C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CT6 = PRO ITÁLII D75 = KLIKA ÚPLNÁ VNĚJŠÍ DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4R = PRODEJNÍ BALÍK SADA-COSMO E94 = KRYT ECA = KLÍČ FX3 = PROGRAM ELEKTRONICKÉ STABILITY FXB = POMĚR NÁPRAVY 3.65 FZ3 = ZDOKONALENÝ ELEKTRONICKÝ PROGRAM STABILITY FZM = NÍZKONÁKLADOVÁ STRUKTURA MODUL PŘEDNÍ ZÓNY G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K13 = POUŽÍVÁ SE S FILTREM PEVNÝM ČÁSTIC VE VÝFUKOVÉM SYSTÉMU K60 = ALTERNÁTOR,100AMP KC7 = ELEKTRICKÁ ZÁSUVKA,ZADNÍ SEDADLO KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LHD = ŘÍZENÍ LEVÉ LPM = VZNĚTOVÝ MOTOR Z19DT[LPM] MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR) N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NR1 = PRO REDUKOVANOU DRÁHU HŘEBENOVÉ TYČE NT4 = EMISE,EEC 05 OHB PXF = LEM,ALFA/VINYL QGF = PNEUMATIKY,205/55 R 16-91H QL5 = KOLO,VOZOVKA,HLINÍK,10 PŘÍČEK,61/2JX16 QQ5 = PRO VELKÉ NÁHRAD.KOLO T6K = PANEL VYBAVENÍ,VNITŘNÍ,VINYL T96 = SVĚTLO DO MLHY PŘEDNÍ T9S = SVÍTILNA ÚPLNÁ,VNITŘNÍ,PŘEDNÍ DVEŘE TIK = CHLADICÍ SYSTÉM,CHLADIČ PLNICÍHO VZDUCHU TM7 = BATERIE,60AH TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ TTB = OSVĚTLENÍ VNITŘNÍ,STŘEŠNÍ, ZADNÍ KOMFORTNÍ A DVOJITÉ ČTECÍ,3. ŘADA U07 = HOUKAČKA,TROUBA U3B U55 U68 = INFORMAČNÍ POČÍTAČ UA6 = OCHRANA PROTI VLOUPÁNÍ UAC = INFORMAČNÍ PANEL LCD - VÍCEFUNKČNÍ UEQ = ODPOJOVAČ AKUMULÁTORU UH0 = VÝSTRAHA BEZPEČNOSTNÍHO PÁSU,LH UJ3 URA = SPÍNAČ OVLÁDÁNÍ RÁDIA UW6 = REPRODUKTOR,6 V2T = NOSIČ,ZAVAZADEL,STŘEŠNÍ,S PRÁŠKOVOU ÚPRAVOU V3E = DRŽÁK ZAVAZADEL VOLNÝ STŘEŠNÍ,STŘÍBRNÝ V4M = VYBAVENÍ 5-STAR,SADA NCAP VFE = NÁRAZNÍK PŘEDNÍ A ZADNÍ,OCHRANNÝ VÝLISEK,BAREVNÝ VG9 = OCHRANNÍ VOSK VNF = ODPOJOVAČ BATERIE W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO XA3 = OPEL XK4 = PRO ITÁLII Z0H = PRO ITÁLII Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ
zaso
Příspěvek od zaso »
Zdravim, mohol by som poprosit este o jedno vytiahnutie info z VIN? Dakujem
WOLOAHL3582123403
Opel Meriva 1.7 CDTI 74kW
W0L:General Motors
A:Astra Platform
L35:Estate
8:2008
2:Bochum
123403:SERIAL NUMBER
2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 4DU = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO A88 = OPĚRKA HLAVY,PŘEDNÍ SEDADLO,AKTIVNÍ AH3 = PŘEDNÍ SEDADLO,ŘIDIČ,RUČNÉ NASTAVENÍ AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA AJT = PRO PŘÍPRAVU K MONTÁŽI BEZPEČNOSTNÍ SÍTĚ AP9 = SÍŹ NÁKLADOVÉHO PROSTORU AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BA9 = CHLADNIČKA BNS = LIŠTA KRYCÍ DVEŘE VNITŘEK,SATÉNOVÁ STONE BPI = LIŠTA PŘÍSTROJOVÉ DESKY,SATÉNOVÁ STONE BRL = IDENTIFIKAČNÍ KRITICKÝ BOD MR 2008 1/2 C32 = PRO SYSTÉM QUICKHEAT C68 = PRO ELEKTRONICKOU KLIMATIZACI C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CE1 = STÍRAČ,PŘEDNÍ,IMPULSOVÝ SYSTÉM CT3 = PRO NĚMECKO CT3 D75 = KLIKA ÚPLNÁ VNĚJŠÍ DD8 = PRO VNITŘNÍ ZRCÁTKO CITLIVÉ NA SVĚTLO DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4Q = ENJOY E94 = KRYT ECA = KLÍČ FX3 = PROGRAM ELEKTRONICKÉ STABILITY FXB = POMĚR NÁPRAVY 3.65 G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K13 = POUŽÍVÁ SE S FILTREM PEVNÝM ČÁSTIC VE VÝFUKOVÉM SYSTÉMU K34 = REGULÁTOR RYCHLOSTI KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA KG9 = ALTERNÁTOR,140A LHD = ŘÍZENÍ LEVÉ LPV = VZNĚTOVÝ MOTOR Z17DTJ,A17DTJ MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR) N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NS2 = PRO VARIABILNÍ POSILOVAČ ŘÍZENÍ NT4 = EMISE,EEC 05 OHA = MÍSTNÍ GM Z EUROPE OHA P92 = KRYT,KOLO 16PALCOVÉ PROVEDENÍ CHAMPAGNE MR07 PHP = TEXTILNÍ ČALOUNĚNÍ,TABITA/ELBA QGF = PNEUMATIKY,205/55 R 16-91H QN1 = KOLO,DISKOVÉ,OCELOVÉ,61/2JX16 QQ5 = PRO VELKÉ NÁHRAD.KOLO R2D T2Q = REFLEKTORY,AUTOMATICKÉ ZAPÍNÁNÍ/VYPÍNÁNÍ T67 = BATERIE,70AH T96 = SVĚTLO DO MLHY PŘEDNÍ T9M = ČALOUNĚNÍ ELBA TGR TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ TSQ = OSVĚTLENÍ INTERIÉRU DELUXE TTO = RÁDIO CHLADICÍ SYSTÉM TTX = PRO POMOCNÝ KONEKTOR RÁDIA U3A U55 U66 = REPRODUKTOR,7 U68 = INFORMAČNÍ POČÍTAČ UAG = GRAFICKÁ INFORMACE - JEDNOBAREVNÁ UCE = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,NAVIGACE,ETR,TLUMENÍ UEC = SNÍMAČ INDIKÁTOR AUTOMATICKÉ RECIRKULACE VZDUCHU UJ3 UWA = PŘÍPRAVA PRO MOBILNÍ TELEFON,S OVLÁDÁNÍM HLASEM A SYSTÉMEM BLUETOOTH V2T = NOSIČ,ZAVAZADEL,STŘEŠNÍ,S PRÁŠKOVOU ÚPRAVOU V3D = NOSIČ ZAVAZADEL VOLNÝ STŘEŠNÍ,ČERNÝ VG9 = OCHRANNÍ VOSK VJU = STŘEDOVÝ PŘÍSTROJ NA PANELU,SATÉNOVÁ STONE W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO WBG = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,GPS XA3 = OPEL XG3 = PRO NĚMECKO Y67 = POŽADUJE PŘI OSAZENÉM SERVISNÍM DISPLEJI Z0F = PRO NĚMECKO Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ
Prosil bych o číslo dílu - spodní část zadního nárazníku OPC. Díky
93186654 - 64 00 611 - NÁSTAVEC, ZADNÍ KONC.PANEL LINE PACK 2 - Cena s DPH 10 128 Kč
93186661 - 64 00 612 - NÁSTAVEC, ZADNÍ KONC.PANEL OPC, VXR - Cena s DPH 10 503,6 Kč
paulinek
Příspěvek od paulinek »
Mohl bych poprosit o číslo na toto: http://corsaar.sweb.cz/drzak/fach2qf5.jpg pokud to jde takhle : ))
Já se prostě v tom opeloem nevyznám a nedokážu to tam najít :D jestli to tam vůbec je...
Zafira B 2009 1.7 CDTi, 92 kW
