Mnozstvo chybovych kodov 1.9CDTi(DTL)-Pomoc
Bryan974
Příspěvek od Bryan974 » 24 srp 2013, 10:57
Zdravim!
Uz dlhsiu dobu nas doma trapia problemy s nasou Zafirou ... zacalo to chybovym kodom ...
P1125 - Throttle Actuator Malfunction
(61) - Present
Skrtiaca klapka uz bola 2x precistena, no stale to hadze do nudzaku ... dnes sa objavili dalsie:
Total number of fault codes: 9
P0070 - Ambient Air Temperature Sensor Malfunction
(71) - Not present
P1811 - Torque Signal Malfunction (CAN)
(72) - Not present
P0500 - Vehicle Speed Signal Range/Performance
(7E) - Not present
U2103 - CAN-Bus Circuit Malfunction
(08) - Not present
U2139 - CAN-Bus No Communication with CIM (Steering Column Module)
(7F) - Not present
P1815 - Cruise Control Interface Malfunction
(72) - Not present
(70) - Not present
P0650 - CAN-Bus No Communication with CIM (Steering Column Module)
(70) - Not present
(61) - Present
Takisto to sprevadzaju problemy s DPF filtrom, dnes mi ukazalo znecistenie na 104%, niekedy sa precistit sam aj na 20%, niekedy sa nespusti automat, trebo tu rucne cez OPCOM. A dalsia vec, peni sa chladiaca zmes. Bola vymenena za novu, ale robi sa to stale ... Nejake rady? Jedna sa o Opel Zafira 2006 1.9CDTi- DTL.
Vdaka za kazdu pomoc ...
